Eagle9 0 #1 May 10, 2011 Jump from space The parachuting is considered to be one of the most attracting, exciting and wonderful kinds of sport. From the beginning of the twentieth century it has been adopted by pilots for safe flight and later it became breathtaking kind of sport. Throughout the previous century there were developed many kinds of it, such as: • Accuracy landing - Landing as close as possible to a target. • BASE jumping - From buildings, antennas, bridges (spans) and cliffs (earth). • Blade running - A kind of slalom with parachute. • Big-ways - Formation skydiving with many people. • Canopy formations - Making formations with other parachutists while under canopies. (Known also as canopy relative work or simply CRW) • Canopy piloting - Also known as 'swooping'. • Formation skydiving - Making formations during freefall. (Known also as relative work or simply RW) • Freefall cinematography • Freefall style • Freeflying • Freestyle skydiving • Military Parachuting • HALO/HAHO • Treejumping • Paraski • Skysurfing - Skydiving with a board strapped to your feet. • Wingsuit flying - Skydiving with a suit which provides extra lift. In spite of such great choice for sky divers probably there could be one more, perhaps the very unusual kind of this sport-jump from the space. Typically, parachuting occurs at the altitude of 4000 meters where the air is enough for breathing. In principle there is no difficulty to increase this altitude (and hence the time spent in Free-Fall), probably the sky diver will need to carry oxygen mask and warm cloth. However, we think that the space parachuting will be completely different thing. Generally, the atmosphere has not got clear boundary to space, the atmospheric pressure and density gradually decreases by growing altitude. However, according to the international definition the formal boundary lies at the altitude of 100 kilometers, therefore jump from space must be occurred at this altitude or a bit higher. Undoubtedly, such jump will require different conditions. First of all, no airplane, helicopter or the gondola of a balloon is able to carry passenger (sky diver) to such altitude (100 km), therefore a suborbital rocket/spacecraft will be needed, for example the SpaceShipOne that has been recently used for winning the X-Prize in 2004 year. A space-suit with some Oxygen supply (for at least 1-2 hours) will be also needed. The spacesuit must meet specific requirements since that altitude and acceleration 9.8 m/sec2 will cause the fact that the any object falling from such altitude will enter the atmosphere very quickly and this circumstance from its side will cause heating object’s surface. Of course the temperature in this case will not be as high as in case of orbital entry. Here we are guiding by the manual written for the suborbital spacecrafts by Drs. Marti Sarigul-Klijn and Nesrin Sarigul-Klijn: “Flight Mechanics of Manned Sub-orbital Reusable Launch Vehicles with Recommendations for Launch and Recovery” [1] [2] that shows the correlation between the maximum temperature and deceleration experienced during descent. It concludes that maximal temperature will be about 540 ° by Celsius due to the Mach 3.5 entry. As for the maximal g-load during fall it reaches 5.5 g at 21.3 km altitude (however we should note that these values cold vary due to vehicle’s shape). We are convinced that this g-load 5.5 g will not make any serious problems since it will be tolerable for the trained jumper; we know that the candidates for spaceflight should withstand much more g-loads that occur at descent. Generally during lift-off the astronauts have to bear not more than 3g's but this lasts several minutes until the spacecraft reaches the orbit. In our case it will last much shorter and after all such extreme kind of sport as parachuting (especially space-parachuting) is for well-trained persons only. As for high temperature (540° by Celsius) it will definitely occur at such jump and needs to be solved since usually the spacesuits are not designed to withstand high temperatures. Generally, both g-load and temperature could be somehow controlled by means of falling in a vertical or horizontal position. In other words the sky diver can fall in vertical position-with legs directed downwards and hence the head directed upwards or horizontally. The sky divers generally do like this-control their velocity when falling down by means of attitude control. However these measurements can not completely solve the problem-the high temperature will be definitely occurred during such cosmic parachuting. We think that this problem can be solved by means of designing, manufacturing and using the heat-proof spacesuit meeting extreme requirements-it should withstand cosmic freeze and quite high temperature (540 ° by Celsius or a bit more) during cosmic parachuting. Simultaneously it must be quite elastic since the jumper will need to move his legs, hands and fingers more than astronaut generally needs during spaceflight. Besides, the spacesuit should be covered with additional outer layer that will protect the jumper from the heat generated due to atmospheric friction. Generally apparently this is not very difficult problem since the temperature is not very high and the fall will last only several minutes. Besides, if after the cosmic parachuting the splashdown is occurred in ocean it would cool the spacesuit and the problem would be finally solved. Perhaps it will be found out that it is possible to use the already-existing spacesuits covered with that additional outer layer meeting all necessary requirements. As for the parachutes, they also should meet the specific requirements, actually two: they must be kept hermetically inside the spacesuit, besides the parachute should be quite large since the altitude at such jump is much more than in case of ordinary jump, in other words the velocity of falling will be more, hence large parachute will be needed for braking and the weight of the jumper is also more due to spacesuit. One very specific problem may arise during such parachuting: there is possibility that jumper to begin spinning just after jump and this is undesirable since such spin may prevent the parachute to deploy if spinning is not stopped. Besides, continuous spin may cause sickness. Generally spinning may be stopped by means of dense atmospheric layers but at 100 km altitude there is no air and such somersault will prevent of getting the whole pleasure from such jump. Therefore, the jumper should be very careful in the beginning of jump; or he should have some device to stop spinning, for example some kind of gas pistol (like the one that sometimes is used during Extra Vehicular Activity) that will be fired against the spin direction and thus the spin will be mainly stopped. Of course, after entering the dense atmospheric layers there will be no problems, therefore this measurement is for the upper layers only. To protect the cosmic jumper from high temperature we can apply to other measurement, perhaps quite unusual. The jumper may use some kind of heat-proof shield that he will hold in his hands during falling down, the shield that will be directed downwards and will counteract the air. The parachutist during falling down should be very careful-the shield MUST be directed exactly downwards to avoid harmful influence of hot air. Also, it is better if the shield is transparent since the jumper will be able to see the Earth and the whole falling process below. After braking to the safe velocity and altitude where the spacesuit will not be heated the jumper may simply throw the shield away and continue falling down with spacesuit only. The shield itself may have flat or a bit curved surface, but it must cover the whole area of the spacesuit. We think that it is quite easy to choose the material for such shield and probably such approach for solving this problem would be justified. As for the weight of the shield it will not make any problem since both shield and jumper will be mainly in the state of weightlessness during falling down and the jumper will have to control his attitude only. Finally, we can conclude that designing such heat-proof shield will pave the way to the successful cosmic jump. As for the spacesuit itself it could be the same as used by astronauts and no special additional outer layer will be needed. Taking into consideration all above-mentioned factors we can easily design such protective shield and execute very attractive and exciting kind of sport activity-jump from space. We think that designing such shield and thus accomplishing the jump from space will be apparently much easier than designing heat-proof spacesuit with its additional layer that should be thin enough (for thick layer the spacesuit would not be elastic); however we should not reject any of them and only the practice will show us which method is more suitable for accomplishing such an attractive kind of deed as jump from space. Now, a bit more about the protective shield itself. What kind of shape should it have? To our mind the hemisphere shape will the most suitable since it has got the simplest aerodynamic form, it will be easy for the jumper being inside to control his attitude-as we know the jumper must be always inside the protective shield, and if the shield is much heavier than jumper (this is desired) it will always be under the jumper during falling down, and this is what we need. For guarantying precise and good descent the size of the shield should be a bit more than size of the jumper itself. In such case the shield would completely hold the jumper inside it. Apparently, the system shield-human after entering the dense atmospheric layers will be stable system and its heavier part-the shield will be always under the human and its simple shape-the hemisphere will sustain this situation. Also, we think that the shield should have several little winglets around it, they will act as stabilizer when the shield enters the atmosphere. This measurement will enable the system shield-human to fall in vertical position and not to somersault in air. This means that the extreme attention will be needed just in the beginning when the jumper still falls in vacuum since it is absolutely necessary shield-human to enter the atmosphere vertically-shield directed downwards. Will the protective shield be reusable or expendable? Well it depends at what speed it will fall into the ocean at splashdown. As written above, at certain altitude the jumper will simply throw the shield away and continue its falling with spacesuit only. The shield will continue falling down until colliding with water surface where it will be severely damaged (actually this also depends on the angles of collision. For instance if the shield collides with water from lateral side apparently the damage will be less) and will not be able to be used again, however if it is equipped with its own parachute or retrorockets it would be possible to be used again. But if it is turned out that parachuting with hemisphere shield is still very risky action due to problem with sustaining stability system shield-human then we will have to execute jump from space with complete sphere-shape shield. In such case the shield will have the shape of the ordinary sphere with hollowness inside where the jumper will be placed and it will be opened by the jumper from inside. Under such approach there will be no need of the gas pistol, we will not need to care about shield-human system stability and etc. The shield should be made of transparent material because the jumper will need to see the Earth. The falling process will be a bit simpler than in previous case: after separating from the suborbital spacecraft the sphere-shape shield and jumper inside may spin and it will not be possible to stop this rotation. At the certain altitude the jumper will open the shield and will continue falling down as in previous case. As we see the jump from space is possible to execute in three different ways and the third one is the most comfortable and acceptable since it is the safest. However, to accept this third way as the best one for executing jumping from space, one formal circumstance makes a problem. Why do we need to jump from space? The answer is clear-for setting new world record, for executing new kind of sport activity and not for descending from high altitudes itself since it has been executed from 1961 many times. Let’s think about it-what would be the difference between descending from suborbital altitude with spacecraft and with above mentioned sphere-shaped shield? We can state that there would be no difference since in both cases the jumper/astronaut will wear spacesuit and besides in addition he will be placed in the medium completely covering him and protecting from high temperature. If we do not distinguish the sphere-shaped shield from the spacecraft on the grounds that both of them are the medium where the jumper/astronaut is placed hermetically and covering him completely than we should admit that jumping with sphere-shaped shield will be almost the same as descending with spacecraft and this has got nothing to do with parachuting at all. Still, which circumstance should we regard as essential difference between descending from suborbital altitude with spacecraft and with parachute? I think that following two: 1. During descent the jumper should NOT be covered with something (except spacesuit of course) completely and hermetically or else it would be descending inside the spacecraft and it would not be parachuting. 2. During the descent the jumper should control the attitude with his body, legs, hands and fingers in order this process to be similar to an ordinary parachuting. Otherwise, it would be descending with ordinary spacecraft. Therefore, based on the above written we think that the best option for jumping from space would be second one, jumping with hemisphere shield since exactly this enable the jumper to reveal his dexterity and courage during falling down and hence exactly this will be regarded as the most extreme and attractive kind of parachuting. Now, how such jump can be accomplished in practice? Which rocket/spacecraft should be used for this purpose? Of course it is doubtful that any vehicle will be designed for this sport, hence we will have to use the ones that have been already designed for sub-orbital spaceflights, particularly the SpaceShipTwo, and this spacecraft designed for space tourist could be used for space parachuting also; its size and capabilities will enable such jump: the length is equal to 18.29 m and crew cabin is 3.66 m long [3] and this means that the protective shield with jumper inside will be able to attached to bottom part of that vehicle. After separating from its mother ship, White Knight Two the SpaceShipTwo will carry the shield and when it reaches maximum altitude 110 km will release the system shield-human that will descend as described above. 1.http://www.spacefuture.com/archive/flight_mechanics_of_manned_suborbital_reusable_launch_vehicles_with_recommendations_for_launch_and_recovery.shtml 2. http://mae.ucdavis.edu/faculty/sarigul/AIAA_2003_0909_revised_Sep03.pdf 3. http://en.wikipedia.org/wiki/Spaceshiptwo Quote Share this post Link to post Share on other sites
piisfish 140 #2 May 10, 2011 still a couple of people with interesting projects in that regard, in order of ancianity of the project : -Michel "still trying" Fournier -Felix "if I do it I'll get sued" Baumgartner plus new projects like : -Olav "tropospheric dolphin" Zipserscissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
Eagle9 0 #3 May 10, 2011 Where is it possible to find their ideas/projects? Where did they express them? In journals? Quote Share this post Link to post Share on other sites
IanHarrop 43 #4 May 10, 2011 Quote Where is it possible to find their ideas/projects? Where did they express them? In journals? there is this thing called Google... you can use it to search the names. There is lots of info available."Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
Eagle9 0 #5 May 10, 2011 I will try By the way, could yup please tell me how it is possible to post an image here? I created them to show how the jumper may execute cosmic jump Quote Share this post Link to post Share on other sites
piisfish 140 #6 May 10, 2011 www.legrandsaut.org for michel fournier www.redbullstratos.com for Felix www.1olav.com/en/olav-zipser/for Olav, but the site is not actual. He was looking for interested people to organize such jump scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
IanHarrop 43 #7 May 10, 2011 Quote I will try By the way, could yup please tell me how it is possible to post an image here? I created them to show how the jumper may execute cosmic jump When posting look for something that says Attachment with a button that says Choose File and another button that says Upload File. HINT- look just above the button you have found that says Post Reply. To be blunt if you couldn't figure that out by yourself it makes me wonder about you even more. "Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
Eagle9 0 #8 May 10, 2011 Quote Quote I will try By the way, could yup please tell me how it is possible to post an image here? I created them to show how the jumper may execute cosmic jump When posting look for something that says Attachment with a button that says Choose File and another button that says Upload File. HINT- look just above the button you have found that says Post Reply. To be blunt if you couldn't figure that out by yourself it makes me wonder about you even more. I tried to upload the image HERE (I mean "Browse" and then "Upload attachment") but it failed for some reason, then I uploaded image at this web-site http://tinypic.com/ but when I pasted the code here no image was shown. So, here it is one image as I imagine this jump Quote Share this post Link to post Share on other sites
Eagle9 0 #9 May 10, 2011 I will take a look at these web-sites thoroughly Quote Share this post Link to post Share on other sites
davelepka 4 #10 May 10, 2011 Jump from space? At this point I'd rather jump off a building sans base rig. How about you buck up and make a skydive before trying to figure out how to do it from space? it would go a long way with your credibility here, and probably wake you from the delusional sleep you're obviously trapped in. Let's consider that Joe Kittenger, who currently holds the record, had the backing of the US govt during the days of unlimited spending known as the 'space race', when he made his jump. Let's also consdier that others with far more expereince and education than you have spent year and millions (literally) of dollars persuing this dream, and have yet to succeed. How about you make one jump, from something far short of space, and then get back to us? Quote Share this post Link to post Share on other sites
piisfish 140 #11 May 10, 2011 Dave, Dave, Dave, don't kill the newbies so fast. We had Giselle in the wingsuit forum, and now Eagle in the spacejump forum... Provides lots of entertainment, and be indulgent with him, he might be one of the first newbies not to post the Lutz video or the crocodile swoop pond picture scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
davelepka 4 #12 May 10, 2011 QuoteWe had Giselle in the wingsuit forum We should hook her up with this Eagle guy, it would be a match made in pretend heaven. They could get married, and talk for hours about having octopus babies and building their dream house on the sun. Quote Share this post Link to post Share on other sites
sundevil777 102 #13 May 10, 2011 Quote• Treejumping What is Treejumping?People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
piisfish 140 #14 May 10, 2011 Quote Quote • Treejumping What is Treejumping? a part of BASTE jumping scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
IanHarrop 43 #15 May 10, 2011 Quote Quote • Treejumping What is Treejumping? Take your pick of two choices: http://en.wikipedia.org/wiki/Treejumping http://www.youtube.com/watch?v=bhbNlrGjUY0"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
billvon 3,121 #16 May 10, 2011 >-it should withstand cosmic freeze . . . I hate that cosmic freeze. Like an ice cream headache but, you know, universe-wide. Quote Share this post Link to post Share on other sites
pyrotech 0 #17 May 10, 2011 Hey, let him do his research Dave! I wanna jump from the space! Quote Share this post Link to post Share on other sites
jackwallace 3 #18 May 11, 2011 Hey you left out low pull contests. A lot more marketable and spectator friendly. Jumping into stadiums. The woffos could sit there drinking beer and watch people open right in front of them. Could hold it in Nevada and bet on it.U only make 2 jumps: the first one for some weird reason and the last one that you lived through. The rest are just filler. scr 316 Quote Share this post Link to post Share on other sites
pchapman 280 #19 May 11, 2011 Although your post was on the wordy side, I did find the links to the AIAA flight mechanics paper to be useful. That's a nice summary of rocket energy balances and factors in flying suborbital. Some of the ideas in your post are similar to those for the bailout from orbit scenarios examined by the MOOSE project and similar ones back in the 60s. Quite a fun bunch of engineering studies. (e.g., http://www.astronautix.com/fam/rescue.htm) Quote Share this post Link to post Share on other sites
jrmrangers 0 #20 May 11, 2011 The upside of his plan is that since it's a Virgin based flight to altitude they will probably have complimentary Mamosa's and snacks. Wait , I pull what first? Quote Share this post Link to post Share on other sites
Eagle9 0 #21 May 12, 2011 Quote We had Giselle in the wingsuit forum Who is she? Does she have similar ideas as I do? davelepka Quote How about you buck up and make a skydive before trying to figure out how to do it from space? Quote How about you make one jump, from something far short of space, and then get back to us? Why not…….when I do it I will share my opinions with you. But I do not think that this will somehow affect my idea….. billvon Quote I hate that cosmic freeze Have you ever tried it? pchapman Quote Although your post was on the wordy side, I did find the links to the AIAA flight mechanics paper to be useful. That's a nice summary of rocket energy balances and factors in flying suborbital. Could you please post the link here? I would read it Quote Some of the ideas in your post are similar to those for the bailout from orbit scenarios examined by the MOOSE project and similar ones back in the 60s. Quite a fun bunch of engineering studies. (e.g., http://www.astronautix.com/fam/rescue.htm) I would try it with pleasure: A quick boost to orbit, a few photo opportunities, then the challenging retrofire and that long free fall or paraglide back to the earth.... Quote Share this post Link to post Share on other sites
JohnRich 4 #22 May 12, 2011 Quote So, here it is one image as I imagine this jump Attachments: Descend.JPG (286 KB) How are you going to get that big-ass shield out of the space plane for exit? Does the space plane have a tailgate? Is there a compartment that the jumper can enter and then depressurize for the exit? Quote Share this post Link to post Share on other sites
pchapman 280 #23 May 13, 2011 Quote pchapman Quote I did find the links to the AIAA flight mechanics paper to be useful. That's a nice summary of rocket energy balances and factors in flying suborbital. Could you please post the link here? I would read it I just meant the AIAA paper that is your citation #2 (and shows up I think in html form as citation #1). Quote Share this post Link to post Share on other sites
Eagle9 0 #24 May 24, 2011 Quote Quote So, here it is one image as I imagine this jump Attachments: Descend.JPG (286 KB) How are you going to get that big-ass shield out of the space plane for exit? Does the space plane have a tailgate? Is there a compartment that the jumper can enter and then depressurize for the exit? Of course the SpaceShipTwo has got no compartment for this purpose because this spacecraft is created for suborbital flights and not for space jumps. As I imagine the jumper should be attached (with that shield of course) from below to the SpaceShipTwo during the whole flight. Also, the White Knight Two should reach the 15.2 m km altitude (where the SpaceShipTwo releases) much faster than it usually it supposed to happen (as far as I remember it takes approximately 2 hours for White Knight to get this altitude), otherwise the jumper will have no Oxygen in spacesuit….. pchapman Quote I just meant the AIAA paper that is your citation #2 (and shows up I think in html form as citation #1). Yes, it provides really useful information Quote Share this post Link to post Share on other sites
Eagle9 0 #25 July 25, 2011 People, I revised my paper for the case when the parachutist jumps from the Space Elevator’s cabin, you can see this revised version here: http://spaceelevatorwiki.com/wiki/index.php/OpenSpace_4 Quote Share this post Link to post Share on other sites
