mrpilotman 0 #1 December 8, 2012 Can you use an exerimental aircraft for a jump ship? Quote Share this post Link to post Share on other sites
airtwardo 7 #2 December 8, 2012 Quote Can you use an exerimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
oldwomanc6 65 #3 December 8, 2012 Quote Quote Can you use an exerimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. All donations are gratefully accepted! lisa WSCR 594 FB 1023 CBDB 9 Quote Share this post Link to post Share on other sites
oldwomanc6 65 #4 December 8, 2012 You won't be catching me jumping out of a push-pull, though! lisa WSCR 594 FB 1023 CBDB 9 Quote Share this post Link to post Share on other sites
ZigZagMarquis 9 #5 December 8, 2012 Quote Quote Quote Can you use an exerimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. All donations are gratefully accepted! And extra altitude can be obtained in the typical manner! Quote Share this post Link to post Share on other sites
michaelmullins 81 #6 December 8, 2012 Quote Quote Can you use an exerimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. In the US, you cannot jump out of an Experimental aircraft, period. Mike Mullins Quote Share this post Link to post Share on other sites
kallend 2,216 #7 December 8, 2012 Quote Quote Quote Can you use an exerimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. In the US, you cannot jump out of an Experimental aircraft, period. Mike Mullins Even if it's on fire?... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
quade 4 #8 December 8, 2012 Quote Quote Quote Can you use an exerimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. In the US, you cannot jump out of an Experimental aircraft, period. Mike Mullins Can you cite the FAR on that?quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
airtwardo 7 #9 December 8, 2012 Quote Quote Quote Can you use an experimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. In the US, you cannot jump out of an Experimental aircraft, period. Mike Mullins Not even a An-2? How about an AirVan? Glider?? Pitts? Balloon? I've jumped from all those in the US and they were definitely placarded experimental. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
CSpenceFLY 1 #10 December 8, 2012 Quote Quote Quote Can you use an exerimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. In the US, you cannot jump out of an Experimental aircraft, period. Mike Mullins That's what I was thinking Mike but I was too lazy to look it up. I've been through the conversation more than once trying to get a Huey for the boogie. Most of them are flying either in Restricted or Experimental Cats. Quote Share this post Link to post Share on other sites
michaelmullins 81 #11 December 8, 2012 Quote Quote Quote Quote Can you use an experimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. In the US, you cannot jump out of an Experimental aircraft, period. Mike Mullins Not even a An-2? How about an AirVan? Glider?? Pitts? Balloon? I've jumped from all those in the US and they were definitely placarded experimental. Unless you sacrificed the Pitts when you jumped it, it was a 2 place Pitts, either an S2A, S2B, or S2C, all certified aircraft. I do not know of any Experimental 2-place gliders, there may be some. Likewise for ballons, most all are certified aircraft. The AirVan is a certified aircraft. The AN-2 was used at the Freefall Convention for a short time one year, it left abruptly when the FAA began to question it. Some AN-2, and other aircraft, are in the "Restricted" category. Aircraft in this category are restricted to the limitations the FAA places on it at the time. The restriction could include intentional parachute jumping. The AirVan is a certified aircraft. An interesting fact is the last C130 used at the convention was in the Restricted category, the restriction did not specify skydiving. However, the restriction did allow aerial photography and each jumper signed a statement that they were using the aircraft for "aerial photography" and each jumper, technically, was carrying a camera. I do not doubt that many jumps are made from Experimental aircraft and just because it happens does not make it legal. I personally do not care how many jumps are made from Experimental Aircraft, I am just saying what the rules are. Mike Mullins Quote Share this post Link to post Share on other sites
michaelmullins 81 #12 December 8, 2012 Quote Quote Quote Quote Can you use an exerimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. In the US, you cannot jump out of an Experimental aircraft, period. Mike Mullins Even if it's on fire? Correct, you must go down with the aircraft. Quote Share this post Link to post Share on other sites
airtwardo 7 #13 December 8, 2012 It was a two place Pitts but I remember seeing an experimental placard riveted in the cockpit The air-van I jumped was experimental, it was serial 1 or 2, it was at Oshkosh and not US certified at the time. The glider was a two place home-built, also placarded exp. I jumped a Wilga not certified in the US at the time, it too was placarded exp. I jumped the 1st Bassler DC3 turbine conversion a week after it was finished...placarded exp. at the time. WERE these aircraft actually exp. by the legal definition? ...i dunno, they WERE identified as such. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
michaelmullins 81 #14 December 8, 2012 Quote Quote Quote Quote Can you use an exerimental aircraft for a jump ship? Experimental aircraft can't be used for hire...read into that what you will. In the US, you cannot jump out of an Experimental aircraft, period. Mike Mullins Can you cite the FAR on that? § 91.319 Aircraft having experimental certificates: Operating limitations. (a) No person may operate an aircraft that has an experimental certificate— (1) For other than the purpose for which the certificate was issued; Each Experimental Aircraft has a certificate that lists the operating limitations. If the certificate does not list "intentional parachute jumping" then you cannot do it. Plus, every certificate I have seen specifically prohibits intentional parachute jumping. There may be some that don't, I just have not seen them. At any rate, it must be operated for the purpose for which the certificate was issued. Mike Mullins Quote Share this post Link to post Share on other sites
michaelmullins 81 #15 December 8, 2012 QuoteIt was a two place Pitts but I remember seeing an experimental placard riveted in the cockpit The air-van I jumped was experimental, it was serial 1 or 2, it was at Oshkosh and not US certified at the time. The glider was a two place home-built, also placarded exp. I jumped a Wilga not certified in the US at the time, it too was placarded exp. I jumped the 1st Bassler DC3 turbine conversion a week after it was finished...placarded exp. at the time. WERE these aircraft actually exp. by the legal definition? ...i dunno, they WERE identified as such. Not saying you did not jump them, just saying it was not legal. Mike Quote Share this post Link to post Share on other sites
airtwardo 7 #16 December 8, 2012 QuoteQuoteIt was a two place Pitts but I remember seeing an experimental placard riveted in the cockpit The air-van I jumped was experimental, it was serial 1 or 2, it was at Oshkosh and not US certified at the time. The glider was a two place home-built, also placarded exp. I jumped a Wilga not certified in the US at the time, it too was placarded exp. I jumped the 1st Bassler DC3 turbine conversion a week after it was finished...placarded exp. at the time. WERE these aircraft actually exp. by the legal definition? ...i dunno, they WERE identified as such. Not saying you did not jump them, just saying it was not legal. Mike Well...the air van and DC3 had 1/2 a dozen feds crawling all over the paperwork, so I would imagine it was legal. Both the jumpers & pilots had to sign that we were not being financially compensated... ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
michaelmullins 81 #17 December 8, 2012 QuoteQuoteQuoteIt was a two place Pitts but I remember seeing an experimental placard riveted in the cockpit The air-van I jumped was experimental, it was serial 1 or 2, it was at Oshkosh and not US certified at the time. The glider was a two place home-built, also placarded exp. I jumped a Wilga not certified in the US at the time, it too was placarded exp. I jumped the 1st Bassler DC3 turbine conversion a week after it was finished...placarded exp. at the time. WERE these aircraft actually exp. by the legal definition? ...i dunno, they WERE identified as such. Not saying you did not jump them, just saying it was not legal. Mike Well...the air van and DC3 had 1/2 a dozen feds crawling all over the paperwork, so I would imagine it was legal. Both the jumpers & pilots had to sign that we were not being financially compensated... The Feds can approve anything they wish. As the AirVan was in a non-standard category waiting to become a Certified aircraft and the DC-3 was in a non-standard category due to the Turbine conversion and was waiting to be re-certified, I can see where a Fed may approve a one time jump or series of jump for the purpose of allowing it to demonstrate that it would be capable of parachute jumping when the standard certificate is issued/re-issued. Basically, they made a provision in the operating limitations to allow it. I doubt that they would ever approve an aircraft that is not on the way to certification. As I posted elsewhere in this thread: § 91.319 Aircraft having experimental certificates: Operating limitations. (a) No person may operate an aircraft that has an experimental certificate— (1) For other than the purpose for which the certificate was issued; Each Experimental Aircraft has a certificate that lists the operating limitations. If the certificate does not list "intentional parachute jumping" then you cannot do it. Plus, every certificate I have seen specifically prohibits intentional parachute jumping. There may be some that don't, I just have not seen them. At any rate, it must be operated for the purpose for which the certificate was issued. Mike Mullins Quote Share this post Link to post Share on other sites
airtwardo 7 #18 December 8, 2012 I doubt that they would ever approve an aircraft that is not on the way to certification. Quote Gotcha...it's not a 'long term OK'. I can see that. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites jclalor 12 #19 December 8, 2012 QuoteThat's what I was thinking Mike but I was too lazy to look it up. I've been through the conversation more than once trying to get a Huey for the boogie. Most of them are flying either in Restricted or Experimental Cats. I made my first jump out of a Huey, I would pay highly to jump one again. Quote Share this post Link to post Share on other sites
skyjumpenfool 2 #20 December 8, 2012 Quote Can you use an exerimental aircraft for a jump ship? You can, and, I have. Birdshit & Fools Productions "Son, only two things fall from the sky." Quote Share this post Link to post Share on other sites
JohnMitchell 16 #21 December 9, 2012 Quote Well...the air van and DC3 had 1/2 a dozen feds crawling all over the paperwork, so I would imagine it was legal. Wouldn't be the first time a bunch of feds got it wrong, mis-interpretted a rule or forgot another one. . . Just sayin' Quote Share this post Link to post Share on other sites
airtwardo 7 #22 December 9, 2012 Quote Quote Well...the air van and DC3 had 1/2 a dozen feds crawling all over the paperwork, so I would imagine it was legal. Wouldn't be the first time a bunch of feds got it wrong, mis-interpretted a rule or forgot another one. . . Just sayin' Yeah but is does tend to cover the jumpers butt when the 'powers that be' say sure go for it! ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
JohnMitchell 16 #23 December 9, 2012 Quote Yeah but is does tend to cover the jumpers butt when the 'powers that be' say sure go for it! No argument there. Quote Share this post Link to post Share on other sites
MikeJD 0 #24 December 10, 2012 My early student jumps were all made from an experimental Cessna 182. As I recall they were using it to trial duct tape as a substitute for aluminium. Quote Share this post Link to post Share on other sites
skycatcher68 7 #25 December 12, 2012 There are different types of experimental aircraft. "Amateur-built" experimental aircraft are specifically prohibited from intentional parachute jumping by FAA Order 8130.2G - Experimental Amateur-Built Operating Limitations. Quote(19) This aircraft must not be used for banner towing operations or intentional parachute jumping.What if the Bible had been written by Stephen King? Quote Share this post Link to post Share on other sites
