billvon 3,176 #1 Posted June 14, 2023 I first got interested in illumination when I was around 12. I built a light with AA batteries and an incandescent bulb inside a round plastic box. I also had a mercury switch in it, so when I rolled it across the floor it would flash on and off. At night it lit up the room. But during the day I could barely see it. How did that work? How did a bright light become dim just because there was other light there? How do you make as much _useful_ light as possible with as little energy as possible? Because incandescent bulbs were terrible in that respect. In high school I discovered LEDs and how efficient they were. At that point they still weren't as good as flourescent light but they were so much easier to use. I built all sorts of things full of flashing LEDs because I thought they looked cool. In college I finally got my hands on some very efficient red LEDs, and I built a red flashlight on top of a 9 volt battery. It was remarkably useful; both bright and small enough to fit in a pocket. It was the first time I realized that LEDs could be used for illumination. But back then you could get efficient red LEDs and sort of efficient green LED's. Together they made a yellowish light. Everyone who worked with LED's knew that the holy grail was a blue LED - a red, green and blue LED could both make white light and any color humans could see by adjusting their intensities. It was how TV's worked, except they used phosphors. We knew that once you had blue LEDs you could make huge and fairly cheap TVs by using LEDs instead of CRTs. And you could make white lights. Around 1990 I found my first blue LED from a surplus place called Hosfelt Electronics. It was a dim not-very-efficient blue LED in a T 1-3/4 housing, but it was absolutely blue and it meant that better ones were coming. I built several "any-color" lights that I could adjust to make any color from warm white to cool white to purple etc. In 1992 I was working on flourescent ballasts at work and put together the most efficent ballast plus bulbs I could find. They were high color rendering 34W tubes from Philips, and they put out a lot of light. And it wasn't the usual cold flourescent light either; it was a warmish white that looked a lot like incandescent light. I used it for a light over my workbench. The ballast was one of the first Advance electronic ballasts as well. Not only was it more efficient, it was dimmable down to 20% - so I could cut back even further on power when I didn't need it to be bright over the workbench. I also started to see compact flourescents start to replace incandescents. They had all sorts of problems - long warm up times, harder to dispose of, some were noisy - but they were a solid 4x improvement in efficiency over incandescents. This was an even bigger deal in warm climates, since air conditioners also had to shoulder the load to cool the incandescents in houses that used them. I changed all the lights in my parent's house out to CFs and they saw a significant drop in their power bill. In 1995 I started to get more efficient blue LEDs and made a few white-light flashlights. Then around 2000 blue LEDs with phosphor backings started to appear. These flouresced red and yellow and thus made the light appear white, at a small loss in efficiency (since you lose energy when you downshift in frequency.) But overall they were more efficient than even compact flourescents, and today they are both cheaper and more efficient than CF's ever were. Nowadays there are amazingly good high intensity LEDs. Petco Park just replaced all their stadium lights with LED's - so now they can be part of the light show, with their instant on/off times. You can buy light tiles you just stick to your wall that gives you not only white light, but any color light you want. We are continually developing illumination that gives us more light, light that looks better, light with more flexibility - and for ever decreasing costs and ever improving efficiencies. And on my wall there is a TV that is made of millions of red, green and blue organic LEDs - the holy grail we talked about way back in college. And similar technology lets you build 100 foot video screens anywhere you want. That old flourescent fixture I built way back when kept moving with me - from my parent's house in New York to a rental house on Long Island, to a house in San Diego, through two apartments, another rental house, the first house I owned and now to my current house, where it hangs over the workbench in the garage. And it finally failed for good after over 30 years of service, with both ends blackened and the filaments so gone that not even the Advance ballast could start them any more. And the bulbs were replaced by LED tubes that are even more efficient and look just as good - so at least the ballast will live on. 1 Quote Share this post Link to post Share on other sites
lippy 918 #2 June 14, 2023 23 minutes ago, billvon said: I first got interested in illumination when I was around 12. I built a light with AA batteries and an incandescent bulb inside a round plastic box. I also had a mercury switch in it, so when I rolled it across the floor it would flash on and off. At night it lit up the room. But during the day I could barely see it. How did that work? How did a bright light become dim just because there was other light there? How do you make as much _useful_ light as possible with as little energy as possible? Because incandescent bulbs were terrible in that respect. In high school I discovered LEDs and how efficient they were. At that point they still weren't as good as flourescent light but they were so much easier to use. I built all sorts of things full of flashing LEDs because I thought they looked cool. In college I finally got my hands on some very efficient red LEDs, and I built a red flashlight on top of a 9 volt battery. It was remarkably useful; both bright and small enough to fit in a pocket. It was the first time I realized that LEDs could be used for illumination. But back then you could get efficient red LEDs and sort of efficient green LED's. Together they made a yellowish light. Everyone who worked with LED's knew that the holy grail was a blue LED - a red, green and blue LED could both make white light and any color humans could see by adjusting their intensities. It was how TV's worked, except they used phosphors. We knew that once you had blue LEDs you could make huge and fairly cheap TVs by using LEDs instead of CRTs. And you could make white lights. Around 1990 I found my first blue LED from a surplus place called Hosfelt Electronics. It was a dim not-very-efficient blue LED in a T 1-3/4 housing, but it was absolutely blue and it meant that better ones were coming. I built several "any-color" lights that I could adjust to make any color from warm white to cool white to purple etc. In 1992 I was working on flourescent ballasts at work and put together the most efficent ballast plus bulbs I could find. They were high color rendering 34W tubes from Philips, and they put out a lot of light. And it wasn't the usual cold flourescent light either; it was a warmish white that looked a lot like incandescent light. I used it for a light over my workbench. The ballast was one of the first Advance electronic ballasts as well. Not only was it more efficient, it was dimmable down to 20% - so I could cut back even further on power when I didn't need it to be bright over the workbench. I also started to see compact flourescents start to replace incandescents. They had all sorts of problems - long warm up times, harder to dispose of, some were noisy - but they were a solid 4x improvement in efficiency over incandescents. This was an even bigger deal in warm climates, since air conditioners also had to shoulder the load to cool the incandescents in houses that used them. I changed all the lights in my parent's house out to CFs and they saw a significant drop in their power bill. In 1995 I started to get more efficient blue LEDs and made a few white-light flashlights. Then around 2000 blue LEDs with phosphor backings started to appear. These flouresced red and yellow and thus made the light appear white, at a small loss in efficiency (since you lose energy when you downshift in frequency.) But overall they were more efficient than even compact flourescents, and today they are both cheaper and more efficient than CF's ever were. Nowadays there are amazingly good high intensity LEDs. Petco Park just replaced all their stadium lights with LED's - so now they can be part of the light show, with their instant on/off times. You can buy light tiles you just stick to your wall that gives you not only white light, but any color light you want. We are continually developing illumination that gives us more light, light that looks better, light with more flexibility - and for ever decreasing costs and ever improving efficiencies. And on my wall there is a TV that is made of millions of red, green and blue organic LEDs - the holy grail we talked about way back in college. And similar technology lets you build 100 foot video screens anywhere you want. That old flourescent fixture I built way back when kept moving with me - from my parent's house in New York to a rental house on Long Island, to a house in San Diego, through two apartments, another rental house, the first house I owned and now to my current house, where it hangs over the workbench in the garage. And it finally failed for good after over 30 years of service, with both ends blackened and the filaments so gone that not even the Advance ballast could start them any more. And the bulbs were replaced by LED tubes that are even more efficient and look just as good - so at least the ballast will live on. Nice history, thanks for sharing. I was relatively late in the game getting into LED’s, but I love to play with them at any opportunity. Under my kitchen cabinets I’ve got some hi-power white LED’s run off of an LM3405 that’s PWM’d from a micro. The micro is triggered by a PIR sensor feeding some amplifiers that drive a comparator. Wave your hand under the cabinets, the comparator flags the micro and the lights ramp up. If it goes 5 minutes without a trigger on the PIR input and they fade out. Great for hands-free light control during food prep and it turns itself off when you walk away. It was a simple project and now 7 years later it’s still a super-useful part of our kitchen. 1 Quote Share this post Link to post Share on other sites
gowlerk 2,309 #3 June 14, 2023 For years I resisted the government imposed push to replace my beautiful globes of heated tungsten fire in semi-vacuum. I seriously considered buying cases of 100 and 60 watts bulbs to put away and last into my old age. Then suddenly while I wasn't paying any attention at all the LED advancements you write of happened. At this point I can't get rid those stupid electricity hogs that I loved so much fast enough. I no longer even like the colour of them, they make me feel as if I'm working by candlelight. Quote Share this post Link to post Share on other sites
Coreece 190 #4 June 14, 2023 2 hours ago, gowlerk said: I no longer even like the colour of them, they make me feel as if I'm working by candlelight. That's what I like about them. But I'm still happy with any type of warm light. Absolutely hate any type of cool "day light" bulbs. So depressing, especially in hotels. Almost as bad as fluorescent bulbs. In the forest at night I use red light as much as possible to preserve night vision since it has a less disruptive effect on scotopic adaptation. Plus it's better for star gazing. 1 Quote Share this post Link to post Share on other sites
billeisele 130 #5 June 21, 2023 On 6/14/2023 at 12:08 AM, billvon said: I first got interested in illumination when I was around 12. I built a light with AA batteries and an incandescent bulb inside a round plastic box. I also had a mercury switch in it, so when I rolled it across the floor it would flash on and off. At night it lit up the room. But during the day I could barely see it. How did that work? How did a bright light become dim just because there was other light there? How do you make as much _useful_ light as possible with as little energy as possible? Because incandescent bulbs were terrible in that respect. In high school I discovered LEDs and how efficient they were. At that point they still weren't as good as flourescent light but they were so much easier to use. I built all sorts of things full of flashing LEDs because I thought they looked cool. In college I finally got my hands on some very efficient red LEDs, and I built a red flashlight on top of a 9 volt battery. It was remarkably useful; both bright and small enough to fit in a pocket. It was the first time I realized that LEDs could be used for illumination. But back then you could get efficient red LEDs and sort of efficient green LED's. Together they made a yellowish light. Everyone who worked with LED's knew that the holy grail was a blue LED - a red, green and blue LED could both make white light and any color humans could see by adjusting their intensities. It was how TV's worked, except they used phosphors. We knew that once you had blue LEDs you could make huge and fairly cheap TVs by using LEDs instead of CRTs. And you could make white lights. Around 1990 I found my first blue LED from a surplus place called Hosfelt Electronics. It was a dim not-very-efficient blue LED in a T 1-3/4 housing, but it was absolutely blue and it meant that better ones were coming. I built several "any-color" lights that I could adjust to make any color from warm white to cool white to purple etc. In 1992 I was working on flourescent ballasts at work and put together the most efficent ballast plus bulbs I could find. They were high color rendering 34W tubes from Philips, and they put out a lot of light. And it wasn't the usual cold flourescent light either; it was a warmish white that looked a lot like incandescent light. I used it for a light over my workbench. The ballast was one of the first Advance electronic ballasts as well. Not only was it more efficient, it was dimmable down to 20% - so I could cut back even further on power when I didn't need it to be bright over the workbench. I also started to see compact flourescents start to replace incandescents. They had all sorts of problems - long warm up times, harder to dispose of, some were noisy - but they were a solid 4x improvement in efficiency over incandescents. This was an even bigger deal in warm climates, since air conditioners also had to shoulder the load to cool the incandescents in houses that used them. I changed all the lights in my parent's house out to CFs and they saw a significant drop in their power bill. In 1995 I started to get more efficient blue LEDs and made a few white-light flashlights. Then around 2000 blue LEDs with phosphor backings started to appear. These flouresced red and yellow and thus made the light appear white, at a small loss in efficiency (since you lose energy when you downshift in frequency.) But overall they were more efficient than even compact flourescents, and today they are both cheaper and more efficient than CF's ever were. Nowadays there are amazingly good high intensity LEDs. Petco Park just replaced all their stadium lights with LED's - so now they can be part of the light show, with their instant on/off times. You can buy light tiles you just stick to your wall that gives you not only white light, but any color light you want. We are continually developing illumination that gives us more light, light that looks better, light with more flexibility - and for ever decreasing costs and ever improving efficiencies. And on my wall there is a TV that is made of millions of red, green and blue organic LEDs - the holy grail we talked about way back in college. And similar technology lets you build 100 foot video screens anywhere you want. That old flourescent fixture I built way back when kept moving with me - from my parent's house in New York to a rental house on Long Island, to a house in San Diego, through two apartments, another rental house, the first house I owned and now to my current house, where it hangs over the workbench in the garage. And it finally failed for good after over 30 years of service, with both ends blackened and the filaments so gone that not even the Advance ballast could start them any more. And the bulbs were replaced by LED tubes that are even more efficient and look just as good - so at least the ballast will live on. Nice walk back in time. I remember the Philips earth tubes with the green ends. Encouraged a ton of customers to convert to electronic ballasts and 34W lamps, then to T-8s. Now there are the LED conversion tubes, and better yet the LED fixtures. It's interesting that the new LED fixtures have 5 temperature settings. Installed some new fixtures in a mechanical space last month and played around with the color options. Building inspectors must be disappointed since they can rarely bust an inspection due to an exit sign not working. The old 7W lamps used to be a guaranteed find, burned out. I still have my light table built with a U-bend T-12 shining thru milky plexiglas. It's great for reviewing slides. Wifey and daughter are currently emptying the 20+ carousels to decide what to get converted to digital. Quote Share this post Link to post Share on other sites
