MMakoto 0 #1 November 23, 2013 Hey, Just wondering, if someone have already Thought about using Teflon powder to help lubricate the cutaway cable (a bit of fine powder with silicone oil), maybe apply a little over the control lines to reduce friction (just the powder, or maybe a beeswax/Teflon blend) or maybe using the powder in the suspension lines to prevent tension knots(just the powder). As a mechanic engineer I know a Little about materials and lubricants, and as far my knowledge goes it cold be a good idea to use fine Powder Teflon (not the liquid solvent based ones). None of my rigger found a problem with that material, but none of them tried it. Not sure how long the powder alone wold hold in the suspension lines though (it can hold for several jumps by adsorption if the powder is fine enough). Quote Share this post Link to post Share on other sites
GLIDEANGLE 1 #2 November 23, 2013 Beeswax on the lines.... as I recollect, this has been tried before and the result was the capture of lots of dirt on the lines which INCREASED all the bad things that you are trying to decrease.The choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites
mcordell 2 #3 November 23, 2013 MMakotoHey, Just wondering, if someone have already Thought about using Teflon powder to help lubricate the cutaway cable (a bit of fine powder with silicone oil), maybe apply a little over the control lines to reduce friction (just the powder, or maybe a beeswax/Teflon blend) or maybe using the powder in the suspension lines to prevent tension knots(just the powder). As a mechanic engineer I know a Little about materials and lubricants, and as far my knowledge goes it cold be a good idea to use fine Powder Teflon (not the liquid solvent based ones). None of my rigger found a problem with that material, but none of them tried it. Not sure how long the powder alone wold hold in the suspension lines though (it can hold for several jumps by adsorption if the powder is fine enough). I feel like this would be an attempt to fix something I don't have problems with. I have never had tension knots in my lines on deployment. I'm also pretty sure I want some friction in my cutaway pull. It's pretty easy to pull and I have had to do so. I wouldn't want to make it any easier.www.facebook.com/FlintHillsRigging Quote Share this post Link to post Share on other sites
councilman24 37 #4 November 23, 2013 The interior of housings are not dry. When produced they are dripping in oil. There is always an oil residue left behind. Teflon powder would combine with the oil and make a slurry/paste. This may not only be not as effective as either oil or powder alone but may be worse. 80 years of housings, 40 years of teflon powder, nothing new here. Bees wax attracts sand and dirt. It was used on dacron lines to try to lessen tension knots. It is not a good idea even though it's probably still in Poynter's manual. Wax sold in paragear, if it's still there, is for waxing thread, not lines. If you want to be a test jumper fine. But don't expect to sell a canopy with lines contaminated.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
gowlerk 2,275 #5 November 23, 2013 QuoteI'm also pretty sure I want some friction in my cutaway pull. It is standard procedure to clean and lubricate the yellow Lolon cutaway cable. If you were to read the manual you will find that you should do it monthly. Although the reality is that it probably only gets done by your rigger at R&I time. You may have found your cutaway easy, as have I, but several people have died due to hard cutaways. It is important that cutaways be as easy as possible. Generally food grade silicon spray is used for this cleaning and lubricating, although some people use a light oil.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
BIGUN 1,486 #6 November 23, 2013 http://www.google.com/patents/EP1718790A2Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
MMakoto 0 #7 November 23, 2013 Well yes, beeswax in the suspension lines will be for sure a bad idea. The only spot that it may be useful is in the part of the control lines close to the toggles to reduce fraying or burning , maybe some Teflon powder would help to neutralize the tackiness of the beeswax . I rather not test new strange combinations though, but hey if someone tested and found it useful why not? QuoteThe interior of housings are not dry. When produced they are dripping in oil. There is always an oil residue left behind. Teflon powder would combine with the oil and make a slurry/paste. This may not only be not as effective as either oil or powder alone but may be worse. Good point, but the amount of powder is important, the idea is not to spray Teflon powder like hell. In some manufacturers manuals, they do recommend dry lubricant to clean the cutaway cables, but they are probably talking about the liquid emulsion types. Anyway the idea is to wipe all the residual powder after using it, leaving only a invisible micro coat that reduces the friction. (the powder needs to be very fine to allow such effect) Quote Share this post Link to post Share on other sites
RedundantRigger 0 #8 November 23, 2013 Do people clean the housings? Quote Share this post Link to post Share on other sites
mcordell 2 #9 November 23, 2013 mcordell***Hey, Just wondering, if someone have already Thought about using Teflon powder to help lubricate the cutaway cable (a bit of fine powder with silicone oil), maybe apply a little over the control lines to reduce friction (just the powder, or maybe a beeswax/Teflon blend) or maybe using the powder in the suspension lines to prevent tension knots(just the powder). As a mechanic engineer I know a Little about materials and lubricants, and as far my knowledge goes it cold be a good idea to use fine Powder Teflon (not the liquid solvent based ones). None of my rigger found a problem with that material, but none of them tried it. Not sure how long the powder alone wold hold in the suspension lines though (it can hold for several jumps by adsorption if the powder is fine enough). I feel like this would be an attempt to fix something I don't have problems with. I have never had tension knots in my lines on deployment. I'm also pretty sure I want some friction in my cutaway pull. It's pretty easy to pull and I have had to do so. I wouldn't want to make it any easier. I actually do maintain my cutaway system but I was saying I wouldn't want to add some other super slick lubricant to a functional system. Didn't we have more cutaway problems before rigid channels due to line twists binding the system?www.facebook.com/FlintHillsRigging Quote Share this post Link to post Share on other sites
mjosparky 4 #10 November 23, 2013 BIGUN http://www.google.com/patents/EP1718790A2 This guy has a patent on everything but the wheel. Sparky https://www.google.com/search?tbo=p&tbm=pts&hl=en&q=inassignee:%22Atair+Aerospace+Inc%22My idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
councilman24 37 #11 November 23, 2013 He patents common sense, and prior art, and will sue you over it. I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
councilman24 37 #12 November 23, 2013 The housings are cleaned before shipment. (Had a college roommate who worked in a factory making the stuff every weekend.) The residual oil is probably a good thing for flexibility and rust protection. But it also coat the cables and attracts dirt. THAT'S why you are supposed to clean and lube your cables every month. I think a completely dry system wouldn't be good. Anybody try it with degreaser?I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
RedundantRigger 0 #13 November 24, 2013 I've seen it done with some kind of raffined parafin/gasolene stuff, a rag and thin wire. Housings can harbor a decent amount of crap as time goes by, (making the rag completely black at least). But few people seem to do this procedure, even though it's mentioned in Poynter and bulletins from various manufacturers. (They seem to be hard to find for some reason) It might not be very important, as you say, if the cables are lubricated periodically. But a thought that struck me is that the reserve cable is never cleaned or lubricated. And that if muck is allowed to build up in the reserve housing, it might contribute to a hard pull. I'm guessing its not a problem seeing as I've never heard of any complications or whatever,but maybe you guys have something clever to say about it? Quote Share this post Link to post Share on other sites
councilman24 37 #14 November 24, 2013 Never heard of or seen an issue of twisted stainless cable on metal housing having an issue. Hard against hard and limited points of contact.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
councilman24 37 #15 November 24, 2013 Never heard of or seen an issue of twisted stainless cable on metal housing having an issue. Hard against hard and limited points of contact.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
mjosparky 4 #16 November 24, 2013 Quote But a thought that struck me is that the reserve cable is never cleaned or lubricated. Are you sure about that. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
uberchris 0 #17 November 24, 2013 i lube my cables once a month. i use food grade silicone spray, purchased from walmart for a few bucks. works like a charm. this is based on the recommendation from several of my rigger friendsgravity brings me down......... Quote Share this post Link to post Share on other sites
RedundantRigger 0 #18 November 24, 2013 So you clean/lubricate the reserve ripcord and clean out the housings? How do you clean the housings? Quote Share this post Link to post Share on other sites
Bertt 0 #19 November 24, 2013 I don't clean the housings, but I bet a BoreSnake would work. As for Teflon powder, the Lolon cable coating is slick, like Teflon, so Teflon powder would be redundant.You don't have to outrun the bear. Quote Share this post Link to post Share on other sites
JohnSherman 1 #20 November 24, 2013 Quote Just wondering, if someone have already Thought about using Teflon powder to help lubricate the cutaway cable (a bit of fine powder with silicone oil), Why not just buy a rig with pure Teflon (FEPT) Coating instrad of Nylon which is hydroscopic. No lubrication or maintaince req'd. They are out there and the cables are colored red or orange. Wonder which rig that is? Probabally the one which has not changed in 20 years, the one which doesn't inovate.The one which does't need a MARD. Quote Share this post Link to post Share on other sites
billvon 3,116 #21 November 25, 2013 >They are out there and the cables are colored red or orange. Wonder which rig that >is? Probabally the one which has not changed in 20 years, Not to quibble, but I bought a Racer 21 years ago and it had yellow cables. Quote Share this post Link to post Share on other sites
Boogers 0 #22 November 25, 2013 MMakoto Teflon powder... maybe apply a little over the control lines to reduce friction... or maybe using the powder in the suspension lines to prevent tension knots... What about the friction that is necessary in your rubber bands to hold your line stow bights? There are places where friction is needed, and a good thing. If your lines are too slick, you could get line dump. What about the effect it has on the slider descending down the lines? If the slider shoots down too fast, you're looking at hard openings. Quote As a mechanic engineer I know a Little about materials and lubricants, and as far my knowledge goes it cold be a good idea... That doesn't mean shit when it comes to applying the knowledge to skydiving gear of which you seem to know little about. And many people have died over the decades experimenting with their equipment without proper knowledge. Seemingly simple changes can have drastic consequences. A lot of systems are carefully balanced with each other, and if you upset that balance bad things can happen. Good luck. I suggest spending a few years becoming an expert skydiver. Then spend a few more years becoming an expert rigger. THEN you'll be ready to experiment with gear. Quote Share this post Link to post Share on other sites
MMakoto 0 #23 November 26, 2013 Just asking if someone had tried it, I'm not trying to be a test jumper, just trying to know a little more about it. So lets discuss about what you said: QuoteWhat about the friction that is necessary in your rubber bands to hold your line stow bights? If the friction is too low on the rubber bands, just tight the rubber bands. QuoteWhat about the effect it has on the slider descending down the lines? If the slider shoots down too fast, you're looking at hard openings. The descending speed of the slider is mainly affected by the air drag not the friction of the lines, spectra are more slick, HMA more rough, no difference about openings. I could say the same about the thickens of the lines, thicker lines mean much more friction between the slider grommet and the lines. We now have more thin microlines (which reduces the friction), and no change to the slider speed. QuoteThat doesn't mean shit when it comes to applying the knowledge to skydiving gear of which you seem to know little about Look before say that someone is stupid you have to be certain of what you are saying, don't be a fool. QuoteI suggest spending a few years becoming an expert skydiver. Then spend a few more years becoming an expert rigger when you say things like that is like saying that everyone that doesn't got 10 thousands jumps are not allowed to make suggestions of improvement, and every expert skydiver or rigger know everything that has to know about parachute systems and dynamics. You know you don't need to be a airplane pilot to improve something in an airplane. I don't know what is going to happen about the Teflon, that's why I'm asking here if someone tried it before. Maybe no one tough to use dry lubricants, that can be a good idea If someone used it and had a bad result so tell us so we can avoid mistakes Just watch your ego boy, Jesus... Quote Share this post Link to post Share on other sites
mcordell 2 #24 November 26, 2013 MMakoto QuoteWhat about the effect it has on the slider descending down the lines? If the slider shoots down too fast, you're looking at hard openings. The descending speed of the slider is mainly affected by the air drag not the friction of the lines, spectra are more slick, HMA more rough, no difference about openings. I could say the same about the thickens of the lines, thicker lines mean much more friction between the slider grommet and the lines. We now have more thin microlines (which reduces the friction), and no change to the slider speed. I would say you are very wrong about that. Smaller, slicker lines have led to the slider decending faster which contributed to harder openings. Several people went to larger sliders or modified sliders for this reason. Grammatically your posts are somewhat difficult to read and the result is it is hard to take your engineering thoughts seriously. That's not an attack, just a suggestion on how to maybe garner more sincere replies.www.facebook.com/FlintHillsRigging Quote Share this post Link to post Share on other sites
MMakoto 0 #25 November 26, 2013 Okay I accept that, slicker suspension lines = bad Idea. I'm a Portuguese speaker, that explains my grammar. Quote Share this post Link to post Share on other sites
