Dimitrilp 0 #1 Posted June 22, 2022 Hello, does anyone have a PARACHUTE DE FRANCE a toggles, the one with the pin. Thank you Quote Share this post Link to post Share on other sites
JerryBaumchen 1,468 #2 June 22, 2022 7 hours ago, Dimitrilp said: Hello, does anyone have a PARACHUTE DE FRANCE a toggles, the one with the pin. Thank you Hi Dimintrilp, You will probably have to have someone make a set for you. I realize you are in Europe, but one option would be to contact Jump Shack. They make both normal toggles & the pins for the PdF style of toggle. I no longer have a photo of the PdF style of toggle. Try to get a photo to go along with any inquiry you might make to Jump Shack. Sport Containers - Parachute Laboratories, Inc. (plabsinc.com) Jerry Baumchen 1 Quote Share this post Link to post Share on other sites
piisfish 140 #3 June 22, 2022 Colin in Empuriabrava has built a couple for me (years ago) Quote Share this post Link to post Share on other sites
rem 0 #4 June 24, 2022 with pin, ok, but, the yellow or gray one, since ~1996 ? or black and pink one, before 96, and with snap in white plastic ? Quote Share this post Link to post Share on other sites
JerryBaumchen 1,468 #6 June 25, 2022 On 6/22/2022 at 10:20 AM, JerryBaumchen said: Hi Dimintrilp, You will probably have to have someone make a set for you. I realize you are in Europe, but one option would be to contact Jump Shack. They make both normal toggles & the pins for the PdF style of toggle. I no longer have a photo of the PdF style of toggle. Try to get a photo to go along with any inquiry you might make to Jump Shack. Sport Containers - Parachute Laboratories, Inc. (plabsinc.com) Jerry Baumchen Hi Dimintrilp, Also, the PdF toggles are not made from the 'normal' 1" (25 mm) Type 4 webbing. They appear to be from 5/8" (15-17 mm) Type 4 webbing. See the photo above. Jerry Baumchen Quote Share this post Link to post Share on other sites
Deyan 36 #7 July 6, 2022 On 6/22/2022 at 12:14 PM, Dimitrilp said: Hello, does anyone have a PARACHUTE DE FRANCE a toggles, the one with the pin. Thank you I have them, and can also make you a pair! However, I HIGHLY recommend you get rid of the reversed 3 ring risers. Here's why! https://www.youtube.com/watch?v=z9RHMQZTSGQ 1 Quote Share this post Link to post Share on other sites
