bdurham 0 #1 January 11, 2012 Should I have my alti-2 altimeter checked to make sure its reading the right altitude during descent? Can i jump looking at someone else altimeter to check it myself? How can i make sure my altimeter is reading and working correctly? Quote Share this post Link to post Share on other sites
skydivecat 3 #2 January 11, 2012 When i got my new altis off of here, I asked one of the TI's at my DZ to jump with them a few times along with their normal alti to verify for me before I jumped with them. The TI didn't mind at all and did 3 tandems with it on and said it looked good to him. I don't know if that was really necessary, but it made me feel better! Quote Share this post Link to post Share on other sites
mrubin 0 #3 January 11, 2012 I just got a new altimeter and periodically checked it against my friend's on the way to altitude. Every time I checked they matched so I called it good."I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery Quote Share this post Link to post Share on other sites
popsjumper 2 #4 January 11, 2012 You can always give to someone who has the equipment and the skill to check it in a test chamber. Mike Gruwell at Chutingstar can do that.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
PiLFy 3 #5 January 11, 2012 I'll leave Audibles out of this. If you don't trust your new Alti. You can borrow a second one from your DZ's student supply. Wear one on each wrist for a few jumps. Quote Share this post Link to post Share on other sites
kallend 2,219 #6 January 11, 2012 The jump plane's altimeter is likely to be accurate (it has to be tested periodically if the plane is flown IFR). So just compare your reading with the plane's, and correct for the altitude of the airport as necessary.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
riggerrob 644 #7 January 11, 2012 QuoteYou can always give to someone who has the equipment and the skill to check it in a test chamber. Mike Gruwell at Chutingstar can do that. .......................................................................... Yes, use a test chamber designed for testing old-style FXC 12000 Automatic Activation Devices. Just phone around to find out which DZ still uses FXC 12000s on their student gear. When I worked at Pitt Meadows, once a year, I used to run all their students altimeters through the test chamber, just to confirm that they were still accurate. Quote Share this post Link to post Share on other sites
