bwg 0 #1 January 14, 2014 Is anyone operating a Cessna 182 with FAA field approval to carry the pilot plus 5 skydivers? Quote Share this post Link to post Share on other sites
Blis 1 #2 January 14, 2014 bwgIs anyone operating a Cessna 182 with FAA field approval to carry the pilot plus 5 skydivers? No idea about FAA approvals but that is how we run 182 cessnas here in europe (well, in finland atleast), have to say that it's rather tight fight especially if there are bigger guys on the load... Quote Share this post Link to post Share on other sites
tristansdad 0 #3 January 14, 2014 You need FAA approval for that? Quote Share this post Link to post Share on other sites
pchapman 281 #4 January 14, 2014 So what's stopping you now? If some inspector says the aircraft was only certified for 4 seats and thus 4 occupants, then you'd be stuck at 3 skydivers, so that may not be the issue. Around where I am, I'm used to often having 5 jumpers in a 182, but those are in widebody 182's that provide sufficient space. Whatever works according to the W&B is allowed, and manifest keeps records of the weight for every load. It only works where the jumpers are below average weight overall. But that's for Transport Canada, not FAA in the States. Quote Share this post Link to post Share on other sites
Krip 2 #5 January 14, 2014 Hi PC My first 500 jumps back in the day were out of 180/182,s No turbine baby here, but I have to ask how high are you going what's your climb rate We were happy to get 400 FPM and exited at 7.5k The little people these days smell very nice.R Quote Share this post Link to post Share on other sites
masterrigger1 2 #6 January 14, 2014 Quote So what's stopping you now? If some inspector says the aircraft was only certified for 4 seats and thus 4 occupants, then you'd be stuck at 3 skydivers, so that may not be the issue. A standard cessna only came with 4 seat belts. To add more requires a field approval.Also it depends on the STC with the door removal/mod/skydiving configuration as to how many jumpers are listed on the approval. There are a few different STCs out there;all with different data. Lastly, it could be a weight and balance issue even if the STC allows 5 jumpers. MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com 1 Quote Share this post Link to post Share on other sites
pchapman 281 #7 January 14, 2014 I had always wondered about the legality of some of the seatbelt installations. Indeed, all belts on the floor are non-standard to begin with, so you've clarified that the issue might be that approvals for 3, 4, or 5 sets of floor belts are out there, but the OP doesn't happen to have one in-hand for 5. Interesting about the door STCs. A little odd, because having a well engineered door is completely unrelated to the number of jumpers inside. Quote Share this post Link to post Share on other sites
ChrisD 0 #8 January 14, 2014 This is one of my favorite topics. There is a difference between economics, the rules, and what is safe. There is a better way and jamming an aircraft to capacity and pushing the W/B to the edge is pushing things as compared with a little margin in the event something happens. High wing Cessna's worldwide, for a number of debatable reasons, continue to lead the incident list. Pilots with little experience in the flight conditions that lead to these same incidents lead the way and their egos continue to take the unwary innocent's that believe their pilot is the best. To the OP original question, No I personally don't know anyone currently operating under that paper STD. If you do a search the company that was offering that mod was posted here somewhere, give them a call? C Just something to consider. But what do I know, "I only have one tandem jump." Quote Share this post Link to post Share on other sites
DBCOOPER 5 #9 January 14, 2014 USPA has the STC for the seatbelt mod for 182's. Most door mods are done on a 337.Replying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites
jonstark 8 #10 January 14, 2014 DBCOOPERUSPA has the STC for the seatbelt mod for 182's. Most door mods are done on a 337. The USPA STC allows for only four seat belt locations and is for early serial number Cessnas. When going for field approval I would heartily recommend the Hooker Harness Systems single belt harness restraints. Simple and effective when used properly. jon Quote Share this post Link to post Share on other sites
riggerrob 644 #11 January 15, 2014 jonstark***USPA has the STC for the seatbelt mod for 182's. Most door mods are done on a 337. The USPA STC allows for only four seat belt locations and is for early serial number Cessnas. When going for field approval I would heartily recommend the Hooker Harness Systems single belt harness restraints. Simple and effective when used properly. jon ................................................................................. Agreed! Jack Hooker is the man! However, if you are operating in a country - where civil aviation authorities do not recognize Hooker's certification - may I recommend an alternate way of anchoring tandem students.? Hook tandem students' side straps to cargo rings, or seat-belt fittings. If none of the seat-belt fittings will accept a Quick-Ejector Snap, then slip on a Maillon Rapide #6 connector link. Maillon Rapide #6 is the most popular size link for tandem mains. This "re-neck engineer" fix may not satisfy government paperwork requirements, but it will reduce the size of your students' flail-arc and you will waste less time recovering from injuries. Quote Share this post Link to post Share on other sites
grue 1 #12 January 15, 2014 bwgIs anyone operating a Cessna 182 with FAA field approval to carry the pilot plus 5 skydivers? I've heard of 5 in a 182 and 6 in a 206 here in Australia, to both of which I say "fuck that". I "grew up" at a Cessna DZ and 4 in our 182 and 5 in our 206 seemed plenty tight and slow.cavete terrae. Quote Share this post Link to post Share on other sites
JohnMitchell 16 #13 January 15, 2014 We routinely carry 23 jumpers in Twin Otters, which I think only fly maybe 16 people in passenger service. Similar ratios with Caravans. 5 jumpers in a 182 . . . well, if it's with weight and balance and everyone has a seatbelt. That's MHO, but the FAA might see things differently. I'm a spoiled turbine brat these days. I haven't jumped a 182 in 2 years. Quote Share this post Link to post Share on other sites
dzswoop717 5 #14 January 15, 2014 When I worked for Paul Fayard back in the day. He built the ultimate 182 jump ship. IO-550 300hp engine, Roll up lexan door, cargo liner on the interior. it was a wide body and he only ever flew it with 4 jumpers. If there was a way to have the extra jumper in there he would have done it. The plane could have easily carried the extra load and the wide body can accomodate another body. I think the issue was useful load and it was maxed out with 4 jumpers and a pilot. Wing tip extensions would have given him more useful load and possibly the ability to carry 5 jumpers . But I can't say for sure. Quote Share this post Link to post Share on other sites
ufk22 33 #15 January 15, 2014 my home DZ flies our Supercessna (io550, wing extensions) with paperwork and belts for 5 jumpers, but we haven't actually flown a load with 5 for a couple of years. It's incredibly tight and if you we ever lost the engine it could be a disaster. There is paperwork for doing it, but just because it can be done doesn't mean it should be.This is the paradox of skydiving. We do something very dangerous, expose ourselves to a totally unnecesary risk, and then spend our time trying to make it safer. Quote Share this post Link to post Share on other sites
Elisha 1 #16 January 15, 2014 grue***Is anyone operating a Cessna 182 with FAA field approval to carry the pilot plus 5 skydivers? I've heard of 5 in a 182 and 6 in a 206 here in Australia, to both of which I say "fuck that". I "grew up" at a Cessna DZ and 4 in our 182 and 5 in our 206 seemed plenty tight and slow. Dude, you're a big boy - not a 100 lb Asian female. Of course you'd say f*ck that! I've been in several loads of a Turbo 206 w/ 7 that was still getting 600 ft / min, but that place has been gone for a few years now. Quote Share this post Link to post Share on other sites
bwg 0 #17 January 16, 2014 So apparently there are a few C-182's out there with the authorization and seat belt installations to legally carry 5 skydivers... I would like to obtain a copy of such an approval to use as a template. If you are willing to share technical information, please PM me. Thank you... Quote Share this post Link to post Share on other sites
grue 1 #18 January 16, 2014 Elisha******Is anyone operating a Cessna 182 with FAA field approval to carry the pilot plus 5 skydivers? I've heard of 5 in a 182 and 6 in a 206 here in Australia, to both of which I say "fuck that". I "grew up" at a Cessna DZ and 4 in our 182 and 5 in our 206 seemed plenty tight and slow. Dude, you're a big boy - not a 100 lb Asian female. Of course you'd say f*ck that! I've been in several loads of a Turbo 206 w/ 7 that was still getting 600 ft / min, but that place has been gone for a few years now. ha! Fair call. The 182 at the DZ I sometimes hit up can push 800fpm, which amazes me.cavete terrae. Quote Share this post Link to post Share on other sites
DrDom 0 #19 January 18, 2014 Physics is such a cruel bitch... More people = more uncomfortable = more time to altitude Nothing like your legs being asleep as you climb out ;)You are not the contents of your wallet. Quote Share this post Link to post Share on other sites
Krip 2 #20 January 22, 2014 DrDomPhysics is such a cruel bitch... More people = more uncomfortable = more time to altitude Nothing like your legs being asleep as you climb out ;) Hi DrDom No disrespect intended But if the airplane is packed like a sardine can so the dzo can maximize his operating efficency and profit. The dzo will continue to do it as long as jumpers are willing to accept substandard conditions. With all respect stop your whining or go to a different dz. Enjoy your next flight, and the next, and your next, and so on. Ever walk in the rain without a umbrella and whine because your getting wet? R.One Jump Wonder Quote Share this post Link to post Share on other sites
wmw999 2,650 #21 January 22, 2014 We did it regularly in the late 1970's. Conventional gear (i.e. front-mounted reserves). Bigger rigs even when they were piggy backs. It meant having one more person in freefall to play with. Quitcher bitchin' Wendy P. There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
DougH 270 #22 January 22, 2014 Sounds like a great idea on a cool spring day, with a nice running engine. What about with two (fat) tandem pairs, one fun jumper that needs to lay off the beer truck when he travels to boogies, a hot august day, and a newly blown cylinder on the engine just after take off?"The restraining order says you're only allowed to touch me in freefall" =P Quote Share this post Link to post Share on other sites
bwg 0 #23 January 24, 2014 I agree that flying with 5 skydivers would not be comfortable, safe, or legal in many of the low gross weight, under-powered Cessna 182's out there. However, adding a 5th skydiver to the load in a 300 HP wide-body C-182 with max gross weight of 3100 lbs can be accomplished within legal weight and balance limitations depending upon jumper weight, fuel load, density altitude, etc. For a DZO, the option to fly with a fifth jumper can help with the bottom line. However, if the load has two heavy tandems... fly without the fifth. If the load is a ladies' 4-way and fuel is light... then adding a camera flyer might be just fine. On a low-ceiling day or with a student load going to 3500'... five jumpers might work depending, of course, on weights and environmental conditions (and any "crunch" factor would only last about 5 minutes... until the first jumper is away). Manifest and the pilot would have to consider limitations of the aircraft for each load. From what I hear, there are numerous drop zones that operate C-182's with 5 + pilot. I am trying to find an operator with legal paperwork for that extra seat belt who is willing to share. Thanks! Quote Share this post Link to post Share on other sites
DrDom 0 #24 January 25, 2014 Krip***Physics is such a cruel bitch... More people = more uncomfortable = more time to altitude Nothing like your legs being asleep as you climb out ;) Hi DrDom No disrespect intended But if the airplane is packed like a sardine can so the dzo can maximize his operating efficency and profit. The dzo will continue to do it as long as jumpers are willing to accept substandard conditions. With all respect stop your whining or go to a different dz. Enjoy your next flight, and the next, and your next, and so on. Ever walk in the rain without a umbrella and whine because your getting wet? R. I love how one can start a paragraph with "no disrespect" but then have a quite disresepctful tone. I was only pointing out that physics can be a bitch. My DZ is mostly Otter based, its a rare treat to jump a C182 and admittedly I really LIKE jumping a cessna (ok, I LIKE standing on the step with my face to the wind and looking over at a smiling pilot with a thumbs up..). so, I'm not complaining, just pointing out how much our physical laws work against us in the most inconvenient ways.You are not the contents of your wallet. Quote Share this post Link to post Share on other sites
riggerrob 644 #25 January 26, 2014 JohnMitchell We routinely carry 23 jumpers in Twin Otters, which I think only fly maybe 16 people in passenger service. Similar ratios with Caravans. 5 jumpers in a 182 . . . well, if it's with weight and balance and everyone has a seatbelt. That's MHO, but the FAA might see things differently. I'm a spoiled turbine brat these days. I haven't jumped a 182 in 2 years. .................................................................................. Most Twin Otters - on scheduled passenger flights - rarely fly with more than 19 passengers. That is because you need a stewardess if you carry 20 passengers. Something about emergency exits ... Quote Share this post Link to post Share on other sites
