Bodhisattva420 0 #1 March 1, 2011 For the old timers out there . . . When you used to pack outside, did you just lay your canopy on the grass? Since I drag my rig when packing I decided to purchase a drag mat online from paragear.com. The weather is getting nicer here in Texas and I was just wondering if I could use it to pack outside when its nice out. Any suggestions would be appreciated. Quote Share this post Link to post Share on other sites
likvidskaj 0 #2 March 1, 2011 Never pack outside, nobody does that. Oldtimers just used those rounds and there was no need to pack them as we all know. Quote Share this post Link to post Share on other sites
mchamp 1 #3 March 1, 2011 Not an old timer, but only pack outside if no other option is available. 1) UV light diminishes the material over time. 2) You can pick up many unknown objects that could potentially damange/create holes within the canopy 3) Dirt and dust within the canopy and container.....nobody likes thatFor info regarding lift ticket prices all around the world check out http://www.jumpticketprices.com/dropzones.asp Quote Share this post Link to post Share on other sites
bofh 0 #4 March 1, 2011 QuoteNot an old timer, but only pack outside if no other option is available. 1) UV light diminishes the material over time. 2) You can pick up many unknown objects that could potentially damange/create holes within the canopy 3) Dirt and dust within the canopy and container.....nobody likes that I've found dry, green grass to be more clean than most indoor places. Sand and dirt tend to fell down between the grass straws where the canopy does not go. Bigger objects are not hard to see while laying down the canopy. If the ground is wet, dirty etc, I only put down the canopy while taking off the rig, if there's nobody around to hold it, but that's quite hard with a larger canopy. Quote Share this post Link to post Share on other sites
Glitch 0 #5 March 1, 2011 I'm tempted to call 'bullshit' on the previous posts. I've packed outside for years, with no noticeable wear/tear on my gear. ...From a UV perspective, your gear sees alot more sunshine when you jump it than it does when you pack it (think of those doing CRW). Pack it when you set it down, don't let it sit there for an hour while you grab a drink, smoke, or have lunch. ...don't pack in the mud or on gravel. Common sense. ...do use a drag mat or packing mat if you have one but if you dont, then I've found that grass works nicely. IMHO... YMMV.Randomly f'n thingies up since before I was born... Quote Share this post Link to post Share on other sites
Glitch 0 #6 March 1, 2011 Quote I've found dry, green grass to be more clean than most indoor places. Sand and dirt tend to fell down between the grass straws where the canopy does not go. Bigger objects are not hard to see while laying down the canopy. Agree... and you posted before I hit the send button. Randomly f'n thingies up since before I was born... Quote Share this post Link to post Share on other sites
airtwardo 7 #7 March 1, 2011 Quote Not an old timer, but only pack outside if no other option is available. 1) UV light diminishes the material over time. 2) You can pick up many unknown objects that could potentially damage/create holes within the canopy 3) Dirt and dust within the canopy and container.....nobody likes that You kids these days...Use to be there WASN'T an INSIDE for packing, the world didn't stop turning, we didn't end up robbing banks or raping geese. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
normiss 893 #8 March 1, 2011 Agreed. Besides, I can make the next load if I back next to the landing area. Quote Share this post Link to post Share on other sites
Andy_Copland 0 #9 March 1, 2011 QuoteI'm tempted to call 'bullshit' on the previous posts. I've packed outside for years, with no noticeable wear/tear on my gear. ...From a UV perspective, your gear sees alot more sunshine when you jump it than it does when you pack it (think of those doing CRW). Pack it when you set it down, don't let it sit there for an hour while you grab a drink, smoke, or have lunch. ...don't pack in the mud or on gravel. Common sense. ...do use a drag mat or packing mat if you have one but if you dont, then I've found that grass works nicely. IMHO... YMMV. Yep. Agreed.1338 People aint made of nothin' but water and shit. Until morale improves, the beatings will continue. Quote Share this post Link to post Share on other sites
JohnRich 4 #10 March 1, 2011 Pack outside - no harm will come to you or your gear. Grass is good. If the ground is dirt, lay down a tarp first and pack on the tarp. Get in the shade of a tree if you can. A packing-tarp is a standard part of my skydiving gear. When inside packing gets too crowded, and the weather outside is nice, go outside. Once packed, drape that drag mat over top of your rig to ward off the sunlight. By being outside, you also don't have to listen to someone else's screaming punk-rock music, and you can watch the action of other loads landing. Watch out for loose dogs... If there's a picnic table or a car trunk to keep the rig off the ground away from urinating dogs, use it. Quote Share this post Link to post Share on other sites
virgin-burner 1 #11 March 1, 2011 Quote Never pack inside, nobody does that. there, fixed it for you! dayum.. “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
wrightskyguy 1 #12 March 1, 2011 QuoteUse to be there WASN'T an INSIDE for packing, the world didn't stop turning, we didn't end up robbing banks or raping geese. *** Well, maybe not robbing banks. John Wright World's most beloved skydiver Quote Share this post Link to post Share on other sites Andy9o8 2 #13 March 1, 2011 Truth be told, packing outside is best done with a 19 year old girl wearing cut-off shorts and a tube top. Don't ask me why; it just is. Quote Share this post Link to post Share on other sites GLIDEANGLE 1 #14 March 1, 2011 If PRO packing over my shoulder in the breeze/wind, I find it best to have the canopy upwind and the rig downwind. The wind blows the canopy towards me, and the canopy does not try to fill with air. YMMVThe choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites david3 0 #15 March 1, 2011 Quote Any suggestions would be appreciated. Stay out of the prop blast. Quote Share this post Link to post Share on other sites Coreefdiver 0 #16 March 1, 2011 flat packed outside for years. used a drag mat then and still doDS#727, DB Cooper #41, POPS #11065, SCR #13183, FA #2125, SCS #8306, HALO #309 SRA #5930 Quote Share this post Link to post Share on other sites likvidskaj 0 #17 March 1, 2011 ha ha, thanks VB I can't believe there's so many posts on this subject geez, man, pack wherever you want, but you can enjoy some breeze and suntan when packing outside there were no indoors packing areas back then and they are in fact rare even today pack outside and be a part of The Elements Quote Share this post Link to post Share on other sites virgin-burner 1 #18 March 1, 2011 to my knowledge, there's ONE dz here that has an indoor packing area.. i find packing on grass much easier too..“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites jonstark 8 #19 March 1, 2011 I can count on my fingers and maybe have to use a few toes the number of times I have packed inside. I use a rig cover or a drag mat with a flap that folds over to cover the rig. I sometimes even drop my shit where I land cuz the grass is nice there and pack it right up. That's in Florida and California too where there is plenty of sun and my canopy is packed right up into it's own shade in a hurry. Don't drop it and let it lay out in the sunshine while you go shoot the shit and review the video tho. Git 'er done! jon Quote Share this post Link to post Share on other sites D22369 0 #20 March 1, 2011 why drag the rig? once the canopy is in the bag simply put the locking stows in place then move toward the rig stowing as you go, no need to drag an expensive piece of equipment. RoyThey say I suffer from insanity.... But I actually enjoy it. Quote Share this post Link to post Share on other sites airtwardo 7 #21 March 2, 2011 Quote why drag the rig? once the canopy is in the bag simply put the locking stows in place then move toward the rig stowing as you go, no need to drag an expensive piece of equipment. Roy That's called 'walking the bag', great if ya can do it...us big ole fat guys with bad knees don't mind buying a new drag mat every decade or so! ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites virgin-burner 1 #22 March 2, 2011 Quote Quote why drag the rig? once the canopy is in the bag simply put the locking stows in place then move toward the rig stowing as you go, no need to drag an expensive piece of equipment. Roy That's called 'walking the bag', great if ya can do it...us big ole fat guys with bad knees don't mind buying a new drag mat every decade or so! i only do the locking-stows, then walk back to the rig where i stow the rest..“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites theonlyski 8 #23 March 2, 2011 Quote i only do the locking-stows, then walk back to the rig where i stow the rest.. I only have 2 locking stows. Gotta love freestowing!"I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites virgin-burner 1 #24 March 2, 2011 Quote Quote i only do the locking-stows, then walk back to the rig where i stow the rest.. I only have 2 locking stows. Gotta love freestowing! havent gotten around to get an mpod yet.. “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites theonlyski 8 #25 March 2, 2011 Quote Quote Quote i only do the locking-stows, then walk back to the rig where i stow the rest.. I only have 2 locking stows. Gotta love freestowing! havent gotten around to get an mpod yet.. Me either, I got the UPT one."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
