Westerly 61 #1 September 6, 2018 It seems like literally the worst possible choice for a canopy. The lines can go hugely out of trim, the material is fairly slippery (which theoretically could encourage a quick drop of the slider when you dont want it), and it's completely inelastic. If low bulk is the goal, why not use Vectran or HMA? What does Spectra do that the other two dont? Vectran and especially HMA dont go wickedly out of trim like Spectra does, but offer most of the same benefits. I think someone said that Spectra lasts longer, but it doesent last longer if the canopy goes way out of trim. Even if the lines were in perfect condition you would still need to replace them if they are too far out of trim. It seems like HMA is the most superior line choice at the moment. Quote Share this post Link to post Share on other sites
gowlerk 2,297 #2 September 6, 2018 QuoteWhat does Spectra do that the other two dont? Resist wear and UV light damage. It is far less likely to break when worn. Line choice is full of compromises. Some, especially larger lightly loaded canopies are less affected by being out of trim. Quote Share this post Link to post Share on other sites
Deimian 43 #3 September 6, 2018 gowlerkQuoteWhat does Spectra do that the other two dont? Resist wear and UV light damage. It is far less likely to break when worn. Line choice is full of compromises. Some, especially larger lightly loaded canopies are less affected by being out of trim. What he said. Spectra is the strongest and longer lasting material. Big canopies fly just fine when out of trim. That's why you don't see spectra in smaller canopies, proper trim is key. In the middle range it is all a matter of preference. It is a trade off between durability and dimensional stability. If you are ok flying a wing that is not in its optimal shape, but you appreciate the peace of mind of the higher endurance of spectra, you use spectra. If you are diligent with maintenance and take care of your lines, and want your canopy to fly the the best it can, then you'd use HMA or Vectran. Quote Share this post Link to post Share on other sites
Maddingo 21 #4 September 6, 2018 Some companies don't use spectra at all anymore. Spectra is also cheap, so there is that financial aspect. Quote Share this post Link to post Share on other sites
RMURRAY 1 #5 September 6, 2018 perfect for reserves. Quote Share this post Link to post Share on other sites
Blis 1 #6 September 6, 2018 Deimian***QuoteWhat does Spectra do that the other two dont? Resist wear and UV light damage. It is far less likely to break when worn. Line choice is full of compromises. Some, especially larger lightly loaded canopies are less affected by being out of trim. What he said. Spectra is the strongest and longer lasting material. Big canopies fly just fine when out of trim. That's why you don't see spectra in smaller canopies, proper trim is key. In the middle range it is all a matter of preference. It is a trade off between durability and dimensional stability. If you are ok flying a wing that is not in its optimal shape, but you appreciate the peace of mind of the higher endurance of spectra, you use spectra. If you are diligent with maintenance and take care of your lines, and want your canopy to fly the the best it can, then you'd use HMA or Vectran. All the line materials last about the same, the difference is that spectra goes out of trim and others tend to break. Just because the line doesn't break does not mean it should not be replaced. NO line set is good for 500 jumps or more, reality is that around 400 jumps is the most you should do on a single line set... Quote Share this post Link to post Share on other sites
benlangfeld 1 #7 September 6, 2018 Spectra goes out of trim and your wing starts flying less efficiently/accurately over time. HMA looks great until the day half your lines break on opening. I know which I prefer. Quote Share this post Link to post Share on other sites
linestretch 0 #8 September 6, 2018 BlisAll the line materials last about the same, the difference is that spectra goes out of trim and others tend to break. Just because the line doesn't break does not mean it should not be replaced. NO line set is good for 500 jumps or more, reality is that around 400 jumps is the most you should do on a single line set... That really doesn't make sense at all. You can easily get 1000 jumps out of spectra (depending on the size of course)....not broken and canopy flying just fine. The openings might suck a bit but if the jumper is happy as a clam...then the lines are fine. HMA?....will just not last that long and will break. Big difference.my pics & stuff! Quote Share this post Link to post Share on other sites
Maddingo 21 #9 September 6, 2018 Interesting, I would not push beyond 500 on any type of lines. Max 400-500 jumps and they are gone. Why would you risk it? I've seen one pair of 500lb vectrans break at around 400 in the air not long ago and it was a sub terminal deployment. Fck that, just change them. Quote Share this post Link to post Share on other sites
linestretch 0 #10 September 6, 2018 It's your money...but I'm telling you 750 or 1000lbs spectra lasts a long ass time. You're trying to compare small vectran to spectra....you can't and the OP was about spectra.my pics & stuff! Quote Share this post Link to post Share on other sites
Maddingo 21 #11 September 6, 2018 I'm flying 750lbs vectran atm. Yea I know, but safety first right? Quote Share this post Link to post Share on other sites
Blis 1 #12 September 7, 2018 linestretch***All the line materials last about the same, the difference is that spectra goes out of trim and others tend to break. Just because the line doesn't break does not mean it should not be replaced. NO line set is good for 500 jumps or more, reality is that around 400 jumps is the most you should do on a single line set... That really doesn't make sense at all. You can easily get 1000 jumps out of spectra (depending on the size of course)....not broken and canopy flying just fine. The openings might suck a bit but if the jumper is happy as a clam...then the lines are fine. HMA?....will just not last that long and will break. Big difference. My reasoning behind this? Out of trim canopy is more likely to malfunction during the opening and/or high turbulence scenarios... I'd rather change my line set than risk a hard opening or collapsing canopy... Also I like my canopies to fly like intended, not out of trim. Quote Share this post Link to post Share on other sites
Deimian 43 #13 September 7, 2018 As mentioned before: that really depends on the canopy type and size. Quote Share this post Link to post Share on other sites
councilman24 37 #14 September 8, 2018 DACRON!!!Might save your neck of aorta.BTW spectra being slick is a good thing. I believe it mostly eliminated dacron tension knots. I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
