David Wang 78 #1 Posted January 21, 2020 (edited) hey guys, I just finished 10min tunnel session at iFLY Oceanside and learned how to turn. Basically I just turned like an airplane in the tunnel. I showed my videos to my Perris instructors and then they said it's a bit different in the real air and I don't turn like that. So how to turn? I'm confused. When I asked them why they said it's hard to explain. Edited January 21, 2020 by David Wang Quote Share this post Link to post Share on other sites
ksmaximums 0 #2 January 21, 2020 I got way more time. In a Windtunnel than freefall time. An I can't tell the difference. Quote Share this post Link to post Share on other sites
David Wang 78 #3 January 21, 2020 1 hour ago, ksmaximums said: I got way more time. In a Windtunnel than freefall time. An I can't tell the difference. Hmm ....interesting man. Quote Share this post Link to post Share on other sites
Binary93 65 #4 January 21, 2020 What do you mean "like an airplane"? Could you explain in a bit more detail? I'm guessing you learned to turn with your arms while "the real stuff in the real air" is with your legs, or some similar comment. Again, just speculating on the meaning intended, otherwise air in the sky is pretty much the same (just a lot wider and with a bit less points you can look at for reference). Quote Share this post Link to post Share on other sites
sfzombie13 324 #5 January 21, 2020 i did a half hour in the tunnel at ifly in cincinatti, and they used real air inside. i then took my newly found skills to an airplane and jumped out (actually just let go of the strut, but whatever) and did the exact same thing and it worked just like it did in the tunnel. i am not an instructor however, and you should take anything i say accordingly. i have been trying to fly flat and stable in the air for years and only learned after the tunnel. turns out it was my leg position and since i was only in the air by myself would have taken a much longer time figuring it out on my own. when i went to the tunnel, i told them i was a skydiver needing to learn how to be stable and they put the airspeed on 120 the whole time. maybe that is what the instructors were talking about, as they usually (from what i have heard and read) lower the speed for "indoor flying" or whatever they call flying for fun. Quote Share this post Link to post Share on other sites
betzilla 56 #6 January 21, 2020 There are lots of different ways to turn, and lots of different ways to teach turns. Your instructors at Perris probably intend to teach you a different way of initiating and stopping turns than what you learned in the tunnel. Just make a good-faith effort to do what they're teaching you, and don't overthink it. Quote Share this post Link to post Share on other sites
wolfriverjoe 1,523 #7 January 21, 2020 #1 - Don't overthink it. That's really easy to do and you seem to do that some (not a criticism, just an observation). #2 - If you are stable on your belly in the tunnel, you are headed in the right direction. Keep in mind that's all you need to do a release dive (level 3?) Turns come later. I'm guessing your 'turn like an airplane' is dipping a shoulder and having that make you turn. It works, but there are better ways. As your instructors noted, it's kind of hard to explain. Turns using your arms & legs will be more controllable, more efficient and have less of an effect on your fall rate. Do you know what speed they were running the tunnel at? I don't have a whole lot of tunnel time, but I tend to run the tunnel a good bit slower than 'real' freefall. Partly because if I'm alone in the tunnel, I don't have to keep down with other jumpers. I tend to fall pretty slow. 1 Quote Share this post Link to post Share on other sites
David Wang 78 #8 January 21, 2020 28 minutes ago, wolfriverjoe said: #1 - Don't overthink it. That's really easy to do and you seem to do that some (not a criticism, just an observation). #2 - If you are stable on your belly in the tunnel, you are headed in the right direction. Keep in mind that's all you need to do a release dive (level 3?) Turns come later. I'm guessing your 'turn like an airplane' is dipping a shoulder and having that make you turn. It works, but there are better ways. As your instructors noted, it's kind of hard to explain. Turns using your arms & legs will be more controllable, more efficient and have less of an effect on your fall rate. Do you know what speed they were running the tunnel at? I don't have a whole lot of tunnel time, but I tend to run the tunnel a good bit slower than 'real' freefall. Partly because if I'm alone in the tunnel, I don't have to keep down with other jumpers. I tend to fall pretty slow. 7 hours ago, Binary93 said: What do you mean "like an airplane"? Could you explain in a bit more detail? I'm guessing you learned to turn with your arms while "the real stuff in the real air" is with your legs, or some similar comment. Again, just speculating on the meaning intended, otherwise air in the sky is pretty much the same (just a lot wider and with a bit less points you can look at for reference). C7F6232F-A4E4-47D9-9DF7-188DB8B1653C.MOV Quote Share this post Link to post Share on other sites
David Wang 78 #9 January 21, 2020 Hope you guys can see the video. I uploaded in non-WiFi environment.... that video shows I turned “like an airplane” lol. Dig one arm and let the air do the rest of the work. I won’t overthink and will just do what my instructor teaches me in the air. Some of my instructors say the tunnel and the air are the same but some of then are not. Some of them teach me to turn like an airplane but some of them are not hahaha. 42 minutes ago, wolfriverjoe said: Do you know what speed they were running the tunnel at? I don't have a whole lot of tunnel time, but I tend to run the tunnel a good bit slower than 'real' freefall. Partly because if I'm alone in the tunnel, I don't have to keep down with other jumpers. I tend to fall pretty slow. Yes, the tunnel speed was slower than actual freefall speed I guess. Not sure tho. Quote Share this post Link to post Share on other sites
David Wang 78 #10 January 21, 2020 1 hour ago, betzilla said: There are lots of different ways to turn, and lots of different ways to teach turns. Your instructors at Perris probably intend to teach you a different way of initiating and stopping turns than what you learned in the tunnel. Just make a good-faith effort to do what they're teaching you, and don't overthink it. Yes, thanks. I will just do what they teach in the Sky. Quote Share this post Link to post Share on other sites
David Wang 78 #11 January 21, 2020 7 hours ago, Binary93 said: What do you mean "like an airplane"? Could you explain in a bit more detail? I'm guessing you learned to turn with your arms while "the real stuff in the real air" is with your legs, or some similar comment. Again, just speculating on the meaning intended, otherwise air in the sky is pretty much the same (just a lot wider and with a bit less points you can look at for reference). So you think tunnel and the real air are the same? Quote Share this post Link to post Share on other sites
gowlerk 2,309 #12 January 21, 2020 14 minutes ago, David Wang said: C7F6232F-A4E4-47D9-9DF7-188DB8B1653C.MOV I hate you for being young, thin, and flexible enough to arch like that. Just kidding, sort of! Just keep jumping, you'll do fine. Your instructors will cope. 1 Quote Share this post Link to post Share on other sites
David Wang 78 #13 January 21, 2020 17 minutes ago, gowlerk said: I hate you for being young, thin, and flexible enough to arch like that. Just kidding, sort of! Just keep jumping, you'll do fine. Your instructors will cope. My lower back hurts now lol!! thanks for your encouragement. I will keep jumping for sure! Quote Share this post Link to post Share on other sites
Binary93 65 #14 January 21, 2020 50 minutes ago, David Wang said: Yes, the tunnel speed was slower than actual freefall speed I guess. Not sure tho. You take the same posture you'll fall pretty much the same speed as in the tunnel. The only differences (why you'll fall slightly faster up there) are due to air density difference but that doesn't make any big difference (after all, it affects everyone else the same way). And given your extreme ability to arch, I'm sure you'll have a wide range of fall speeds to choose after some practice. As others already said, keep up, listen to your instructors, you'll do just fine :) 1 Quote Share this post Link to post Share on other sites
David Wang 78 #15 January 21, 2020 3 hours ago, sfzombie13 said: i did a half hour in the tunnel at ifly in cincinatti, and they used real air inside. i then took my newly found skills to an airplane and jumped out (actually just let go of the strut, but whatever) and did the exact same thing and it worked just like it did in the tunnel. i am not an instructor however, and you should take anything i say accordingly. i have been trying to fly flat and stable in the air for years and only learned after the tunnel. turns out it was my leg position and since i was only in the air by myself would have taken a much longer time figuring it out on my own. when i went to the tunnel, i told them i was a skydiver needing to learn how to be stable and they put the airspeed on 120 the whole time. maybe that is what the instructors were talking about, as they usually (from what i have heard and read) lower the speed for "indoor flying" or whatever they call flying for fun. 25 minutes ago, Binary93 said: You take the same posture you'll fall pretty much the same speed as in the tunnel. The only differences (why you'll fall slightly faster up there) are due to air density difference but that doesn't make any big difference (after all, it affects everyone else the same way). And given your extreme ability to arch, I'm sure you'll have a wide range of fall speeds to choose after some practice. As others already said, keep up, listen to your instructors, you'll do just fine :) Thank you both of you! air density! that's physics lol! Quote Share this post Link to post Share on other sites
betzilla 56 #16 January 21, 2020 36 minutes ago, Binary93 said: The only differences (why you'll fall slightly faster up there) are due to air density difference but that doesn't make any big difference (after all, it affects everyone else the same way) you'll also be wearing thirty pounds of parachute gear. That'll make you fall faster. 3 Quote Share this post Link to post Share on other sites
David Wang 78 #17 January 21, 2020 2 hours ago, betzilla said: you'll also be wearing thirty pounds of parachute gear. That'll make you fall faster. yupp 1 Quote Share this post Link to post Share on other sites
Nabz 30 #18 January 22, 2020 22 hours ago, David Wang said: C7F6232F-A4E4-47D9-9DF7-188DB8B1653C.MOV You look really stable, especially for only having a few jumps under your belt. As mentioned just go with the flow and you will do fine 1 Quote Share this post Link to post Share on other sites
David Wang 78 #19 January 22, 2020 7 hours ago, Nabz said: You look really stable, especially for only having a few jumps under your belt. As mentioned just go with the flow and you will do fine ok Quote Share this post Link to post Share on other sites
piisfish 140 #20 January 24, 2020 On 1/21/2020 at 6:35 PM, betzilla said: you'll also be wearing thirty pounds of parachute gear. That'll make you fall faster. and also it will modify your center of gravity, and limit your ability to arch. Pretty serious arch man, congratulations. As mentioned above, I am also jealous of that one. I still feel pretty young, and am rather thin, but flexible like an ironing board. keep on like that, have fun, you are just at the beginning of an adventure. Quote Share this post Link to post Share on other sites
David Wang 78 #21 January 25, 2020 22 hours ago, piisfish said: and also it will modify your center of gravity, and limit your ability to arch. Pretty serious arch man, congratulations. As mentioned above, I am also jealous of that one. I still feel pretty young, and am rather thin, but flexible like an ironing board. keep on like that, have fun, you are just at the beginning of an adventure. absolutely a great adventure ahead of me! thanks buddy! Quote Share this post Link to post Share on other sites
timski 80 #22 January 25, 2020 My take on where you find yourself: The tunnel is great to refine and to learn new disciplines, BUT unless one of your AFF instructors tells you that you NEED tunnel time, stop wasting that money. Get checked off and get that A license. On a side note, the other day I over heard a student tell the instructor that she didn't think it was good to look first in the direction BEFORE starting the flat turn, because I guess in her mind that caused instability. So just go into it blindly??? If your NOT a strong instructor who can be FIRM and educated people correctly, please do something else with your time. That being said Mr Wang, be a good student, if and when something doesn't sound right or safe, by all means question it. BUT also know when to listen and follow simple instructions. Excuse me while I step down off the soap box! 1 Quote Share this post Link to post Share on other sites
Remster 30 #23 January 26, 2020 (edited) On 1/25/2020 at 3:11 PM, timski said: On a side note, the other day I over heard a student tell the instructor that she didn't think it was good to look first in the direction BEFORE starting the flat turn Are you talking freefall, or canopy? Because in freefall (and that's what we've been talking about), you definitely do not want to look where you're going when turning. Edited January 26, 2020 by Remster Quote Share this post Link to post Share on other sites
timski 80 #24 January 28, 2020 yeah, FF. So just turn blindly huh? I'll just keep flying solo wingsuit, where I feel somewhat safer. Quote Share this post Link to post Share on other sites
daffes 4 #25 January 28, 2020 That's a strong arch buddy, I imagine you could surprise an instructor with it haha! A faster fall rate allows you to turn effectively with a smaller input, usually, in AFF, things happen in a more "slow motion" way. Don't sweat, you'll be fine. 1 Quote Share this post Link to post Share on other sites
