Zep 0 #1 November 7, 2004 I'm curious to know, At the DZ you jump do they have a policy in the exit order IE:- Freeflyers first or Relative first I'm not including Tandems as this is often dictated by the aircraft the DZ is using and obiously wingsuit an surfers last If they do have a policy do you know why? edited to change subject Gone fishing Quote Share this post Link to post Share on other sites
BIGUN 1,521 #2 November 7, 2004 Cause John Kallend has quantifed the reason and it keeps folks alive.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
Zep 0 #3 November 7, 2004 I didn't ask what John Kelland had to say about it I asked which policy your DZ uses Gone fishing Quote Share this post Link to post Share on other sites
airdweller 0 #4 November 7, 2004 Generally it goes tandems at 10,500 then to altitude belly first Sit flyers next head down next jumpers opening up high wingsuits next cross country last------------------------------------------------------ "From the mightiest pharaoh to the lowliest peasant, who doesn't enjoy a good sit?" C. Montgomery Burns Quote Share this post Link to post Share on other sites
skyyhi 0 #5 November 7, 2004 Ours is belly groups first, freefly groups next, then solos then tandems. Skysurfers get out when the plane is over the DZ and clear of any houses, tandems are usually out last. birdmen get out before the tandems I think. . .though I am a belly flyer and NEVER leave late enough to know the answer to that one.________________________________________ Take risks not to escape life… but to prevent life from escaping. ~ A bumper sticker at the DZ FGF #6 Darcy Quote Share this post Link to post Share on other sites
crotalus01 0 #6 November 7, 2004 belly fliers largest group to smallest group, freeflyers largest group to smallest group, AFFs, Tandems. we (so far) havent had any birdmen or skysurfers on loads that i have been on.... As for me and my house, we will serve the LORD... Quote Share this post Link to post Share on other sites
BIGUN 1,521 #7 November 7, 2004 You asked... QuoteIf they do have a policy do you know why? Kallend has explained what the policy should be and why. That's what we use.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
LouDiamond 1 #8 November 7, 2004 Birdmen should go last unless your cross country is more than 6+ miles and not either a downwind or crosswind run. We recently proved in Eloy that even the smallest of suits can easily make it back 6 miles from the DZ on a constant basis when flown properly."It's just skydiving..additional drama is not required" Some people dream about flying, I live my dream SKYMONKEY PUBLISHING Quote Share this post Link to post Share on other sites
Zep 0 #9 November 7, 2004 QuoteYou asked... QuoteIf they do have a policy do you know why? Kallend has explained what the policy should be and why. That's what we use. Ok Mr bigway you seem obsessed with Mr Kellend If my name was Einstien an I told you the world was going to end 1/1/05 would you take it as gospel It may surprise you to know that there are some DZ’s that do not adopt this policy For reasons Geographical or metrological the DZ I use 90% of the time, Experienced freeflyers go out first. Now Mr Kellend and all his Physics tells us that this is wrong. I have no argument with Mr Kelland but If he could explain how a common or garden Bumble Bee can fly I would be more inclined to follow his theory. Physics isn’t everything At the Dz I mainly use On exit I use a combination of experience and judgement I have never had a problem with invading space of flat flyers, The only problems I’ve had is with the professional freeflyers who with their students insist on being the first out In part I understand as some times they are doing back-to-back an want to get down first. At the DZ’s I use that FF leave first, When I flare out at 5000ft I always barrel Roll and asses the situation ( I learnt along time ago not to trust a wave off) Also a student FF will very often when something goes wrong go flat instead of going into The ball position, so a barrel roll or a few seconds tracking on your back is to me important. Now the DZ I mainly use has a strict policy that FF must turn 90º right or left to flight line Oh an the other thing is that at this DZ if you have not had your FF card stamped you cannot do more than a two way, when I say card stamped I mean that you have proved to an instructor that you are capable of FF. Witch personally I think is the way to go So the original question was, Which policy does your DZ adopt And do you know why regardless of what Mr Kellend says Gone fishing Quote Share this post Link to post Share on other sites
Jib 0 #10 November 7, 2004 QuoteIf they do have a policy do you know why? The longer your fall (the slower fall rate), the futher back toward the dropzone (downwind) you are going to go. -------------------------------------------------- the depth of his depravity sickens me. -- Jerry Falwell, People v. Larry Flynt Quote Share this post Link to post Share on other sites
kallend 2,216 #11 November 7, 2004 QuoteQuoteYou asked... QuoteIf they do have a policy do you know why? Kallend has explained what the policy should be and why. That's what we use. Ok Mr bigway you seem obsessed with Mr Kellend If my name was Einstien an I told you the world was going to end 1/1/05 would you take it as gospel It may surprise you to know that there are some DZ’s that do not adopt this policy For reasons Geographical or metrological the DZ I use 90% of the time, Experienced freeflyers go out first. Now Mr Kellend and all his Physics tells us that this is wrong. I have no argument with Mr Kelland but If he could explain how a common or garden Bumble Bee can fly I would be more inclined to follow his theory. Physics isn’t everything At the Dz I mainly use On exit I use a combination of experience and judgement I have never had a problem with invading space of flat flyers, The only problems I’ve had is with the professional freeflyers who with their students insist on being the first out In part I understand as some times they are doing back-to-back an want to get down first. At the DZ’s I use that FF leave first, When I flare out at 5000ft I always barrel Roll and asses the situation ( I learnt along time ago not to trust a wave off) Also a student FF will very often when something goes wrong go flat instead of going into The ball position, so a barrel roll or a few seconds tracking on your back is to me important. Now the DZ I mainly use has a strict policy that FF must turn 90º right or left to flight line Oh an the other thing is that at this DZ if you have not had your FF card stamped you cannot do more than a two way, when I say card stamped I mean that you have proved to an instructor that you are capable of FF. Witch personally I think is the way to go So the original question was, Which policy does your DZ adopt And do you know why regardless of what Mr Kellend says My name is Kallend, not Kellend, and from what you write it is pretty obvious that you have not read what I wrote on this topic. And physics can explain the flight of bumble bees very well. Any claim to the contrary is simply ignorant.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
feuergnom 29 #12 November 7, 2004 hey dude - take a deep breath & relax ok? most of the dz's i have jumped use the large group belly then large group freeflyer etc just yesterday i had a discussion about exit orders and how they change when the uppers are really high, if pilots always have to drop against the wind or what it would be like if they dropped jumpers on a crosswind approach etc if you are allergic on the name kallend (thats how it's spelled) try the article by skratch garrison, he posts here under the name skr (if i remember correctely). quite interesting stuff edit to add: while i was typing kallend showed up -----› hence the double post The universal aptitude for ineptitude makes any human accomplishment an incredible miracle dudeist skydiver # 666 Quote Share this post Link to post Share on other sites
winsor 236 #13 November 7, 2004 QuoteQuoteYou asked... QuoteIf they do have a policy do you know why? Kallend has explained what the policy should be and why. That's what we use. Ok Mr bigway you seem obsessed with Mr Kellend That's DOCTOR or PROFESSOR Kallend. With an "a." QuoteIf my name was Einstien an I told you the world was going to end 1/1/05 would you take it as gospel It doesn't follow. If you do a brief search you will find a variety of sources, all of them quite legitiamate, whose analyses come to the same conclusions. John Kallend's presentation is among the best. if not THE best. Do your homework and get back to me. QuoteIt may surprise you to know that there are some DZ’s that do not adopt this policy Actually, it is anything but surprising. QuoteFor reasons Geographical or metrological the DZ I use 90% of the time, Experienced freeflyers go out first. Now Mr Kellend and all his Physics tells us that this is wrong. I have no argument with Mr Kelland but If he could explain how a common or garden Bumble Bee can fly I would be more inclined to follow his theory. With all due respect, that standpoint is entirely irrelevant. The principles put forth by any of us are about as cut and dried as whether an anvil, when released, will go up or down. QuotePhysics isn’t everything Nobody with a clue would describe Physics as "everything," but the disciplne does detail some inescapable realities. Ignore these physical realities at your peril. QuoteAt the Dz I mainly use On exit I use a combination of experience and judgement I have never had a problem with invading space of flat flyers, The only problems I’ve had is with the professional freeflyers who with their students insist on being the first out In part I understand as some times they are doing back-to-back an want to get down first. At the DZ’s I use that FF leave first, When I flare out at 5000ft I always barrel Roll and asses the situation ( I learnt along time ago not to trust a wave off) Also a student FF will very often when something goes wrong go flat instead of going into The ball position, so a barrel roll or a few seconds tracking on your back is to me important. Now the DZ I mainly use has a strict policy that FF must turn 90º right or left to flight line Oh an the other thing is that at this DZ if you have not had your FF card stamped you cannot do more than a two way, when I say card stamped I mean that you have proved to an instructor that you are capable of FF. Witch personally I think is the way to go So the original question was, Which policy does your DZ adopt And do you know why regardless of what Mr Kellend says The answer is: the policy which optimizes horizontal separation between groups in all regimes of the skydive. And yes, I know why, and Dr. Kallend and I are in complete agreement. Blue skies, Winsor Quote Share this post Link to post Share on other sites
Zep 0 #14 November 8, 2004 Reply to Mr kallend. I apologise for the error in spelling your name It was not intentional. When I went to school we were told that the Bumble Bee was an anomoly and that the size of it's wings should not sopport the weight of it's body mind you that was over 35 years ago. I seem to remember some years ago you saying some thing like "The exit order dosent matter as long as you give enough time" I can't quote you as I can't find the thread. Now I prefere to exit before flat flyers because, 1,I turn 90º after exit an generaly stay on heading 2, because I know I go down fast 3,Because after 18 years at this DZ I know the wind conditions (uppers an lowers) 4, Because at this DZ the run in is always South to North (more or less) reguardless of upper wind dirrection (explination, we have the sea behind us A town directly below us mountains to the right of us, A main road in front or us and buildings to the right of us, AAD's are compusory" So Mr kallend I do not dought your equations, so in a perfect world your equations would be pefect but alas we do not live in a perfect world Note. I am not trying to belittle or contradict Mr Kallend, but some DZ's do put FF out first. The question still stands "do you know why" Gone fishing Quote Share this post Link to post Share on other sites
sundevil777 102 #15 November 8, 2004 QuoteI seem to remember some years ago you saying some thing like "The exit order dosent matter as long as you give enough time" Of course that is right. Most choose to use an exit order policy that does not require the extra long delays to be safe.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
Zep 0 #16 November 8, 2004 QuoteQuoteI seem to remember some years ago you saying some thing like "The exit order dosent matter as long as you give enough time" Of course that is right. Most choose to use an exit order policy that does not require the extra long delays to be safe. The DZ's in this tread use GPS and at the cut off point always go round again, This point I will stress as we do exit in cloud and we cannot always see the ground also I trust the pilots 99%of the time So the question still stands Gone fishing Quote Share this post Link to post Share on other sites
PhreeZone 20 #17 November 8, 2004 Zhill's used to be Freefliers out first for the longest time too, I heard they just switched to RW'ers first last year.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
Zep 0 #18 November 8, 2004 QuoteZhill's used to be Freefliers out first for the longest time too, I heard they just switched to RW'ers first last year. Nothing to do with FF just an anecdote, Last time I jumped at Zhill's it snowed 89 Gone fishing Quote Share this post Link to post Share on other sites
billvon 3,171 #19 November 8, 2004 >The DZ's in this tread use GPS and at the cut off point always go > round again, This point I will stress as we do exit in cloud >and we cannot always see the ground also I trust the pilots 99% >of the time In the 1970's a group of US jumpers trusted the pilot and ended up with an ATC-assisted spot over Lake Erie. Most of them died. Exiting when you can't see the ground, other traffic or other groups is a bad idea. >So the question still stands You can use any exit order you wish IF you leave enough time between groups. In some cases, that amount of time may be 45 seconds in normal conditions; this leads to many go-arounds. If your DZ is willing to put up a load and do six go-arounds, then no problem. In most cases, DZO's prefer to not spend the extra money on fuel when a smarter exit order can result in safe separation with 5-10 second delays between exits. Quote Share this post Link to post Share on other sites
Zep 0 #20 November 8, 2004 Quote>The DZ's in this tread use GPS and at the cut off point always go > round again, This point I will stress as we do exit in cloud >and we cannot always see the ground also I trust the pilots 99% >of the time In the 1970's a group of US jumpers trusted the pilot and ended up with an ATC-assisted spot over Lake Erie. Most of them died. Exiting when you can't see the ground, other traffic or other groups is a bad idea. >So the question still stands You can use any exit order you wish IF you leave enough time between groups. In some cases, that amount of time may be 45 seconds in normal conditions; this leads to many go-arounds. If your DZ is willing to put up a load and do six go-arounds, then no problem. In most cases, DZO's prefer to not spend the extra money on fuel when a smarter exit order can result in safe separation with 5-10 second delays between exits. At this DZ we do have faith in the drivers we do not suffer to much from bandit aircraft. In the days of VOR no ground, No drop The dz has lost jumpers to the sea but only once in 20yrs due to circumstances beyond thier control I prefere to jump th Porter an if FF exit before flat flyers as do 99% of the other jumpers. When jumping the Twotter I will hang back on boarding an leave after the professional FF After 5 years of FF I'm not going to change my habbits Gone fishing Quote Share this post Link to post Share on other sites
Ruffles 0 #21 November 8, 2004 Addressing the question asked that started this thread, my DZ does Skysurfers, Big-way belly, small-way belly, freefly, tandem. However, this is when the plane is flying INTO the uppers, When the plane is flying WITH the uppers, Freefly out first, then belly, then surf, then tandem. For some reason the uppers in San Diego like to reverse themselves during the fall months, but otherwise, its the former of the two exit orders. Why? DZO says its because FF tend to sink straight and fall faster and bellys slower and tend to drift. Sounds to me... as long as we don't get rushed on exit, I've never had a close call (100-jump-wonder mind you). Quote Share this post Link to post Share on other sites
kallend 2,216 #22 November 8, 2004 QuoteReply to Mr kallend. I apologise for the error in spelling your name It was not intentional. When I went to school we were told that the Bumble Bee was an anomoly and that the size of it's wings should not sopport the weight of it's body mind you that was over 35 years ago. Post edited. The gist of John's reply was that 35 years ago, they made a mistake about the bumblebee.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
ps5601 0 #23 November 8, 2004 I thought Empuria operated a big to small policy for exits, regardless of discipline (note they also put tandems out first). I have seen FFs there insist on going first, no matter who or what else is on the plane (except tandems) for no other reason than they want to get down quick and don't want to be spotted off the north of the DZ (which can be a wet landing area). When I have seen it I have found it very annoying, not least 'cos it can ruin the most efficient exit, bum spotting the last out and is very selfish (and no matter what you say, getting a go around at Empuria is easier said than done). One good reason for big to small is that you can spot the first group slightly short, knowing that by the time they are set up in the door they are in the correct place. If it's a solo you lose that climb out time. Blue Skies Quote Share this post Link to post Share on other sites
speedy 0 #24 November 8, 2004 Exit order for my dropzone (generally): 1st Large to small belly groups 2nd large to small freefly groups 3rd solo freefly 4th extra seperation time then solo belly fliers who are warned to pull a little higher (they may have a long spot) 5th AFF 6th Tandems 7th wingsuits 8th the pilot if something goes wrong CRW can take their pick, Generally either 1st or last( but before the pilot). There may be exceptions to this exit order. Prof Kallend also explains situations where you may want to change things. Why do we do this? Because we have studied Kallend's stuff. It's the easiest way to achieve the seperation needed and to get everyone out in one drop run. It does not matter how much experience someone has, the physics remain the same. Dave Fallschirmsport Marl Quote Share this post Link to post Share on other sites
kallend 2,216 #25 November 8, 2004 QuoteQuote>The DZ's in this tread use GPS and at the cut off point always go > round again, This point I will stress as we do exit in cloud >and we cannot always see the ground also I trust the pilots 99% >of the time In the 1970's a group of US jumpers trusted the pilot and ended up with an ATC-assisted spot over Lake Erie. Most of them died. Exiting when you can't see the ground, other traffic or other groups is a bad idea. >So the question still stands You can use any exit order you wish IF you leave enough time between groups. In some cases, that amount of time may be 45 seconds in normal conditions; this leads to many go-arounds. If your DZ is willing to put up a load and do six go-arounds, then no problem. In most cases, DZO's prefer to not spend the extra money on fuel when a smarter exit order can result in safe separation with 5-10 second delays between exits. At this DZ we do have faith in the drivers we do not suffer to much from bandit aircraft. In the days of VOR no ground, No drop The dz has lost jumpers to the sea but only once in 20yrs due to circumstances beyond thier control I prefere to jump th Porter an if FF exit before flat flyers as do 99% of the other jumpers. When jumping the Twotter I will hang back on boarding an leave after the professional FF After 5 years of FF I'm not going to change my habbits Assuming jump run into the wind: If fast falling skydivers (head down, etc) exit first, followed by slow fallers, then the groups are on converging paths. Making an small error in exit timing can make those paths intersect, which is bad. If slow fallers exit first, followed by fast fallers, then their paths diverge, which is basically immune to errors in exit timing. Prudent DZs operate in ways that minimize the effects of errors.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
