JohnRich
Static Line Attachment Point
Attached is a photo of a static line attachment ring on the back wall near the door of an Otter. We haven't done any static line students in years, but the ring is still there, just in case.
Because of the way it is attached, the ring can rotate to be pointed either towards the door or away from the door.
Sometimes when I get on the plane I find the ring pointing inboard. This is not safe! When it is pointed inward, it can act like a hook to snag someone's reserve ripcord as they slide along the back wall to dive out the door. Beware!
When the ring is pointing outward, it can cause no problems.
Does anyone else have a problem like this?
The safe way is to have the static line attachment point at floor level, preferably at the front of the door.
Sparky
Isn't the static line supposed to be routed above/over the student's shoulder when they exit, to reduce the possibility of an acrobatic entanglement? And if so, wouldn't having the ring on the floor make it more difficult to achieve this?
Pull.
> shoulder when they exit . . .
Most SL aircraft I have used had the SL attachement down low. I would manage the static line with my "high" hand, and keep it above him until he actually let go of the airplane.
The one exception was an Otter that we rigged with a SL attach on the inside of the floater bar. It was awkward to use, since I was used to a low SL, and I always worried about the tail with a premature release.
If the static line attachment is at the top of the door, it is the same a cutting 3+ feet off the static line.
Sparky
Most SL aircraft I have used had the SL attachment down low. I would manage the static line with my "high" hand, and keep it above him until he actually let go of the airplane.
Um, yeah. I guess if I had thought about this more, I would have realized that it's the same in the planes I've been in while students are SLed out. Durrr. :S
Pull.
