bbrodes 0 #1 October 5, 2014 So I just took the winsuit first flight course and I'm hooked. Putting the rig trough the suit I had to detach my bungee...which I'm realizing is gonna be a bitch when I'm coming down from a freefly and going up to wingsuit. Has anyone thought of some kind of quick detach system? Thanks! Quote Share this post Link to post Share on other sites
Decodiver 0 #2 October 5, 2014 I've seen people use an RSL shackle fixed to the elastic on one side and a loop on the other end. Quote Share this post Link to post Share on other sites
dirtbox 0 #3 October 5, 2014 get a 10mm fastex clip from your local outdoor store and some 4mm shock cord. Make two ~15cm loops and larkshead them to the two ends of the clips and to the bungee attachment points on your rig. Easy to use and make, cheap to replace. I get a couple hundred jumps out of each one. There is another thread on this Quote Share this post Link to post Share on other sites
monkycndo 0 #4 October 5, 2014 I don't like any metal/plastic clips between my legs. I show my WS students how to use a closing loop and length of bungee. It is very simple to install and just as easy to disconnect when jumping your WS. The info is included as part of my course. If you have not taken your FFC through me, the system costs a bazillian dollars. 50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
strife 0 #5 October 5, 2014 Im using one of these S-biner micro lock and just unlock one side when wingsuiting http://www.rei.com/product/860182/nite-ize-s-biner-microlock-keychain-2-pack Quote Share this post Link to post Share on other sites
Krip 2 #6 October 5, 2014 bbrodes So I just took the winsuit first flight course and I'm hooked. Putting the rig trough the suit I had to detach my bungee...which I'm realizing is gonna be a bitch when I'm coming down from a freefly and going up to wingsuit. Has anyone thought of some kind of quick detach system? Thanks! Hi Have you considered getting a second rig, only $3 to $6k , think of all the time you would save, and all the extra loads you could get on.One Jump Wonder Quote Share this post Link to post Share on other sites
dthames 0 #7 October 6, 2014 There was a thread about this a year or so ago, as I recall. There were several good ideas. I am to tired and lazy to try to find it now. If you are really hooked, you don't have to worry with the bungee any longer. Just put it away in case you need it at a later date. DanInstructor quote, “What's weird is that you're older than my dad!” Quote Share this post Link to post Share on other sites
bbrodes 0 #8 October 7, 2014 I went with these and they worked great :) thanks! To everyone else thank you for the replies! Quote Share this post Link to post Share on other sites
riggerrob 644 #9 October 7, 2014 strifeIm using one of these S-biner micro lock and just unlock one side when wingsuiting http://www.rei.com/product/860182/nite-ize-s-biner-microlock-keychain-2-pack ...................................................................................... That is the scariest parachute accessory I have seen in a long time!!!!! What prevents it from grabbing your pilot-chute????? Quote Share this post Link to post Share on other sites
Hellis 0 #10 October 7, 2014 riggerrob***Im using one of these S-biner micro lock and just unlock one side when wingsuiting http://www.rei.com/product/860182/nite-ize-s-biner-microlock-keychain-2-pack ...................................................................................... That is the scariest parachute accessory I have seen in a long time!!!!! What prevents it from grabbing your pilot-chute????? It's a twist lock. It will probably make it harder to unintensionally catch something. Not saying I like the idea though. Quote Share this post Link to post Share on other sites
elias123 0 #11 October 7, 2014 I use a bungee that I put through the hole on one legstrap and attach it to a hard link that I put through the hole on the other. Very quick and easy to change inbetween jumps."In a mad world, only the mad are sane" Quote Share this post Link to post Share on other sites
CornishChris 5 #12 October 11, 2014 I use a clip from a puppies collar (when my dog was a puppy). One half is attached to a keyring loop, on one leg loop and the other is on the bungee, through the other loop. It clips open and closed and works well. Checked with my rigger and they were cool with it. CJP Gods don't kill people. People with Gods kill people Quote Share this post Link to post Share on other sites
RMK 3 #13 October 11, 2014 Here you go; post #20 has the coolest solution http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=2750316;page=unread#unread"Pain is the best instructor, but no one wants to attend his classes" Quote Share this post Link to post Share on other sites
