ctremie 0 #1 November 30, 2012 Just started packing my own main canopy, it is a silhouette 230, I PRO pack it as taught, very simular to the PD Nick Grillet's pro pack a large canopy video. but on opening it tends to surge forward, or dive on opening, afer it gets completely open, and only dives for about 3 seconds then levels out. Is this something I am doing wrong in the pack job, I do set the brakes, any help would be appreciated, thanks Quote Share this post Link to post Share on other sites
likestojump 3 #2 November 30, 2012 I am betting that your deployment brakes are too deep and you are opening in a stall. Quote Share this post Link to post Share on other sites
ctremie 0 #3 November 30, 2012 Thanks for the insight, How can I check that my deployment brakes or deep or not deep? Also for more info on this, I took a canopy course last week, the dz packers packed it for that day and I didn't have the surge. During the course, to stall my canopy on the toggles, I had to single wrap my brakelines while flaring. Quote Share this post Link to post Share on other sites
PiLFy 3 #4 November 30, 2012 Quote Thanks for the insight, How can I check that my deployment brakes or deep or not deep? Also for more info on this, I took a canopy course last week, the dz packers packed it for that day and I didn't have the surge. During the course, to stall my canopy on the toggles, I had to single wrap my brakelines while flaring. Bring one of those Packers a case of beer on a slow weekday. They know something you don't. Are you quartering your Slider properly? My Sabre2 was doing some diving on opening. I was advised to try quartering as usual. Then, pull the Slider towards the nose a couple inches. It works like a charm . Get w/a rigger or packer, & get it sorted out. Quote Share this post Link to post Share on other sites
djmarvin 2 #5 November 30, 2012 Rory can check the trim for you in the loft. Next time you see me at the DZ hit me up and I'll see what I can do to help as well. DJ Marvin AFF I/E, Coach/E, USPA/UPT Tandem I/E http://www.theratingscenter.com Quote Share this post Link to post Share on other sites
DJL 235 #6 November 30, 2012 QuoteGet w/a rigger or packer, & get it sorted out. Yeah, same thing."I encourage all awesome dangerous behavior." - Jeffro Fincher Quote Share this post Link to post Share on other sites
PiLFy 3 #7 December 1, 2012 QuoteQuoteGet w/a rigger or packer, & get it sorted out. Yeah, same thing. I didn't say they were... Quote Share this post Link to post Share on other sites
ElectricFetus 0 #8 December 9, 2012 total noob question here so go easy on me....if it surges or dives, but stabilizes quickly, what is the harm? is it a question of overall stability of the jumper, or is it the potential of loss of control of the canopy? Quote Share this post Link to post Share on other sites
PiLFy 3 #9 December 9, 2012 Potential Canopy collisions on opening. Other Jumpers sometimes end up way too close when you open. If you're thrown out of control when that happens? Bang... Plus, at higher wingloadings, it could throw you into line twists. Quote Share this post Link to post Share on other sites
pchapman 280 #10 December 9, 2012 Quoteif it surges or dives, but stabilizes quickly, what is the harm? Good point. It all depends on what kind of "surge" we are talking about. All canopies pick up forward speed at the end of the opening sequence so how much more is a short duration surge adding? Who cares if a bigger canopy surges when you'd be moving much faster with a sub 100 crossbraced canopy anyway? If it is the type of surge forward that happens after a stall, then the canopy doesn't have much forward speed to begin with, so it is safe in that way. But since stall behaviour can be more unpredictable and unpleasant the smaller the canopy, you don't want even minor stalling on opening. [Experienced jumpers: Yeah Sigma reserves are interesting...] While a surge on its own may not be an issue, controlability is. If the forward dive is sudden enough, it may unload the lines a bit and especially if one is bouncing around a little at the end of opening, or not perfectly symmetrical, or the canopy is hunting in direction during the opening, loss of some line tension could allow one's body to twist enough to twist up under the canopy. So it is all a matter of degree. Every canopy varies in how much distance it takes to open and then picks up forward speed, but if a surge is enough to reduce line tension significantly then it could become a problem. Quote Share this post Link to post Share on other sites
