kelpdiver 2 #1 August 23, 2005 Just to get a decent WAG on RSL usage. Let's say Skyhooks and Colin's lanyards are same as plain jane RSLs, and not worry if you are on one side of the fence 60% of the time or 99.9%. And this would apply to you for 2005 onward, not what you may have done in the past. Let's stick to the other threads for the arguing, though if you're picking the minority option more than 5% of the time (CRW, camera, whatever), feel free to write how you decide. Quote Share this post Link to post Share on other sites
Squeak 17 #2 August 23, 2005 Yep have an RWS RSL and it connected, but no AAD at present, so in Oz if you are not and E license you need either an AAD OR an RSL. and they are to be functioningYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
FrenchyDiver 0 #3 August 23, 2005 Yup. Over 200 jumps and still have one. Always connected too Hispas Brothers President HISPA #2, Quote Share this post Link to post Share on other sites
airtwardo 7 #4 August 23, 2005 Never had one...never will. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
fueler 0 #5 August 23, 2005 I havent had one since about jump number 200. an instructor i would almost always go to gave me the advice that i should leave it connected until i have my first cut away. i did a little more digging for info to make my decision and finally decided to ditch my RSL. i had a cut away on jump number 230. no RSL required. i want to tell my reserve when to deploy. im more confident than ever that i dont want one. **************************************** what!? Quote Share this post Link to post Share on other sites
sundevil777 102 #6 August 23, 2005 I would secretely disconnect mine as a student. But that was when it was a long connection to the belly mount reserve. The thought of the handle getting ripped out of my hand or smacking me in the face was not comforting. OK, not very useful info for the modern world. People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
nate_1979 9 #7 August 23, 2005 Had one, had two cut aways where I didnt need it (one of which the RSL deployed my reserve after a spinning on my back malfunction) Dont need it, dont want it. No more RSL for me FGF #??? I miss the sky... There are 10 types of people in the world... those who understand binary and those who don't. Quote Share this post Link to post Share on other sites
skydiverton 0 #8 August 23, 2005 QuoteHad one, had two cut aways where I didnt need it (one of which the RSL deployed my reserve after a spinning on my back malfunction) Dont need it, dont want it. No more RSL for me And haw was your forced reserve opening? Ok I assume so the RSL did it's work ++++++++++++++++++++++++++++++++++++++++++++ Using your droque to gain stability is a bad habit, Especially when you are jumping a sport rig Quote Share this post Link to post Share on other sites
nate_1979 9 #9 August 23, 2005 QuoteQuoteHad one, had two cut aways where I didnt need it (one of which the RSL deployed my reserve after a spinning on my back malfunction) Dont need it, dont want it. No more RSL for me And haw was your forced reserve opening? Ok I assume so the RSL did it's work I'm guessing that it worked... Like I said, I had the dring pulled before I felt reserve ... The point is that I also worked, performed my EPs without any problem Dont need the RSL, never have needed it, and hopefully never will since I dont have it anymore FGF #??? I miss the sky... There are 10 types of people in the world... those who understand binary and those who don't. Quote Share this post Link to post Share on other sites
Freeflysmiley 2 #10 August 23, 2005 RWS skyhook, if someone takes my canopy out at 500ft I'll be the one with the fully inflated reserve at 430ft (hopefully)-------------------------------------------------- Practise the 6 P's! -------------------------------------------------- Quote Share this post Link to post Share on other sites
Scrumpot 1 #11 August 23, 2005 QuoteOK, not very useful info for the modern world. Sure it is, as it brings up at least in my mind still, a LEGITIMATE "thought process" none-the-less for AWARENESS. For instance, I was gear-checking a just off AFF novice this past weekend who had JUST bought his own gear. It was an original Vector (IIRC). The RSL on this set up was (IS in this case still) an "exposed" length (about 4-5" in my estimation) of RSL attached (or supposed to be 'attached") by velcro over the RH shoulder portion of the harness/yoke. The velcro was worn & the RSL between attachment point was looped and again, "EXPOSED". In that instance I too felt better that the RSL be disconnected (or not jumped at all until) & the rig looked at by a RIGGER. Not everybody jumps absolutely the MOST modern of gear even still, and it is incumbent upon ALL OF US to know/understand thy gear! ...The very gear we are supposedly "relying upon" to save our lives! I'm glad you posted this! -Grantcoitus non circum - Moab Stone Quote Share this post Link to post Share on other sites
billvon 3,155 #12 August 23, 2005 >if someone takes my canopy out at 500ft I'll be the one with the >fully inflated reserve at 430ft (hopefully) Yikes! I sure hope you haven't decided that you can cut away at 500 feet and live! Let's say you see your altimeter: 500 feet. Now, no altimeter is really that accurate, so you're really at 400 feet. You look up and - wham! - someone flies into your canopy and destroys it. 350 feet. It takes you only half a second to realize what happened and that you have to cut away. 300 feet. You drop the toggles, reach down to find the cutaway handle. 250 feet. You grab it and pull. 150 feet. The Skyhook does its thing and pulls the reserve out. 120 feet. Your reserve is now beginning to deploy. You're doing about 40mph downwards, and you're accelerating. Will you get an inflated canopy within 120 feet (<2 seconds?) Maybe, but that's an awful big risk to take. Quote Share this post Link to post Share on other sites
Elisha 1 #13 August 23, 2005 Not much choice for me, as the rig I bought didn't have an RSL. Not worried. Quote Share this post Link to post Share on other sites
Freeflysmiley 2 #14 August 23, 2005 I hope I'd never had to, but I tell u what, if I was under 1000ft on any standard rig with or without an rsl and my canopy was destroyed u only have one option- pull silver and get fabric over head. The reserve may never come out of its bag if your not going fast enough, or it may entangle with whats left of your main. Basically its not good, u know that your 100 times more experienced. A skyhook gives me the option of getting rid of the bag of shit above me and putting a FULLY INFLATED reserve above my head in less than 100ft. I'll take your point on board and rephrase my point ..under a grand its one hell of an option don't u think? But no I wouldn't be trying it at 300ft, even though your point is semi -inaccurate as I'm sure your aware there have been 2 demo's from sub 150ft ( slider down admittedly) But like I said I wouldn't be trying it that low P.s i wouldn't be wasting time looking at an alti which could be 200ft out if i was in shit at low level-------------------------------------------------- Practise the 6 P's! -------------------------------------------------- Quote Share this post Link to post Share on other sites
billvon 3,155 #15 August 23, 2005 >But no I wouldn't be trying it at 300ft, even though your point is >semi -inaccurate as I'm sure your aware there have been 2 demo's > from sub 150ft ( slider down admittedly.) Of course. I've jumped from ~300ft - but that was with very different gear, and I knew the altitude with great accuracy. The Skyhook is a great development in skydiving gear, but I hope it doesn't give people the false confidence that they can chop at any altitude and live. Quote Share this post Link to post Share on other sites
Darius11 12 #16 August 23, 2005 Have one, have had a cutaway and i pulled silver and was very calm no need for the RSL. Will keep mine for now. Once I am under a HP canopy I will reevaluate.I'd rather be hated for who I am, than loved for who I am not." - Kurt Cobain Quote Share this post Link to post Share on other sites
wmw999 2,631 #17 August 23, 2005 I can pull silver. I have an RSL. I'm betting that the chance that I'll be low and dirty on a cutaway is greater than the chance that an RSL will do the wrong thing. It's a crapshoot -- I have airbags in my car, too, even though I'm 5'4" and under. Wendy W.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
nael 0 #18 August 25, 2005 I have one and have decided to keep it connected until I have my first cutaway. I trust myself that I will pull the right handles when it counts, but so did people who are now deceased due to cuting away and then doing nothing until impact.www.TerminalSports.com.auAustralia's largest skydive gear store Quote Share this post Link to post Share on other sites
DrewEckhardt 0 #19 August 25, 2005 Two don't. One does because I haven't gotten arround to repacking it and removing the RSL. Quote Share this post Link to post Share on other sites
kelpdiver 2 #20 August 25, 2005 heh - I didn't think to give directions for those with multiple, conflicting rigs. Just take the 51% answer. Quote Share this post Link to post Share on other sites
Salsa_John 0 #21 August 25, 2005 QuoteRWS skyhook, if someone takes my canopy out at 500ft I'll be the one with the fully inflated reserve at 430ft (hopefully) I have a skyhook as well. "You did what?!?!" MUFF #3722, TDSM #72, Orfun #26, Nachos Rodriguez Quote Share this post Link to post Share on other sites
grue 1 #22 August 26, 2005 Currently renting, so there's an RSL on there. When my rig gets here, it'll have an RSL installed, which I will stop using after my first cutaway, most ilkely.cavete terrae. Quote Share this post Link to post Share on other sites
Superfletch 1 #23 August 29, 2005 I've got a Micron with a skyhook no AAD. I've got a Javelin with an RSL and AAD. I've got a Racer with no RSL and AAD. Rotate through them pretty regularly. I jump the Micron the most. I'd like to get a Vigil for it but can't afford it right now. Gary "Superfletch" Fletcher D-26145; USPA Coach, IAD/I, AFF/I Videographer/Photographer Quote Share this post Link to post Share on other sites
linc_harris 0 #24 August 30, 2005 Nope. Removed it after 500 Jumps Quote Share this post Link to post Share on other sites
btucker 0 #25 August 30, 2005 BTW: Our DZ has a local rule. If less than 200jumps you must use a RSL. This is additional to the APF which says {if less than 500 jumps} you must have an AAD. Blue Dreams Benno Quote Share this post Link to post Share on other sites
