5 5
cmercha
Turn Altitude Start
  On 6/21/2022 at 12:53 AM, cmercha said:
I'm curious at what height everyone starts their turns (270 and greater)?  I think it would be interesting to hear how different WL and canopies influence people's preferences, in addition to other factors.
I think the variability is too high to get anything really useful out of it in a forum. Besides accounting for WL and canopy, you have to consider the altitude of the dropzone and the speed of the turn (are people snapping the turn or doing a slow controlled turn whipping it at the end?). And of course the style of turn (just fronts, just harness, both, rears). Also some people start with double fronts before they turn. Which altitude do you take there, when you start doing double fronts or when the turn actually starts?
For what is worth I turn between 900 and 650 feet on my Gangster 90 at around 2.05 WL. When I am late I make a much quicker turn than when I am early on that range. At 900 feet I am hanging on double fronts and start turning with harness and fronts. The last 90° are quicker than the first 180.
680 for a 270 on my VC96 loaded at 2.1. It’s worth noting that, due to some perfect intersection of short risers, short body, turn mechanics, etc, I always tend to be turning lower than people on similar canopies and wing loadings so most definitely don’t be taking my heights as an example of where to turn. I’m in the turn for 8 seconds.
Edited by base615
Meaningless number really. Given everything else is the same (density altitude, heat etc), it depends on what you mean by "starting your turn" and what your turn looks like.
My initiation point is Xft with a brake surge from full flight but I have no idea what altitude I actually start pulling on my fronts. I just make sure I do the same thing every time.
Also depends whether you're turning efficiently or allowing the canopy to recover during the turn. I could stay on double-fronts for too long for example and my turn altitude might change but my max speeds would be lower.
I know from FlySight data that I can't start higher than 840ft on a VE84 at 2.3 without dragging it out of the sky. I'll always prefer being a touch lower than higher (guarantee the first jump of the day when conditions are unknown and then creep it up as the day goes on).
Edited by hodges
  • Like 1
When I started on my 96 Velo it was at roughly 700ft. As I got progressively more confident and grew the turn I managed to get it to 1000ft. Above 1000ft I found that I needed to go to a bigger turn but funnily enough I found that with my size and experience the 270 was good enough and the 450 gave me minimal additional benefits. I will add that I did not use harness all that much on the 270
5 5
