SansSuit 1 #1 June 27, 2010 Is there a website that will calculate the distance and radial to the nearest VOR? When preparing the 7711-2 for demo jumps I'm using a sectional and a protractor. This is the year 2011. There has to be a better method. I did a quick search but didn't find what I was looking for. Thanks !Peace, -Dawson. http://www.SansSuit.com The Society for the Advancement of Naked Skydiving Quote Share this post Link to post Share on other sites
CSpenceFLY 1 #2 June 27, 2010 No one is going to check your numbers. They just want it close. Quote Share this post Link to post Share on other sites
JumpHog 0 #3 June 27, 2010 If you really want to be exact, you can use Google Earth's "Ruler" tool. Find the nearest VOR, select that as your reference and measure the distance (in nautical miles) from there to your demo site. It will also show you the bearing to that site, which you can use to figure the radial off the VOR. You will have to figure in the magnetic variation (which is printed on your sectional) to convert the true course from Google Earth into a magnetic course which is what the VOR radials are based on. Quote Share this post Link to post Share on other sites
dninness 4 #4 June 28, 2010 QuoteNo one is going to check your numbers. They just want it close.[/reply Last demo jump I did, the FSDO's ops inspector and I spoke on the phone and he _did_ check my numbers.NIN D-19617, AFF-I '19 Quote Share this post Link to post Share on other sites jim_32766 0 #5 June 28, 2010 If I remember correctly that information was displayed in MS Flight Simulator, along with GPS coordinates, for any location you chose. I checked the data once against my airplane nav gear and found it was quite accurate. Check it out and let us know if that works for you.The meaning of life . . . is to make life have meaning. Quote Share this post Link to post Share on other sites Dean358 0 #6 June 28, 2010 QuoteIs there a website that will calculate the distance and radial to the nearest VOR? When preparing the 7711-2 for demo jumps I'm using a sectional and a protractor.! Are you using a "protractor" or a "plotter?" A flight plotter has millage scales on the bottom which are very easy to use. And while it may seem like it's old fashioned using one on top of a sectional to calculate distance and radial I'd argue there's actually much to be said for "old school" flight planning! Cheers, Dean Edited to add: here's a fancy-schmancy one: http://sportys.com/PilotShop/product/9284www.wci.nyc Quote Share this post Link to post Share on other sites SansSuit 1 #7 June 28, 2010 Quote You will have to figure in the magnetic variation (which is printed on your sectional) to convert the true course from Google Earth into a magnetic course which is what the VOR radials are based on. Thanks ! Just a tad more complicated that what I had imagined but it does do the job. How about a quick block of instruction on how to figure out this conversion? Does this have to do with the red dashed lines that run diagonally through the sectional? The point I'm looking at lies directly between one that reads "3°W" and "4°W" if that helps.Peace, -Dawson. http://www.SansSuit.com The Society for the Advancement of Naked Skydiving Quote Share this post Link to post Share on other sites wolfriverjoe 1,523 #8 June 28, 2010 QuoteQuote You will have to figure in the magnetic variation (which is printed on your sectional) to convert the true course from Google Earth into a magnetic course which is what the VOR radials are based on. Thanks ! Just a tad more complicated that what I had imagined but it does do the job. How about a quick block of instruction on how to figure out this conversion? Does this have to do with the red dashed lines that run diagonally through the sectional? The point I'm looking at lies directly between one that reads "3°W" and "4°W" if that helps. Yes. If you look on the "legend" part, it tells you that those are the lines of variation. You want to add west variation to the true heading. There's an explanation HERE. Go down the page to just below the picture of the sectional chart to skip over the prelimiary crap about a cross country flight."There are NO situations which do not call for a French Maid outfit." Lucky McSwervy "~ya don't GET old by being weak & stupid!" - Airtwardo Quote Share this post Link to post Share on other sites azureriders 0 #9 June 28, 2010 QuoteNo one is going to check your numbers. They just want it close. depends on the FSDO. Some will check EVERY DETAIL OF YOUR 7711-2 and expect extra documentation. I have seen 7711-2's rejected because of faulty numbers from the nearest VOR, and the numbers were "close" to begin with. It helps is you can include the Lat & Lon of the LZ. The FSDO that I normally am dealing with, who is very detailed and will check things out, really likes it when I include a satelite image of the LZ. On the image I mark off the actuall landing area and The radius of the drop zone around the target expressed in nautical miles.FAR 105.15-a-2. Quote Share this post Link to post Share on other sites NickDG 23 #10 June 28, 2010 Give the feds the minimum amount of info requested. Tell them you're the Tea Party Demo Team and if they give you any shit then picket the FISDO with signs like, "The Skis Belong to US!" LOL . . . NickD Quote Share this post Link to post Share on other sites azureriders 0 #11 June 28, 2010 Here is a spread sheet that will give you what you need, very accurately provided you have the lat/lon for both the VOR and your landing area. Those numbers should not be hard to get, but if so, hopefully someone will get some use out of this. Be sure to enable macros when opening the file. No viruses, I promise Quote Share this post Link to post Share on other sites SansSuit 1 #12 June 29, 2010 Thanks! I'll give that try as well.Peace, -Dawson. http://www.SansSuit.com The Society for the Advancement of Naked Skydiving Quote Share this post Link to post Share on other sites kallend 2,148 #13 June 29, 2010 en.wikipedia.org/wiki/Spherical_trigonometry... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites Squeak 17 #14 June 29, 2010 Quote Give the feds the minimum amount of info requested. Tell them you're the Tea Party Demo Team and if they give you any shit then picket the FISDO with signs like, "The Skis Belong to US!" LOL . . . NickD They'll reply with ..you can keep your damned Skis. But the SKIES belong to the FAAYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites SansSuit 1 #15 June 30, 2010 Spherical trigonometry. Thanks for dumbing it down for me! Peace, -Dawson. http://www.SansSuit.com The Society for the Advancement of Naked Skydiving Quote Share this post Link to post Share on other sites JohnMitchell 16 #16 June 30, 2010 Quote How about a quick block of instruction on how to figure out this conversion? Does this have to do with the red dashed lines that run diagonally through the sectional? The point I'm looking at lies directly between one that reads "3°W" and "4°W" if that helps. Here's how I do it with a sectional and a strip of paper. First, mark a mileage scale on your strip of paper by laying it along a longitude and making a mark at each minute of latitude. Each minute= one nautical mile. Now take your new ruler scale and find your DZ. Now find the VOR you want to reference. Use your ruler , starting from the middle of the navaid to the DZ to measure the distance. Use the compass rose around the Navaid to get the magnetic radial. Combine these in the following format: VOR/radial/distance. My house is the TCM092011, or the McChord VORTAC 092 degree radial, 11 nm fix. Good enough for government work. Easy, easy. Quote Share this post Link to post Share on other sites Av1ator 0 #17 July 3, 2010 The Friendly Aviation Administration has some software too: http://www.naco.faa.gov/index.asp?xml=naco/online/compsys Remember...They are here to Help! Quote Share this post Link to post Share on other sites azureriders 0 #18 July 3, 2010 http://www.naco.faa.gov/index.asp?xml=naco/online/compsys Quote Share this post Link to post Share on other sites SansSuit 1 #19 July 3, 2010 QuoteThe Friendly Aviation Administration has some software too: I found that in my initial search. Alas, it is a PC program. I'm on a Mac.Peace, -Dawson. http://www.SansSuit.com The Society for the Advancement of Naked Skydiving Quote Share this post Link to post Share on other sites theonlyski 8 #20 July 3, 2010 QuoteQuoteThe Friendly Aviation Administration has some software too: I found that in my initial search. Alas, it is a PC program. I'm on a Mac. I should start a board of Mac vs PC pros and cons... If I wasnt so damn lazy!"I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites SansSuit 1 #21 July 4, 2010 Quote Here's how I do it with a sectional and a strip of paper.... That is pretty much how I had been doing it. The biggest problem with that is locating the exact landing area on the sectional. I don't know how much you've worked with sectionals but landmarks can be scarce. So my method was to find the exact location on a web page, zooming out until I could find landmarks that I could recognize on the sectional and then guess at the exact location of the landing area. Not very precise. It reminded me of the old army adage, "Plan it on a computer, measure it with a micrometer, mark it with a piece of chalk and then cut it with an axe."Peace, -Dawson. http://www.SansSuit.com The Society for the Advancement of Naked Skydiving Quote Share this post Link to post Share on other sites JohnMitchell 16 #22 July 4, 2010 Our neighbor hood is close to a junction of two rivers, easy to find. For the purpose of a NOTAM, +/- a mile seems okay. But I could understand trying to find your neighborhood in a yellow blob town on a sectional. Quote Share this post Link to post Share on other sites D2626 0 #23 July 7, 2010 go to a small airport and find a map called a "sectional" for your area then go to your jump pilot and ask him to show you how to use it. He'll be delighted to show you his skill. You can also use it figure out where to spot a cross-country jump. I keep the sectional in my gear bag. Quote Share this post Link to post Share on other sites SansSuit 1 #24 July 7, 2010 OK, I did the calculations for an upcoming demo. These were my results: By hand, using a sectional 23° 20 NMI Google Earth using the ruler tool (and adding the magnetic variation) 25.3° 19 NMI Excel spreadsheet (and adding the magnetic variation) 25.3° 19 NMI So, I was pretty close doing it by hand, just off by a couple degrees. But I like the precision of the other 2 methods. Playing around with Google Earth, it looks like the difference between my hand calculation and GE or Excel was about 1.3 miles.Peace, -Dawson. http://www.SansSuit.com The Society for the Advancement of Naked Skydiving Quote Share this post Link to post Share on other sites Beerlight 0 #25 July 7, 2010 QuoteOK, I did the calculations for an upcoming demo. These were my results: By hand, using a sectional 23° 20 NMI Google Earth using the ruler tool (and adding the magnetic variation) 25.3° 19 NMI Excel spreadsheet (and adding the magnetic variation) 25.3° 19 NMI So, I was pretty close doing it by hand, just off by a couple degrees. But I like the precision of the other 2 methods. Playing around with Google Earth, it looks like the difference between my hand calculation and GE or Excel was about 1.3 miles. Good, cept' (and damn it's been a while since I filed a notam for an off-DZ jump), but I don't think you need to figure in the magnetic variation? Just radial off the VOR and distance. Also, make sure you put a ZERO in front of 23 degrees, ie. 023 degrees. Always a three digit.. Have fun! I'm sure some rocket scientist will come along and correct me........ Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
