BigMikeH77 0 #1 January 3, 2013 Was just reviewing the SIM and am a little confused by this recommendation for remedying a side-by-side two canopies out situation; QuoteSide-by-side procedure 1: If both canopies are flying without interference or possibility of entanglement and altitude permits: (1) Disconnect the RSL. (2) Cut away the main and steer the reserve to a normal landing. My question is, how do you disconnect the RSL? Yes, I will of course talk to my instructors about this and other questions when I head to the DZ next weekend... I am just looking for insight. :-) Quote Share this post Link to post Share on other sites
IanHarrop 43 #2 January 3, 2013 see the buckle in this video... disconnect it by pulling on the tab http://www.youtube.com/watch?v=_ZbHg1QZZPs Probably good for you to read http://theblueskyranch.com/sta/tb21.htm this too http://www.dropzone.com/safety/Gear_and_Equipment/Top_5_RSL_myths_18.html"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
BigMikeH77 0 #3 January 4, 2013 Perfect... Thanks so much for the links. Quote Share this post Link to post Share on other sites
mr2mk1g 10 #4 January 4, 2013 Potentially your RSL on your student gear may have that quick release replaced with a maillon rapeade link. [edit - which unless you've got a wrench in your jumpsuit pocket you won't be able to undo] Talk to your instructors about what drills they want you to perform and when you qualify talk to people about how, if at all, your drills may change as your gear changes (if it does). Quote Share this post Link to post Share on other sites
t1mb0b 0 #5 January 4, 2013 Quotesee the buckle in this video... disconnect it by pulling on the tab http://www.youtube.com/watch?v=_ZbHg1QZZPs Probably good for you to read http://theblueskyranch.com/sta/tb21.htm this too http://www.dropzone.com/safety/Gear_and_Equipment/Top_5_RSL_myths_18.html Great info, thanks Ian! Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #6 January 4, 2013 There are actually two types of side-by-sides and each has very-different EP's: FIRST you must determine whether or not if the two canopies are entangled or not and disconnect your RSL If your canopies are NOT entangled, then you can steer the left-hand canopy away from the right hand canopy by the left-rear riser with your left hand and cutaway with your right hand. If you cannot determine whether or not your canopies are entangled, then you may choose to land both canopies in that configuration trying at all costs to keep both canopies from downplaning. If your canopies ARE entangled you CAN'T cutaway and must instead do everything in your power to keep both canopies above your head and prevent them from turning into a downplane. Cutting away an entangled main is not an option as it will almost certainly collapse your reserve canopy and you will then have two balls of crap over your head. An example of how you might have two out and have them entangled is deploying your main while tumbling and having your AAD fire your reserve PC through one side of your risers or through the lines as the canopy was deploying. Chuck Quote Share this post Link to post Share on other sites
ActionAir 0 #7 January 4, 2013 Pull your reserve ripcord. RSL is now disconnected.AAP Quote Share this post Link to post Share on other sites
monkycndo 0 #8 January 4, 2013 Chuck, there was a seminar at PIA 2011 that discussed two outs. It had a great and simple way to remember what you described. In times of stress, I like to follow KISS. If you have determined canopies are not entangled and after RSL is disconnected: LEFT on LEFT on LEFT Left hand on left rear riser of left canopy. Right hand on cut away handle. Pull on rear riser until canopies are completely separated. As you cut away the main, release rear riser with left hand. If the left canopy is the main, that riser will soon be pulled away from you. I learned a lot at that presentation that I hopefully will not need to put into practice. And as always, best to think about it on the ground before having to practice it in the air.50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
DocPop 1 #9 January 4, 2013 Quote LEFT on LEFT on LEFT Gold. Thank you."The ground does not care who you are. It will always be tougher than the human behind the controls." ~ CanuckInUSA Quote Share this post Link to post Share on other sites
popsjumper 2 #10 January 4, 2013 QuotePotentially your RSL on your student gear may have that quick release replaced with a maillon rapeade link. [edit - which unless you've got a wrench in your jumpsuit pocket you won't be able to undo] Really???? That is an accident looking for a place to happen. I would avoid ANY rig set up like that. For what logical purpose is that done? Where is a DZ that does that? QuoteTalk to your instructors about what drills they want you to perform and when you qualify talk to people about how, if at all, your drills may change as your gear changes (if it does). Ordinarily, I would agree with this somewhat. Only somewhat because you said, "...when you qualify talk to people about how". Why would you send a student off to talk to those otherm people about "how" to do something? Additionally, in light of your RSL mention above, it highlights the fact that there are many instructors out there proposing and teaching the wrong things..some of it total bullshit. I would suggest to the student to read the SIM first...it's a U.S. thing, and then talk to the I's with your questions. At least the student gets an eyeful of what is recommended as best practices from the USPA before the instructor twists his head around telling him to do something stupid....such as tie down the RSL with a hard link.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
popsjumper 2 #11 January 4, 2013 QuotePull your reserve ripcord. RSL is now disconnected. Think about that and re-do. Hint: Which would come first, disconnect RSL or pull reserve handle?My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
sundevil777 102 #12 January 4, 2013 QuotePull your reserve ripcord. RSL is now disconnected. It will only be disconnected from the ripcord cable, assuming something else allowed the reserve to open, like an AAD. There will still be some force needed to get the RSL lanyard pulled free from the channels routing it on the rig. If cutting away from a two-out, I'd rather not have a shackle on the riser to snag the reserve, so releasing the RSL shackle would be better.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
popsjumper 2 #13 January 5, 2013 Awww, man...I was hoping ActionAir would come up with that...plus he's only talking about it being disconnected on the useless end. My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
milehigheric 0 #14 January 5, 2013 FYI, my student gear had non removable RSL. Same goes for other student gear I have seen at different drop zones. I have no idea what the reasoning is behind it however. Sounds a bit crappy really, but I only learnt that RSL's can be disconnected after buying my own gear and sitting down with someone to explain it to me - I would guess alot of students would be the same. Quote Share this post Link to post Share on other sites
pchapman 280 #15 January 5, 2013 I've also seen non-removable RSLs on student gear. But it tended to be on older gear -- i.e., less likely to be seen on modern common brands. The idea was to avoid accidental disconnects, while at the same time one wasn't going to ask a static line student to start looking for a little tab in the rare event of a two out. I'm not advocating that method, just describing why it was done. Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #16 January 5, 2013 QuoteQuote LEFT on LEFT on LEFT Gold. Thank you. +1! I've never heard it stated that way and it DOES describe what I said to the T. Quote Share this post Link to post Share on other sites
mr2mk1g 10 #17 January 7, 2013 I'm not advocating the use of a rapeade link, just observing that there are rigs out there and DZ's out there that have them in place of a shackle for students. There's no use us lot giving the OP advice about releasing the RSL if he's using such a rig. He needs to speak with his instructors if that is the case. If online advice is followed for a gear configuration not suited to that advice, unpleasant things can happen. His instructors must have risk assessed their choice to use such a link and have decided on training to suit - if not, perhaps he needs to consider where he's jumping. Obviously you take the view that using a link in place of a shackle is already cause for that. I'm not taking issue with that. I'm not sending a student off - I said once qualified. Instructors are a great source of safety info for all but they are far from the only source of information. Training wheels have to come off at some point so that people can start learning to cut the wheat from the chafe. Student's must do as directed by their instructors. Qualified jumpers can and indeed must learn to make their own choices about their gear and emergency procedures based on what and how they are jumping. Quote Share this post Link to post Share on other sites
popsjumper 2 #18 January 7, 2013 Quote There's no use us lot giving the OP advice about releasing the RSL if he's using such a rig. He needs to speak with his instructors if that is the case. If online advice is followed for a gear configuration not suited to that advice, unpleasant things can happen. How right you are. Are arguing against the OP have the knowledge of the RSL and it;s function? Regardless, of the setup, he needs to know about RSL...he will be having one in the very near future. What concerns me is that students come here asking questions about things they should have already been taught. I'll not mention the apparent "experienced, but young" jumpers asking the same types of questions. I'm not one to hold back on info for the students.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
NvyZero 0 #19 January 8, 2013 Quote Quote What concerns me is that students come here asking questions about things they should have already been taught. I'll not mention the apparent "experienced, but young" jumpers asking the same types of questions. I'm not one to hold back on info for the students. Students are usually given the info they need for the jump. Also a lot of information is covered in the fjc and most of it is totally forgotten due to information overload! Also I think no one should ever give advice on these forums, were all assholes ! Im a YDJ but i have had access to amazing instructors, and people in general and for some reason im still alive! If your gonna take advice always pull high! Quote Share this post Link to post Share on other sites
mr2mk1g 10 #20 January 8, 2013 Quote Are arguing against the OP have the knowledge of the RSL and it;s function? I want aware I argued anything. I just gave the OP additional info no one else had that there may be a link in place of a shackle. Quote Share this post Link to post Share on other sites
BigMikeH77 0 #21 January 8, 2013 You know, I didn't post this to start an argument among the more experienced jumpers. I just had a simple question about the SIM. I even edited my original post with "Of course I'll be asking my instructor..." because I left that out at first - It SHOULD go without saying. I'm not here on the forum to learn how to skydive. I have a DZ and instructors for that. But there is a lot of valuable experience that can be shared from folks who have hundreds/thousands of jumps. REMEMBER, I'm new. I have a lot of questions and since I also have a job and kids, I'm not always available to go to the DZ whenever I want. MAYBE twice a month.. So I think these forums are a great place to ask questions. I respectfully request the arguing and nit picking over symantics to stop. You are doing me and the other lesser experienced jumpers and students a disservice. Now, if you have an opinion on the SIM or procedures for a side-by-side I'd love to hear them... And there have already been a couple of those posted. So thank you for those. Quote Share this post Link to post Share on other sites
popsjumper 2 #22 January 8, 2013 Does your gear have the RSL or the hard link? As far as the side discussion, unless you knew all that already, didn't you learn anything from it? If you did, then all is well and good, eh? Most often we "nitpick" for clarity...which is good thing for everyone. The funny part is that, most often, it turns out that the nitpickers are talking about the same thing. The two-out procedures in the SIM are golden. Those procedures were tested by the Golden Knights years ago and were deemed "best practices" and adopted by USPA. I'm always wary of "new" things being dreamed up and suggested for use. It's preferable to test those "new" things prior to use. On top of that, quite often those "new" things have already been thought of, and tested, and found to be wanting. IMHO, tying off the RSL with a hard link is one of those dreamed up things. My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
ChrisD 0 #23 January 8, 2013 QuoteFYI, my student gear had non removable RSL. Same goes for other student gear I have seen at different drop zones. I have no idea what the reasoning is behind it however. Sounds a bit crappy really, but I only learnt that RSL's can be disconnected after buying my own gear and sitting down with someone to explain it to me - I would guess alot of students would be the same. It does sound a bit crappy,... WE still want, in the event of an accidential pin bump, in the plane, to be able to remove the main to a safe condition, seat belt in the student, and ride the plane down with them. CBut what do I know, "I only have one tandem jump." Quote Share this post Link to post Share on other sites
popsjumper 2 #24 January 9, 2013 Quote....but I only learnt that RSL's can be disconnected after buying my own gear and sitting down with someone to explain it to me - I would guess alot of students would be the same. *sigh* ...and I had someone question why my faith was so lacking in AFFIs in general. I am VERY glad that you or someone caught that hole in your training before something weird happened.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
kuai43 7 #25 January 9, 2013 QuoteReally???? That is an accident looking for a place to happen. I would avoid ANY rig set up like that. For what logical purpose is that done? Where is a DZ that does that? I would suggest to the student to read the SIM first...it's a U.S. thing, and then talk to the I's with your questions. At least the student gets an eyeful of what is recommended as best practices from the USPA before the instructor twists his head around telling him to do something stupid....such as tie down the RSL with a hard link. Completely in agreement. Unless it's already been mentioned, EP's for water landings, roof landings, and in some cases, tree landings might require chopping the main without having to worry about the reserve being automatically deployed. No way would I ever jump with an un-detachable RSL.Every fight is a food fight if you're a cannibal Goodness is something to be chosen. When a man cannot choose, he ceases to be a man. - Anthony Burgess Quote Share this post Link to post Share on other sites
