Twoply 0 #1 December 29, 2017 I'm fabricating a little something and I need a very specific pulley. Problem is my vocabulary is lacking. I need this portion of the shaft to be exactly 2 3/8". What is this portion of the pulley referred to as? Quote Share this post Link to post Share on other sites
flyhi 24 #2 December 29, 2017 Axle?Shit happens. And it usually happens because of physics. Quote Share this post Link to post Share on other sites
wolfriverjoe 1,523 #4 December 29, 2017 I'm gonna go with "Hub", maybe "integral hub", since it seems to be cast as one piece along with the wheel."There are NO situations which do not call for a French Maid outfit." Lucky McSwervy "~ya don't GET old by being weak & stupid!" - Airtwardo Quote Share this post Link to post Share on other sites
Twoply 0 #5 December 29, 2017 Thanks guys! i need that long hub/ axle to be be forged together/ when integrated internet the pulley wheel. Quote Share this post Link to post Share on other sites
muff528 3 #6 December 30, 2017 sleeve or connecting sleeve. (integral connecting sleeve?) Quote Share this post Link to post Share on other sites
piisfish 140 #7 December 30, 2017 ARE you building a concrete rebound hammer?scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
Niki1 2 #8 December 30, 2017 I'm going to guess Bushing for the axle. The 2 female screw inserts look like that is fastened to something else. The axle appears to be inserted into that. OR the inserts are for set screws to fix the pulley (channel wheel?) axle to the large hub in which case the hub would be an enlarged extension of the axle. This probably makes no sense whatsoever but it's not the first time I've done this.Most of the things worth doing in the world had been declared impossilbe before they were done. Louis D Brandeis Where are we going and why are we in this basket? Quote Share this post Link to post Share on other sites
oldwomanc6 60 #9 December 30, 2017 piisfish ARE you building a concrete rebound hammer? lisa WSCR 594 FB 1023 CBDB 9 Quote Share this post Link to post Share on other sites
rmsmith 1 #10 December 30, 2017 Since that pulley will be rotating with the shaft it is likely that the shaft and pulley share a key way. Do a search for "keyed shaft and pulley" in the image area. Quote Share this post Link to post Share on other sites
akarunway 1 #11 December 30, 2017 pully axle or shaft. I hold it true, whate'er befall; I feel it, when I sorrow most; 'Tis better to have loved and lost Than never to have loved at all. Quote Share this post Link to post Share on other sites
david3 0 #12 December 30, 2017 wolfriverjoeI'm gonna go with "Hub", maybe "integral hub", since it seems to be cast as one piece along with the wheel. +1 integral hub Quote Share this post Link to post Share on other sites
dpreguy 14 #13 January 1, 2018 It is not a bushing, as a bushing is internal and is a bearing surface. A bushing is typically installed to reduce the diameter of the hole a shaft goes into. It is not an axle, as an axle is the shaft that a wheel or pully turns around. It is not a shaft. It is a device that slips over a shaft. I think that part of the drawing is best described as a sleeve with threaded set screw holes. (As a sleeve "slips over somethng".) Quote Share this post Link to post Share on other sites
ControlFreak 0 #14 January 3, 2018 Hub. And try "sheave" instead of "pulley".Alcohol never really solved any problems. But then again, neither did milk. Quote Share this post Link to post Share on other sites
david3 0 #15 January 4, 2018 ControlFreakHub. And try "sheave" instead of "pulley". +1 Ding ding ding! We have a winner. It is a sheave with a hub (integral hub). Quote Share this post Link to post Share on other sites
