sgt_ludy 0
QuoteQuotethe techno reserve has max. exit weight 100kg
Your profile states you have a Tempo reserve. The 150 Tempo, closest to what you have listed, has a max. Suspended weight of 165 lb.
You are right about the Techno reserve, it has a weight range of 60 kg. (132 lb.) to 100 kg. (220 lb.) max suspended weight for the 155 size. That makes it only about 10 pounds over.
Sparky
yep. made a mistake in my profile. i do have a TECHNO 155.
So are you going to have that surgery?
sgt_ludy 0
QuoteMaybe "holy fuck it happened and I'm lucky my dumb ass is still alive and I can walk."
well, that´s exactly how i feel!
QuoteBut apparently you were just sitting back waiting for the day to come..,
i think i used the wrong words. i surely wasn´t sitting back and waiting. if i had been, i know could say "it happened". instead i was actively pulling my left front riser knowing what the results could be. it didn´t happen to me, i DID it.
sgt_ludy 0
QuoteSo are you going to have that surgery?
just called the hospital, and the dr. told me that they would strongly recommend it. right now i´m trying to get at least another opinion, and the name of a good surgeon.
Squeak 17
QuoteJust curious but, how long were you doing 90's before going to 180's? Do you think you would've had this problem if you were doing a 90 instead of a 180?
This is where my thinking is, I have heard it recomended by MANY experience HP pilots that a couple of hundred 90 degree turns are recomended before progressing to 120 degree turns and so on,
300 jumps and pulling 180s, well glad you're not dead
My Life ROCKS!
How's yours doing?
My Life ROCKS!
How's yours doing?
mr2mk1g 10
Quotei had something between 20 to 25 jumps on which i really focused on 90° before switching to 180.
Looking back now while pumped up on pain killers do you think in hindsight 20-25 jumps was enough?
There's a good lesson there for everyone; thanks for posting it and swift recovery.
BETO74 0
http://web.mac.com/ac057a/iWeb/AC057A/H0M3.html
In my limited experience opinion, I would suggest double fronts first. Then 45's, 90's, 180's and so on.
And when first attempting 180's etc. you should be planing out with enough altitude to maybe even need a little double fronts to keep the speed induced by your turn up for your landing. Then bring it a little lower very slowly untill you have it mastered.
In matters of style, swim with the current; in matters of principle, stand like a rock. ~ Thomas Jefferson
As if it was inevitable. As if "hooking it in" after one year in the sport is long enough to say "finally." I'd expect that sort of comment from someone with thousands of high speed landings who finally misjudged one by a few feet. Or maybe an AFF student that "finally" stood up a landing. It's all relative... but breaking your back after ANY amount of jumping shouldn't be a "finally," especially after just a year or less. If I ever twist an ankle on landing, I'll say "it finally happend." I'd think a little differently about a broken back though. Maybe "holy fuck it happened and I'm lucky my dumb ass is still alive and I can walk."
Stupid low turns don't just happen. People read about them and think they know better, as if they are different from the last guy to fuck himself up. But apparently you were just sitting back waiting for the day to come...
Dave
