azureriders 0 #1 February 27, 2006 Our DZ follows the same basic exit order that most on here seem to agree with. RW largest to smallest, FF largest to smallest, AFF, Tandems. A load from this weekend, in the order of exit 1) RW four way round, 2) solo belly flyer, 3) Hybrid including 6 or 7 belly flyers. I realize that hybrid belly flyers arch hard and fall fast in sake of their FF counterparts, but do they truly fall faster and therefore have less drift than the solo that went ahead of them. (I don't think so) Does the fact that they had more belly flyers slow them down more than the RW four way and therefore they should have went first (I still don't think so) IMO the correct order would have been 1)RW four way, 2) Hybrid 3) Solo Belly, but then again I don't know enough about the fall rate of a Hybrid to say this for sure ergo my questions. More info: Jump run was into the wind. I was in the first group so I felt safe no matter. I knew we had more drift than the solo and even if the hybrid should have gone first I could not see them drifting all the way over the solo and to us. The hybrid was also packed with experience, a lot of which I have the utmost respect for and no doubt in my mind they gave a good separation (although I was gone by that time so who can say for sure) I have learned a lot from a few similar threads in the past and Kallend's model is great. I would appreciate any input on this to further my knowledge. Quote Share this post Link to post Share on other sites
billvon 3,151 #2 February 27, 2006 To get best advantage of the greater separation you get when you have faster fallers out last, it should be: RW hybrids freefly Quote Share this post Link to post Share on other sites
bob.dino 1 #3 February 27, 2006 In my limited experience, hybrids fall at 140-160mph, with 155-160mph being the most common. 20-way hybrids rock Quote Share this post Link to post Share on other sites azureriders 0 #4 February 28, 2006 QuoteRW hybrids freefly I know and agree with this, and also that larger groups fall slower therefore the largest to smallest within each discipline. I guess my question was could one larger group of one discipline overlap fall rates with a small group of another discipline? Quotehybrids fall at 140-160mph, with 155-160mph being the most commonIf that be the case I stand corrected already as I don't believe the solo belly flyer was falling nearly that fast and the exit order was correct as it was. Quote Share this post Link to post Share on other sites packing_jarrett 0 #5 February 28, 2006 how come DZ just do jump-run crosswind. That would eliminate the exit order problem right?Na' Cho' Cheese Quote Share this post Link to post Share on other sites billvon 3,151 #6 February 28, 2006 >how come DZ just do jump-run crosswind. That would eliminate the >exit order problem right? Yes. Problems are: 1. It's harder to spot 2. You have to leave pretty quickly to get everyone out on one pass; it's like separation for zero uppers. Quote Share this post Link to post Share on other sites matthewcline 0 #7 February 28, 2006 How about a "cross/up-wind" exit? I have used it on CH-47's and it seemed to work pretty good. The alt was 14K, A/C airspeed was 100kts and the load had the usuall mix of RW, Hybrid, VRW, Student/AFF and tandems with Video.An Instructors first concern is student safety. So, start being safe, first!!! Quote Share this post Link to post Share on other sites billvon 3,151 #8 February 28, 2006 > How about a "cross/up-wind" exit? That requires people to either do trigonometry or at least understand it - and skydivers generally don't do trigonometry. It also requires RW out first, like an upwind jump run (at least if you want the best possible separation.) If you're going to program the GPS and do the math and all, then a curved jump run might be the ticket. Eloy has experimented with these, with good results. You end up leaving too much time as the last people get out, but everyone ends up closer to the DZ so it's not as big a deal. >The alt was 14K, A/C airspeed was 100kts . . . . A 100kt airspeed fixes many ills, since it's difficult to get out fast enough to cause a separation problem. Quote Share this post Link to post Share on other sites CornishChris 5 #9 February 28, 2006 Hybrid Dave? Is that you? CJP Gods don't kill people. People with Gods kill people Quote Share this post Link to post Share on other sites bob.dino 1 #10 February 28, 2006 I was waiting for that, though it was Oli I was expecting to chime in . Quote Share this post Link to post Share on other sites matthewcline 0 #11 February 28, 2006 trigo what? is that what I was doing? I only used it to avoid the " we are always hosed and out so long" complaints. We happened to be able to get 30 (+ or -) out in 1 pass each time and have planty of seperation and a good drift line.An Instructors first concern is student safety. So, start being safe, first!!! Quote Share this post Link to post Share on other sites br0k3n 0 #12 February 28, 2006 QuoteHybrid Dave? Is that you? How did you beat me to that Parsons... gutted Oh HD (hybrid Dave) is this your work (goto 3mins 37secs)----------------------------------------------------------- --+ There are 10 types of people in the world: Those who understand binary, and those who don't.. --+ Quote Share this post Link to post Share on other sites milkybar 0 #13 March 14, 2006 Consider break-off altitudes, and deployment altitudes: Consider experience level of jumpers on Hybrid, jumpers following hybrid [new freeflyers = horizontal drifting] Seperation is paramount: Many times organizers will alter the exit order to ensure safe separation. A hybrid has the potential to drift horizontally. A good organizer takes many things into account to determine the safest exit order. If I doubt the organizer's judgement or those in his/her's group, I state I will be deploying higher than them and stick to the plan, enjoy the extra canopy time, and the uncluttered airspace as I come into land. As with most things in skydiving there are many variables to take into account. Disclaimer: All the above is the opinion of an idiot. Signed: Ab Normal Quote Share this post Link to post Share on other sites davelepka 4 #14 March 14, 2006 The biggest problems with hybrids is that the fall rates vary greatly from jump to jump. If ti build fast, and is solid, it's closer to a freefly jump. If it builds slow, and the hangers cork, it's back to belly speed. Separation from drift is all related to time in freefall, so the fall rate becomes an issue. The best slot is inbetween the last RW and first freefly group, so what ever happens they're good. Quote Share this post Link to post Share on other sites popsjumper 2 #15 March 14, 2006 Quote... >The alt was 14K, A/C airspeed was 100kts . . . . A 100kt airspeed fixes many ills, since it's difficult to get out fast enough to cause a separation problem. Uh....I assume you are considering 0kt uppers at exit altitude here. Other than that, one would be considering ground speed rather than airspeed along with winds aloft at lower altitudes. Fell free to correct me if I'm wrong.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites billvon 3,151 #16 March 14, 2006 >I assume you are considering 0kt uppers at exit altitude here. I'm considering all uppers. The faster the airspeed of the plane, the faster its groundspeed as well. An Otter flying 80kts is always going to require greater separation times than a King Air flying at 100kts. Quote Share this post Link to post Share on other sites TheDonMan 0 #17 March 14, 2006 Thats not true..... An otter going 80kts with 0kt head wind will have the same ground speed as a kingair flying at 100kts air speed with a 20kts head wind. When determining separation from groups you should be looking at ground speed and should have around 1000ft separation between groups based of the ground speed not the air speed. The air speed is a constant..... An Otter will always have the same air speed on jump run just to stay in the air. that does not mean that the ground speed will always be the same. I have been on some Jump runs that the uppers were so strong that we needed 20 seconds of separation because our ground speed was about 35 kts. The plains air speed was 80 kts. The world is full of willing people, some willing to work, the rest willing to let them. Quote Share this post Link to post Share on other sites billvon 3,151 #18 March 14, 2006 > An otter going 80kts with 0kt head wind will have the same ground >speed as a kingair flying at 100kts air speed with a 20kts head wind. Right. But in ANY GIVEN WIND the faster plane has less problems with separation. Which means that any given DZ, the faster planes will have fewer separation problems than the slower planes. Greater airspeed can help people who don't understand separation to get separation anyway. Quote Share this post Link to post Share on other sites kallend 2,192 #19 March 14, 2006 Quote The air speed is a constant..... An Otter will always have the same air speed on jump run just to stay in the air. . NOT TRUE! Try jumping from an Otter in trail behind a CASA on a multi-plane formation.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites TheDonMan 0 #20 March 14, 2006 That's because the CASA need more AIR speed to stay in the air... When flying in formations the air speeds for all the planes need to be the same as the plane that needs the greatest amount of AIR speed to keep from falling out of the sky. Thus the Otter will actually fly faster to keep up with the CASA when in actuality is can fly a lot slower and still stay in the air. The world is full of willing people, some willing to work, the rest willing to let them. Quote Share this post Link to post Share on other sites pilotdave 0 #21 March 14, 2006 I think his point was that airspeed on jumprun isn't constant for a given aircraft. There may be a nearly fixed minimum jump run airspeed, but pilots won't always fly at that minimum. And of course that minimum includes some margin... the pilot doesn't fly jumprun at the minimum controllable airspeed (the airspeed needed to "stay in the air"). Dave Quote Share this post Link to post Share on other sites kallend 2,192 #22 March 14, 2006 QuoteI think his point was that airspeed on jumprun isn't constant for a given aircraft. There may be a nearly fixed minimum jump run airspeed, but pilots won't always fly at that minimum. And of course that minimum includes some margin... the pilot doesn't fly jumprun at the minimum controllable airspeed (the airspeed needed to "stay in the air"). Dave "Always" is very difficult to justify.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
