kallend 2,147 #1 April 14, 2010 Jump 3 of the SOS event today, my slot is instructed not to pull above 2.5k. Opening was fine, went to release the toggles and the right one wouldn't release. Just thinking I might chop because I was approaching 2k, when I took another look and saw that my slider had come down past the "top hat" bumper on my right rear riser and had trapped the brake line. Pushing the slider back above the bumper released the toggle.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
fasted3 0 #2 April 15, 2010 How quick does your canopy open? Good on the quick thinking!But what do I know? Quote Share this post Link to post Share on other sites
artard 0 #3 April 15, 2010 I had a cutaway a couple weeks ago because of a stuck brake line/spin and in retrospect think something like this caused ithttp://www.mixcloud.com/prajna http://vimeo.com/avidya Quote Share this post Link to post Share on other sites
davelepka 4 #4 April 15, 2010 QuoteOpening was fine, went to release the toggles and the right one wouldn't release I took another look and saw that my slider had come down past the "top hat" bumper on my right rear riser and had trapped the brake line. Pushing the slider back above the bumper released the toggle. Normally I would suggest that there is no rush to unstow your brakes, and that it's good practice to inspect your toggles and excess brake line before unstowing the brakes. This helps to prevent little porblems like this, or putting your hand through a loop of excess brake line from becoming a big problem. However, this was at an SOS event, so I'm guessing this was a bigger way jump, and keeping your eyes on the sky looking for traffic after opening is probably more important in that circumstance. To everyone else, if you can clear your area and have the time, take a look before you unstow. Quote Share this post Link to post Share on other sites
kkeenan 14 #5 April 15, 2010 QuoteJust thinking I might chop because I was approaching 2k, when I took another look ... Kudos to John for fixing the issue rather than cutting away an otherwise good canopy. I know that we don't want to encourage Newbies to mess with in-air problems too long, but there's a lot to be said for experienced, knowledgeable jumpers taking a moment to analyze an issue prior to initiating EPs. Once again, if you are a newer jumper, never hesitate to follow your training with regard to initiating EPs. But, if you have the experience and mental stability to recognize a simple fix, then fix it. The most common issue I've seen is a brake line released on opening. If you're turning under an otherwise good-looking canopy, unstow your breaks. When you find that one was already unstowed, but now you're flying straight, then, Voila!, you've fixed it. Once again; If you don't know what you're looking at or how to deal with it, do not hesitate to execute your EPs. Reserves ALWAYS work... except for when they don't. There's no point in worrying about it, but some people say you only have so many Silver Bullets. Kevin K._____________________________________ Dude, you are so awesome... Can I be on your ash jump ? Quote Share this post Link to post Share on other sites
peek 21 #6 April 15, 2010 I would like to understand that, but I'm having trouble visualizing the parts and what they were doing. Quote Share this post Link to post Share on other sites
GLIDEANGLE 1 #7 April 15, 2010 Quote But, if you have the ALTITUDE, experience, and mental stability to recognize a simple fix, then fix it. I suspect that is what you meant. The choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites
Skydivesg 7 #8 April 15, 2010 Hi John. I'm glad everythig worked out. I have a couple of questions just out of cuiousity. Does your toggle keeper have the enclosed dome on the top so that when the toggle is stowed you can't see the yellow locking tab. Also how do you stow your excess steering line if at all? I've had two friends cutaway from something very similar in the last few months. I'm trying to find out all the particulars I can, to determine if we can do things better. And did you have a harder than usual opening causing the slider to come down hard? How often does your slider come down past the top hat stops? Sorry for all the ??s but I appreciate the info.Be the canopy pilot you want that other guy to be. Quote Share this post Link to post Share on other sites
jsaxton 0 #9 April 15, 2010 So how are the jumps going? Quote Share this post Link to post Share on other sites
kallend 2,147 #10 April 16, 2010 QuoteI would like to understand that, but I'm having trouble visualizing the parts and what they were doing. Well, since I have a personal hard deck of 2k I didn't really have time for a super detailed analysis, it was fix it right now or chop. The toggle wouldn't release and I could see the slider had come below the "top hat" bumper and was over the toggle and (stowed) excess brake lines (URW velcroless risers, excess line passed through the keepers on the back of the risers). I can't say exactly what the mechanism of the jam was. Pushing the slider back above the bumper freed it up. Canopy PD Storm 135, fairly short snivel. Threw out my PC as instructed at 2.5k... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
kallend 2,147 #11 April 16, 2010 QuoteSo how are the jumps going? As well as can be expected for a bunch of geezers.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
Andy9o8 2 #12 April 16, 2010 QuoteCanopy PD Storm 135, Hey, how do you like that canopy compared to your Spectre? Specifically, howzit on the spine on openings? Quote Share this post Link to post Share on other sites
kallend 2,147 #13 April 16, 2010 QuoteQuoteCanopy PD Storm 135, Hey, how do you like that canopy compared to your Spectre? Specifically, howzit on the spine on openings? Faster than the Spectre, but not too fast. I got it for wingsuiting where a Spectre is maybe a little too slow.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
jumpwally 0 #14 April 19, 2010 and how about the other qualities ? flare ? turns ? etc.. thanks smile, be nice, enjoy life FB # - 1083 Quote Share this post Link to post Share on other sites
Prior23 0 #15 April 22, 2010 Quote saw that my slider had come down past the "top hat" bumper on my right rear riser and had trapped the brake line. Pushing the slider back above the bumper released the toggle. That happens to me all the time. Either my slider comes down 2/3s of the way or it slams down and comes over the risers and I have to play with it to get my toggles release. Although mine is most likely due to me being new at packing.I'm jumping my DZs 150 triathlon and they have it set up with a bag for a 135, the canopy is relatively new, so this thing is a nightmare for a newbie like me to pack... B.A.S.E. #1734 Quote Share this post Link to post Share on other sites
AFFI 0 #16 April 23, 2010 Quote Quote But, if you have the ALTITUDE, experience, and mental stability to recognize a simple fix, then fix it. I suspect that is what you meant. +1 Altitude awareness may be considered as something that "goes without saying", but it is not. Altitude awareness should be continually trained and practiced over and over again. When I train students and challenge them with say, a line twist scenario - they must check altitude prior to dealing with the situation and every 5 seconds during. “Roll to Recover” training prior to release dives, before attempting to roll belly to earth, check altitude first. Seems like many jumpers progress in the sport and it is practiced less and less. Becoming an instructor revealed deficiencies in my altitude awareness and it improved only as a byproduct of training specifically for that awareness. I personally lost a friend as a direct result of a lack of altitude awareness after cutting away too low and we read about it in the incident reports all to often, and at times it is an experienced jumper who should have known better, so it can happen to any of us if we overlook it during traiining and during all the excitement of dealing with a situation. As the OP described, altitude awareness was part of the decision making process. Great job! Altitude awareness often times may be a primary factor between living and dying.Mykel AFF-I10 Skydiving Priorities: 1) Open Canopy. 2) Land Safely. 3) Don’t hurt anyone. 4) Repeat… Quote Share this post Link to post Share on other sites
