QuoteHorse shoe and PC in tow are probably the 2 mals I am most afraid of.
As long as we are draging out dead horses to beat, you've just pointed out my reason for choosing a pullout for the last 2200+ jumps.....
lazerq3 0
QuoteThe best way to deal with any malfunction is to avoid it. Maintain your equipment, pack it properly and get a real gear check before exit
Plus while I respect your reply and yes you are 100% right,, the truth is that doesnt happen , I mean yes poeple maintain there gear and do gear checks but unfortunalty shit happens and so do mals or else we wouldnt need to practice our drills!!
jason
Ron 10
QuoteAs long as we are draging out dead horses to beat, you've just pointed out my reason for choosing a pullout
It seems it still CAN happen..I don't know how, but it did.
Lets not let this get into a PUD/Pullout debate...
Both have issues, and both have benefits.
Yes a PUD should not have a PC in tow, but a lost PUD is something a BOC will not have.
Quote3: A jumper with a new rig, and a new pull out system was jumping with her team, at break off, she
tried to deploy, and her pull out was misrouted, this is the hard to understand thing somehow she got
her pc out of the container but the container was locked. The jury is out on if she beat her cypress or
not, but it fired, and she landed about 20 feet away from her handles and freebag, extremely shaken.
Lesson learned, she had the same exact problem a week later and wasted no time cutting away and
pulling her reserve. She now jumps a BOC design, but the pull out isnt to blame, Jumpers should check
their gear, and Packers should know how to close the gear the right way.
rjf98 0
		The first time, I don't know why, but without even thinking about it I reached back, grabbed my bridle, and gave it a tug. It all happened really fast in one motion. It fixed the PC in tow, but it also flipped me over and my dbag bounced right over my side. Canopy opened fine with a couple linetwists.
The second time, my hands went right to the cutaway handle. As soon as I touched it the main opened. Whew.
So I'm not saying what the right thing to do is. I'm just saying what I
Dave
Scrumpot 1
QuoteIf you argue that the reason for the tow may involve a PC that is not fully cocked or for some reason not performing fully, then the reduced tension may indeed matter, and then it is important to evaluate whether the risk of entaglement/pulling up the reserve slider/etc. is greater as the main departs (cut away) or during simultaneous deployment (not cutting away).
What do you think?
Chances are, that under THIS scenario, once the reserve has inflated and you are now vertical in attitude, if the pin now somehow did either fall out or get pulled (if PC drag force was insufficient at terminal, it certainly now is going to be much less once UNDER your reserve) ...Most likely the d-bag is instead going to merely drop out of the container, rather than pull to line-stretch & begin to inflate. I have actually seen this happen just this way too, BTW.
I am for "if you KNOW you have pitched something" then don't take the time second guessing it... Pull cut-away, pull Silver. If on the other hand you KNOW you have put NOTHING into the wind (like an unfind-able hackey buried into the spandex) then go straight to Silver. There's pro's & con's to differing opinions & this one is just mine. Personal decision (thought out in ADVANCE) based upon weighing risk/reward consequences & potentialities scenarios (and personal gear/configuration choices too) that go along with that.
My .02
BSBD,
-Grant
And after listening to a well respected AFFI do a recurrency training with someone else, when I could not clear the second PIT, I did not cut away.... I ended up in exactly this scenerio:
QuoteWhen the reserve comes out and relieves the pressure on the main tray, allowing the main to come out during your reserve deployment.
I was lucky as hell. My reserve bridle/freebag tangled with my main bridle. The canopies opened simultaneously. With plenty of altitude, I played with both out for a bit, then downplaned and cut away the main.
I got an ass chewing for not cutting away first, but it created a discussion, and now all the instructors at our DZ will be on the same page--Cut Away a Pilot chute in tow.
tbrown 26
I'm just happy things worked out and you opened. Somebody we knew went in twenty some years ago trying to fine tune a PC in tow. You've barely got 10 seconds for something that absolutely has to work. The smart money is still on the handles.
Your humble servant.....Professor Gravity !
bclark 0
Nice thing about PC in tows is that if you cock your pilot chute, maintain your gear, and do proper gear checks you will probably never have one.
Duhh...Really?
When people look like ants - pull. When ants look like people - pray.
