dthames 0
What Billvon listed comes directly from NZ Aerosports,
Proof:
http://www.nzaerosports.com/massive-information/downsizing-checklist
I do not think anyone should attempt high performance landings before attending a few canopy courses
And I would add, it is very hard to do anything "double front" if you are loaded light. Well, chin-ups would be an exception.
Instructor quote, “What's weird is that you're older than my dad!”
Maddingo 21
I woud disagree, it all comes to strength on lighter wingloads. I was able to do a 360 in the air with a 190 on fronts. But yeah now at 150 the pressure is half that if not more.
The only thing I could do with front risers on the navigator was a pull up.
Now, some questions for you. You don't have to give me the answers, but you should know them.
1 - What is your wingloading on the 190? On the 170? Keep in mind that wingloading is your weight, when fully geared up, divided into the size of the canopy in square feet.
2 - You say you PLF a lot of your landings. Why? Bad flare timing, bad height judgement (similar, but not the same), bad flaring technique, inability to flare properly (again, similar but not the same), inability to run out the landing (lots of reasons for that), simple fear (when you PLF landings you could have stood up).
The idea of getting video of your current landings and having an instructor critique them is a good one. Some canopy courses include this.
3 - How good is your canopy control other than the landing? How is your pattern, approach, all that?
4 - How was the 190 to fly and land? Was it 'scary fast'? Did it feel like you were almost out of control?
When I got my first rig, I went from a Manta 288 to a 190 Triathlon. Nothing between. But the Tri was only loaded at 1:1. I had been making consistent landings under the Mantas, good patterns and good, on target, stand up landings. The Mantas ranged from almost new to almost totally ragged out. Some had a nice, strong flare, some you flared as hard as you could a bit higher than usual and hoped it slowed down before you hit the ground.
Although it was a pretty big 'leap', the transition wasn't all that difficult. I picked a day with moderate, steady winds to land into. I did a high pull and practiced my flares a bunch. It worked out well for me. I never had any real problems with it. But, again, it was a conservative wing loading and a fairly big canopy, despite being a 'big jump.']
