Neoslim22 0 #1 March 5, 2010 look at 3:45 in the video. http://www.dropzone.com/videos/Exits/Men_in_Black_jumping_in_Static_Line_1339.html Quote Share this post Link to post Share on other sites
dragon2 2 #2 March 5, 2010 http://www.dropzone.com/videos/Exits/Men_in_Black_jumping_in_Static_Line_1339.html What you're seeing is 2 different methods for static line, the one you're referring to is called pilot chute assist. So yes, normal, at some Dz's and in some countries. Also used for BASE sometimes ciel bleu, Saskia Quote Share this post Link to post Share on other sites
jtnesbitt 0 #3 March 5, 2010 Is it still considered a PCA if the person holding the PC doesn't pop the pin(s)? A PCA in base where the holder doesnt actually pop the pins is called a freefall assist. I didnt know if this was also the case in skydiving."If this post needs to be moderated I would prefer it to be completly removed and not edited and butchered into a disney movie" - DorkZone Hero Quote Share this post Link to post Share on other sites
BrianM 1 #4 March 5, 2010 That's not static line at all. It's IAD (Instructor Assisted Deployment)."It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
Andy9o8 3 #5 March 5, 2010 QuoteThat's not static line at all. It's IAD (Instructor Assisted Deployment). You mean the PCAs are IAD, right? I think you'll agree that some in the video are clearly S/L and others are clearly IAD. Quote Share this post Link to post Share on other sites
BrianM 1 #6 March 5, 2010 QuoteQuoteThat's not static line at all. It's IAD (Instructor Assisted Deployment). You mean the PCAs are IAD, right? I think you'll agree that some in the video are clearly S/L and others are clearly IAD. The static lines are direct bag. The handheld pilot chute is IAD, not static line. PCA static line is a third method that I didn't see in that video."It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
billvon 3,151 #7 March 5, 2010 >You mean the PCAs are IAD, right? PCA is a form of static line, separate from direct bag. Quote Share this post Link to post Share on other sites
Andy9o8 3 #8 March 5, 2010 QuoteQuoteQuoteThat's not static line at all. It's IAD (Instructor Assisted Deployment). You mean the PCAs are IAD, right? I think you'll agree that some in the video are clearly S/L and others are clearly IAD. The static lines are direct bag. The handheld pilot chute is IAD, not static line. PCA static line is a third method that I didn't see in that video. You're right; I started back when all students were S/L - some were direct bag and some were PCA. In more recent times I've sometimes heard IAD referred to as PCA because there's been some bleed-over of the terminology from BASE. I think posts 2 & 3 kind of reflect that. But your use of the terms is the correct one. Quote Share this post Link to post Share on other sites
BrianM 1 #9 March 5, 2010 Also looks like those IAD pilot chutes are being thrown pretty high up. The tail isn't much higher than the door on an AN-2, and the strut comes down to about mid-door or lower."It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
Remster 30 #10 March 5, 2010 Is that the standard way of dispatching students when using a larger plane in a IAD setup? I've only done IAD from cesnas, so dont know any better...Remster Quote Share this post Link to post Share on other sites
Remster 30 #11 March 5, 2010 QuoteAlso looks like those IAD pilot chutes are being thrown pretty high up. The tail isn't much higher than the door on an AN-2, and the strut comes down to about mid-door or lower. Hence my question one post above.... I was cringing.Remster Quote Share this post Link to post Share on other sites
BrianM 1 #12 March 5, 2010 Quote Hence my question one post above.... I was cringing. Me too. If you pause the video at the right spot, it looks like some of those PCs are getting very close to the tail strut, though you can never see both the strut and the PC at the same time. I wonder how well an AN-2 flies without a tail? "It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
billvon 3,151 #13 March 5, 2010 >Is that the standard way of dispatching students when using a larger plane >in a IAD setup? I don't know. I've used both. Direct bag gets you more reliable but much scarier looking deployments, since the parachute deploys top/side to the relative wind. PCA gets you cleaner deployments but the student has a greater chance of screwing things up by grabbing or rolling through stuff. Quote Share this post Link to post Share on other sites
popsjumper 2 #14 March 6, 2010 Quote I wonder how well an AN-2 flies without a tail? I'm not sure the AN2 flies fast enough to put enough drag on anything to rip off the tail. Talking to an AN2 pilot, he said his greatest fear was a bird strike....from the rear. My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
BrianM 1 #15 March 6, 2010 Quote Quote I wonder how well an AN-2 flies without a tail? I'm not sure the AN2 flies fast enough to put enough drag on anything to rip off the tail. Talking to an AN2 pilot, he said his greatest fear was a bird strike....from the rear. Good point! I've jumped from an AN-2, and watching it take off and land is impressive. Apparently the procedure for power loss in low visibility is to pull the stick all the way back and keep the wings level - it won't stall."It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
DeNReN 0 #16 March 6, 2010 If I am ever in a plane without a tail...I hope it is a AN2 Brian...Cinnamon Girl is sitting in West River ...dosent look like its moved in a few years Quote Share this post Link to post Share on other sites
riggerrob 644 #17 March 6, 2010 No! That is not the preferred method for IADing students from large airplanes. I have IADed students from all the usual piston-pounding Cessnas, but the only "big" airplane I have IADed students from was a Twin Otter. Twin Otters are among the few "big" airplanes that can fly slow enough for IAD and we stuck with standard IAD procedures, which include tossing the pilot-chute below floor level/bottom edge of the door. Any higher and you risk tearing the horizontal tail off the airplane. On a separate note: it is rare to see static-line and IAD on the same DZ, because most DZs "locked" onto one method decades ago. For example, there are only two civilian DZs in Canada still dropping students with static-lines. All the other Canadian DZs converted to IAD during the 1980s. Rob Warner S/L Instructor since 1982 IAD Instructor since 1984 Tandem Instructor since 1986 Progressive Freefall Instructor since 1989 Quote Share this post Link to post Share on other sites
1969912 0 #18 March 6, 2010 What are the benefits of IAD vs SL? Less time to get unstable? No chance of wrapping the static line around an arm or foot? "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
BIGUN 1,520 #19 March 6, 2010 Search Results: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=2259507;search_string=static%20line%20vs%20iad;#2259507Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
riggerrob 644 #20 March 6, 2010 IAD advantages include less paint beaten off the airplane and being able to use one set of gear for all types of students (first-timers and freefallers). Oh! And less mess on the cabin floor after all students have left. (Direct bag) Static-line advantages include a greater chance of deploying a canopy over the head of even the dumbest student. Static-line disadvantages include greater wear on gear, greater wear on airplanes and a higher incidence of line twists. Both systems require jump-masters to avoid routing bridles around students' necks, arms, ankles, etc. Neither system is perfect, but I find IAD to be a much lower workload on the jump-master, allowing him to devote more energy to TEACHING. Quote Share this post Link to post Share on other sites
Andrewwhyte 1 #21 March 6, 2010 I have long been of the opinion that people obsess about throwing the pilot chute down on IADs. As long as the pilot chute is released after the jumper is away it will be going down. If it is released from a point above the tail it may cause a problem, but as long as it starts out below the tail, it will not go up unless it is pivoting up after encountering resistance (the pin or the tree rings). In this case the j/m clearly releases after the jumper is away. I do have a problem with her not actually placing the p/c outside the aircraft. Quote Share this post Link to post Share on other sites
1969912 0 #22 March 6, 2010 QuoteIAD advantages include less paint beaten off the airplane and being able to use one set of gear for all types of students (first-timers and freefallers). Oh! And less mess on the cabin floor after all students have left. (Direct bag) Static-line........ Thanks. That makes sense. Does the instructor always release the PC at the same point, or does he/she either release it or delay release based upon the the stability of the student at exit? EDITED for poor wording. "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
BrianM 1 #23 March 6, 2010 Quote Brian...Cinnamon Girl is sitting in West River ...dosent look like its moved in a few years That's too bad. She's a beautiful plane, and a fun jump ship too."It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
BrianM 1 #24 March 6, 2010 QuoteOn a separate note: it is rare to see static-line and IAD on the same DZ, because most DZs "locked" onto one method decades ago. I found that interesting too. Possibly they are using both because they have a mix of gear? I can't think of any other reason they would do that. QuoteFor example, there are only two civilian DZs in Canada still dropping students with static-lines. STI would be one. What's the other one?"It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
BrianM 1 #25 March 6, 2010 QuoteI have long been of the opinion that people obsess about throwing the pilot chute down on IADs. As long as the pilot chute is released after the jumper is away it will be going down. If it is released from a point above the tail it may cause a problem, but as long as it starts out below the tail, it will not go up unless it is pivoting up after encountering resistance (the pin or the tree rings). In this case the j/m clearly releases after the jumper is away. I do have a problem with her not actually placing the p/c outside the aircraft. Perhaps, but it is no harder to place it low than it is to place it high. Given the abillity to place it wherever I wish, I will always choose to place it low. At least one of the PC's in that video looked like it was thrown out and up."It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
