Elpnor 5 #1 September 2, 2018 Does anyone know if someone still makes dome sliders? I'm having hard openings, and need to slow them down a bit. I've read all the info out there that I could find, including John Leblancs bit, and I don't think it's my packing technique. It's happened when I pack, and a packers pack job as well. I'm kicking around getting a bigger slider, and I've contacted pd about it and am waiting to chat with them, but I thought I'd try herd wisdom as well. It's a sabre 2 230. I'm a bigger guy with a faster fall rate, but not horrific. I double wrap all my stows, and replace the locking stows that show even a little wear. I have 700 jumps, so I don't think it's body position. Quote Share this post Link to post Share on other sites
peek 21 #2 September 2, 2018 Unlike the original Sabre, the Sabre 2 is noted for opening well if packing is done well, and I have not heard of one needing a larger slider. Line trim will need to be checked first. You might need to send it to PD to test jump. To all: Does anyone know someone who has installed a larger slider on a Sabre 2? Quote Share this post Link to post Share on other sites
billvon 3,170 #3 September 2, 2018 >To all: Does anyone know someone who has installed a larger slider on a Sabre 2? Nope. I went through a lot of funky sliders for a few Sabre 1's (dome slider, pocket slider, bigger slider) but I've never seen one on a Sabre 2 or its relations by other manufacturers (Safire, Pilot.) Quote Share this post Link to post Share on other sites
JerryBaumchen 1,489 #4 September 3, 2018 Hi Elpnor, QuoteDoes anyone know if someone still makes dome sliders? The last that I knew, Mark Lancaster ( MEL on here ) still makes them. Give him a try, Jerry Baumchen Quote Share this post Link to post Share on other sites
Westerly 61 #5 September 3, 2018 I think it's more complicated than just adding a larger slider. I am not an expert so I could be wrong, but I was speaking to a canopy manufacturer (specificaly, the guy who designs canopies), and he mentioned that there are several factors that affect opening shock, the slider only being one of them. The position of the brakes and even the length each of the individual lines can have an effect. The trim of the canopy can have a large effect. There was a post on here about someone getting slammed under a Safire 3, and they found out just one group of lines was out of trim a bit which was causing the hard openings. As it was explained to me, while a larger slider does have more surface area to keep the slider up, it also allows the canopy to expand more while snivling so it might not yield a softer opening. It depends on the types of hard openings we're talking about. Is it the type where the opening is hard because the slider is coming down way too soon and you're getting slammed, or the type where the canopy just opens hard while snivling? If slider size was the only thing that affected opening shock, then hard openings should be completely non-existent on tandem canopies and extremely common on tiny crossbrased canopies, but neither of those statements are necessarily true. Quote Share this post Link to post Share on other sites
Elpnor 5 #6 September 3, 2018 I don't think it's the trim of the lines. This is a fairly new sabre 2 with maybe 30 jumps. Not all openings are hard, but most are hardish. The reason a dome slider is appealing is it would seem to give more surface area for the air to push up against, but not allow a the lines to spread out more that a significantly larger slider would. I think the main cause is larger body, faster speeds, equal more force on the lines and that just shoots the slider down. I need that little piece of life saving fabric to hang up there for a moment and give me some love. Quote Share this post Link to post Share on other sites
DBCOOPER 5 #7 September 3, 2018 Just curious as to how fast your falling and what is the wing loading?Replying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites
RMURRAY 1 #8 September 3, 2018 actually 'masterrigger1' here. a true expert. Quote Share this post Link to post Share on other sites
fluffyduckie 6 #9 September 3, 2018 Given that the canopy is that new, and giving you consistent hard openings, you should contact PD. Even though their manufacturing procedures are exceptionally consistent, some times a canopy simply doesn't perform to the correct standard. There is no reason to turn yourself into a test jumper. Contact the repairs department and explain the issue. If they can't resolve the issue with a repair, they will replace the canopy. If you ask nicely, they may even help you out with a demo while they are evaluating your main. PD prides themselves on their customer service. Take advantage of that fact."I love when humans fly," Quote Share this post Link to post Share on other sites
JerryBaumchen 1,489 #10 September 3, 2018 Hi Rob, Quoteactually 'masterrigger1' here. You are correct; my bad. Here is his contact info: Mark Lancaster Skyworks Parachute Service 2222 Buffalo – West Springs HiWay Buffalo, SC 29321 864-429-8428 skyworksparasvc@aol.com Jerry Baumchen Quote Share this post Link to post Share on other sites
glh 4 #11 September 3, 2018 I have had a brand new canopy sent back to the manufacturer for hard openings that was condemned by them and I was giving another new canopy in exchange. Quote Share this post Link to post Share on other sites
BIGUN 1,520 #12 September 3, 2018 billvon>To all: Does anyone know someone who has installed a larger slider on a Sabre 2? Nope. I went through a lot of funky sliders for a few Sabre 1's (dome slider, pocket slider, bigger slider) but I've never seen one on a Sabre 2 or its relations by other manufacturers (Safire, Pilot.) I am one. When the Safire 2's first came out; I was having hard openings (189). They said they knew exactly what was wrong and had me measure the slider's length/width/diagonal just to make sure and exchanged my slider for a larger one. Problem Solved.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
Elpnor 5 #13 September 4, 2018 I just looked at my viso 2. It says fall rate was 134. Fast, but not ungodly. I was doing a sitfly and had transitioned to belly and tracked away from the guy I was jumping with. I flattened out for maybe 4 seconds before pulling. Wing loading is 1.25 Quote Share this post Link to post Share on other sites
Westerly 61 #14 September 4, 2018 ElpnorI just looked at my viso 2. It says fall rate was 134. Fast, but not ungodly. I was doing a sitfly and had transitioned to belly and tracked away from the guy I was jumping with. I flattened out for maybe 4 seconds before pulling. Wing loading is 1.25 Here is a video for you. Take from it what you want. https://www.youtube.com/watch?v=zCM-eAekMCg Quote Share this post Link to post Share on other sites
betzilla 56 #15 September 4, 2018 QuoteThere is no reason to turn yourself into a test jumper. Contact the repairs department and explain the issue. If they can't resolve the issue with a repair, they will replace the canopy. PD prides themselves on their customer service. Take advantage of that fact. This right here. Quote Share this post Link to post Share on other sites
LeeroyJenkins 3 #16 September 4, 2018 Westerly***I just looked at my viso 2. It says fall rate was 134. Fast, but not ungodly. I was doing a sitfly and had transitioned to belly and tracked away from the guy I was jumping with. I flattened out for maybe 4 seconds before pulling. Wing loading is 1.25 Here is a video for you. Take from it what you want. https://www.youtube.com/watch?v=zCM-eAekMCg Dammmnnnn those Safire openings were slow and crappy. Quote Share this post Link to post Share on other sites
finchaos 0 #17 September 5, 2018 Can someone comment on the impact of line length and hard openings? Quote Share this post Link to post Share on other sites
Elpnor 5 #18 September 11, 2018 So PD is sending me a dome slider. I am surprised they make them. I thought it would be more likely that they'd try a larger slider. But first they are going to have a test jumper jump that sized sabre 2 with what my loading would be. Some poor schlub will have to put on like maybe 40 pounds of lead and take it to terminal, and hope it's a nice opening. I hope I don't make him shorter. I'm very impressed with PD on this one, and look forward to softer openings with my one cup brassiere of a slider Quote Share this post Link to post Share on other sites
Elpnor 5 #19 October 19, 2018 I finally jumped my dome slider today. Huge improvement. Three ff jumps, all 130 mph or so openings, all soft as a high pull. I'm thrilled. Any big guys out there experiencing hard openings might want to look into it. Same sized slider, but more surface area, and it cups the air a bit. Opening seemed about as long, maybe a touch more. The other problem I have is the slider coming down over my toggles on a standard riser. No one makes the pilgrim hats for normal risers. I wished they did. I'm thinking about having a local sew shop make me some. Quote Share this post Link to post Share on other sites
gowlerk 2,303 #20 October 19, 2018 QuoteNo one makes the pilgrim hats for normal risers. Just use regular Slink hats mounted upside down. Quote Share this post Link to post Share on other sites
riggerrob 644 #21 October 19, 2018 I have installed PD “pilgrim hats” on wide(1 23/32”) Type 8 risers. It took a bit of wiggling, but they worked fine. Quote Share this post Link to post Share on other sites
Elpnor 5 #22 October 19, 2018 Really? they don't look like they'd fit, but I'll try it. Quote Share this post Link to post Share on other sites
skydiverek 65 #23 October 19, 2018 gowlerkQuoteNo one makes the pilgrim hats for normal risers. Just use regular Slink hats mounted upside down. I did that. Has worked great for over 1000 jumps ! Quote Share this post Link to post Share on other sites
flyboy6554 3 #24 October 21, 2018 Thanks for the update.....Just borrowed a domed slider from Aerodyne for my Nitron 170 but haven't tried it out yet. Quote Share this post Link to post Share on other sites
flyboy6554 3 #25 November 4, 2018 OK...made three jumps today on a domed slider from Aerodyne (thanks Marcia!!).....it was sized for a Pilot 188 and just slightly larger in both dimensions than my current slider that came with my Nitron 170....but it was a domed version.....had significantly slower and buttery soft opening subterminal and a somewhat softer than normal opening at terminal....not a scientific study and no velocity data to back it up but think it was a winner for me. Quote Share this post Link to post Share on other sites
