Fall0ut 3 #1 Posted June 6, 2021 I'm in the market for a new pilotchute, since my standard Mirage PC with longer bridle has well over 900 jumps on it and openings with larger wingsuits tend to be slower than I like. What size and type of PCs are you using for wingsuiting and "normal" jumps ? Squirrel's SkySnatch doesn't seem so bad but a bit pricey Quote Share this post Link to post Share on other sites
BMAC615 209 #2 June 6, 2021 The type matters less than size - which is determined by D-bag/canopy heft. I’m using a Sunpath 33” F-111 w/ 9’ bridle to pull my Epicene 190 out of my Aurora container. 1 Quote Share this post Link to post Share on other sites
davenuk 8 #3 June 7, 2021 I use a standard Mirage bridle and PC that have well over 1000 jumps for both WS and Other, no issues so far. 1 Quote Share this post Link to post Share on other sites
skydiverek 63 #4 June 7, 2021 Material: F-111 Diameter: 30-inch Bridle length: 9 feet (from pin to pilotchute) 1 Quote Share this post Link to post Share on other sites
birdynamnam 28 #5 June 7, 2021 Squirrel SkySnatch 30" or have a look at the new Aerodyne Extractor which is almost identical to the SkySnatch design. These evolved designs comes with kill-line ready to be mounted and are a lot better than the normal standard ones that comes with a container. But in general size >= 30", 8-9" kill-line, fresh f-111 fabric (beware of f-111 material getting worn very quickly) or rather just go for ZP (superior durability and best choice) 1 Quote Share this post Link to post Share on other sites
lyosha 50 #6 June 8, 2021 23 hours ago, birdynamnam said: Squirrel SkySnatch 30" or have a look at the new Aerodyne Extractor which is almost identical to the SkySnatch design. These evolved designs comes with kill-line ready to be mounted and are a lot better than the normal standard ones that comes with a container. But in general size >= 30", 8-9" kill-line, fresh f-111 fabric (beware of f-111 material getting worn very quickly) or rather just go for ZP (superior durability and best choice) I'll second the snatch. If you're going to get a new PC, snatch is probably top of class. Marginally better than F-111. But in my experience, the bridle length plays a more critical factor than PC material or shape, so you'll be fine with anything so long as you have enough bridle for your PC to reach clean air. 1 Quote Share this post Link to post Share on other sites
BMAC615 209 #7 June 8, 2021 (edited) Here’s a Video by Squirrel that explains why they design the Snatch the way they do. Edited June 8, 2021 by BMAC615 Quote Share this post Link to post Share on other sites
RolandForbes 44 #8 June 15, 2021 32'' ZP Icarus pilot chute for me. It's worked well with a relatively large surface area suit (Freak3). That suit flares so damn well though that I think going up to a 34 or 36 may be in order soon. Quote Share this post Link to post Share on other sites
