ikebonamin 0 #1 March 22, 2006 What if you stall your canopy when under a line over mal? Can this act help the mal clear itself? Quote Share this post Link to post Share on other sites
AggieDave 6 #2 March 22, 2006 It depends and I wouldn't say "stall." If a control line is the line that is apart of your canopy/line entanglement then it is possible to clear the line with a smooth and full flare. However, it may not always work. The other side of the equation is that the line may have damaged the topskin of your canopy, something you may not be fully aware of until it is too late to cutaway your canopy. Personally if I have the altitude I'll mess with a malfunction a little bit, BUT I have learned (and was lucky) that altitude awareness is the most important aspect in regards with trying to salvage a malfunction. The last time I had a lineover, I tried flaring out of it, but much to my surprise the line cleared the "wrong way" leaving the left control line wrapped completely around all the lines and around the canopy. Needless to say that ended up in a reserve ride. There's a reason why a majority of instructors teach a single malfunction proceedure to students. Muscle memory is built to ask "Is it there, is it square, is it steerable" and if not and is not a typically fixable problem (linetwists, collapsed endcells, etc) then the response is always the same. This keeps students and low time jumpers from going in while trying to practice rigging in the air. So please, even though you apparently have a license, chat with some of the instructors and/or the S&TA (or equivilent) at your DZ about your options when presented with malfunctions such as a lineover.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
billvon 3,152 #3 March 22, 2006 >What if you stall your canopy when under a line over mal? Can this >act help the mal clear itself? "Stall" is really only valid when the canopy is flying normally, and usually with a lineover it isn't. Pumping the toggles can sometimes help clear a lineover. If you are certain you have a lineover, it is generally unfixable, and should generally be cut away immediately. If you have the altitude, the canopy is at least partially inflated, and is not going to spin up too much (i.e. it's a very light loading or a 'small' lineover) you may try to clear it. If you do try to clear it I recommend pumping the toggles three times to see if that clears it. If it does not, cut it away. Don't get wrapped up in trying to clear it and lose track of altitude! Always ensure you have a good canopy by your decision height. Quote Share this post Link to post Share on other sites
marks 0 #4 March 23, 2006 QuoteWhat if you stall your canopy when under a line over mal? Can this act help the mal clear itself? lineover's usually clear themselves without you ever even knowing there was one. stalling, or aggressively handling your canopy CAN clear one, but also can make it worse. plus, like someone else said, there could be other damage because of it... if altitude allows, try to clear, if you do check for 3 S's, and proceed with whatever you need to. Quote Share this post Link to post Share on other sites
sundevil777 102 #5 March 23, 2006 On my only lineover mal, I was turning aggressively to try to do something with it, and the lineover cleared when I let go of the toggle - letting it 'snap' up to the riser. Unfortunately, when I let go of the toggles, I chopped it. A friend a little ways above/side of me, saw it clear immediately before I chopped. I really wonder if it might be that a deep toggle input, followed by a release of the handle to let it go fast, might be the most effective way to clear a lineover?People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
riggerrob 644 #6 March 23, 2006 Yes, I have used the "deep stall followed by flinging the toggles up" technique to clear several tension knots and one line over. Mind you, I cleared that last line over at about 1500 feet over the Fraser River. Wasting that much altitude - under a malfunction - scared me! The bottom line is that sometimes you can clear a line over with toggle movement, but having a good canopy overhead by decision height is more important. Quote Share this post Link to post Share on other sites
AFFI 0 #7 March 23, 2006 Be advised. You can cause canopy damage trying to fix a line over problem and really risk loss of altitude awareness while you spend the rest of your life fixing… Quote Share this post Link to post Share on other sites
dragon2 2 #8 March 24, 2006 I was taught a lineover can more easily be cleared on a tandem canopy, on a sports rig just cataway, to prevent damage to the canopy and to prevent wasting time, because you're probably not going to clear it anyway. How come on a tandem canopy it is easier to get rid of a lineover? Or is it? ciel bleu, Saskia Quote Share this post Link to post Share on other sites
ikebonamin 0 #9 March 24, 2006 Thanks all for the input... After reading all the posts I think the best thing to do is to cut away and forget about it... Quote Share this post Link to post Share on other sites
BrianM 1 #10 March 28, 2006 QuoteYes, I have used the "deep stall followed by flinging the toggles up" technique to clear several tension knots and one line over. Mind you, I cleared that last line over at about 1500 feet over the Fraser River. You cheated me out of a great show - I was just above you and off to the side a bit waiting for you to chop."It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
Zoter 0 #11 March 29, 2006 I'd always thought if it was stable and steerable and I had plenty of altitude I might cut the affected control line and land on rear riser/opposite toggle..... ( I already have several landings just on rears and a few in the above combination.....not all standup, but all landed without incident) Not something to be recommended for those of us with low numbers, including myself.....but if the conditions were as stated...me ,myself and I certainly would consider it over chopping. Cant be much price difference in a new set of control lines vs a repack ( with maybe a lost freebag and handles) Quote Share this post Link to post Share on other sites
dragon2 2 #12 March 29, 2006 QuoteI'd always thought if it was stable and steerable and I had plenty of altitude I might cut the affected control line and land on rear riser/opposite toggle..... Not something to be recommended for those of us with low numbers, including myself.....but if the conditions were as stated...me ,myself and I certainly would consider it over chopping. Cant be much price difference in a new set of control lines vs a repack ( with maybe a lost freebag and handles) It's not always a control line... If I had started cutting a at my lines it would've been pretty expensive and probably an interesting ride too And you need to know WHICH line to cut, not that easy. Look up a thread by Hooknswoop about an intentional lineover... ciel bleu, Saskia Quote Share this post Link to post Share on other sites
Zoter 0 #13 March 29, 2006 Fair enough......... If I couldnt ID the affected line.....I wouldnt try.. Quote Share this post Link to post Share on other sites
