blueskies85 0 #1 January 25, 2018 Hey all, Is the Horizon from PD strictly for wingsuit jumps or can it be used for any and all disciplines? I mainly do tracking jumps but also fun jumps. I like the idea of a low bulk main and the Horizon seems to fit the bill. Will it be good for non wingsuit canopy rides? I want a canopy that will open, deploy on heading and be ok to fly. I don’t want much performance or swoops. Low pack volumes are more beneficial to me. Thanks Blueskies Quote Share this post Link to post Share on other sites
LeeroyJenkins 3 #2 January 26, 2018 Yeah, it will work. It is just a docile canopy. Quote Share this post Link to post Share on other sites
gowlerk 2,310 #3 January 26, 2018 You should know that it is mostly made from non ZP fabric and will not last as long as some others. PD says you can expect hundreds of jumps from it. ZP canopies last for a couple thousand. http://www.performancedesigns.com/docs/Horizon_FAQs.pdf Quote Share this post Link to post Share on other sites
shadeland 5 #4 January 26, 2018 LeeroyJenkinsYeah, it will work. It is just a docile canopy. It would seem that's not the case. Among other caveats from the FAQ: "For this reason, we recommend that you have at least 50 jumps on a canopy (landing accurately and comfortably on your feet) that is approximately two (2) sizes SMALLER than the Horizon you plan to use for wingsuiting." Also: "Performance Designs recommends utilizing the Horizon for the purpose that it was designed and developed for. This will help ensure that you get the best performance and longevity out of your Horizon while using it for wingsuiting." So, probably not a good choice for non-wing suiting given the OPs status as non-wingsuiter. PD does have the Silhouette, which is a lower pack volume main apprpriaate for general jumping and beginners (at the appropriate wing loading). For low bulk regular jumping, there's Aerodyne Pilot in ZPX (about a size smaller) and UltraLPV (maybe 2 sizes smaller, not sure). The same for the Pilot 7 (which is good for wing suiting, but Aerodyne says its also good for regular jumping). I've seen a few ZPXs around, but not the UltraLPV. Quote Share this post Link to post Share on other sites
jurgencamps 0 #5 January 29, 2018 blueskies85Hey all, Is the Horizon from PD strictly for wingsuit jumps or can it be used for any and all disciplines? I mainly do tracking jumps but also fun jumps. I like the idea of a low bulk main and the Horizon seems to fit the bill. Will it be good for non wingsuit canopy rides? I want a canopy that will open, deploy on heading and be ok to fly. I don’t want much performance or swoops. Low pack volumes are more beneficial to me. Thanks Blueskies If you read this http://www.performancedesigns.com/docs/Horizon_Flight_Characteristics.pdf, and more specific what they say about landings; you will understand that it is not an easy canopy to land. You can make good landings with the canopy, if you master that art. So, I think that the PD Pulse (the successor of the silhouette) is a better choice for you. Quote Share this post Link to post Share on other sites
timski 80 #6 January 29, 2018 blueskies85Hey all, Is the Horizon from PD strictly for wingsuit jumps or can it be used for any and all disciplines? I mainly do tracking jumps but also fun jumps. I like the idea of a low bulk main and the Horizon seems to fit the bill. Will it be good for non wingsuit canopy rides? I want a canopy that will open, deploy on heading and be ok to fly. I don’t want much performance or swoops. Low pack volumes are more beneficial to me. Thanks Blueskies Save some cash, get a Storm! I fly WS mostly but sprinkle in some other jumps... Great over all canopy. Quote Share this post Link to post Share on other sites
LeeroyJenkins 3 #7 January 29, 2018 Right, right, I forgot this was DZ.com. Let me rephrase. Yeah, it will work, but that doesn't mean its the best option. Quote Share this post Link to post Share on other sites
Unstable 9 #8 January 29, 2018 Quote If you read this http://www.performancedesigns.com/..._Characteristics.pdf, and more specific what they say about landings; you will understand that it is not an easy canopy to land. You can make good landings with the canopy, if you master that art. I have read this several times and while I understand it completely, the concept and principles appear to be a design heritage of a 7-cell, low permeability canopy tuned for better openings. Here are some blurbs from the link you posted. ---------------------------------------------------------- Quote The Horizon is a 7-cell rectangular canopy available in sizes 120-190 with roots coming from our Optimum Reserve. So a 7-cell low Perm canopy. Quote This canopy has a shorter snivel than other canopies in our line such as the Sabre2 or the Spectre. So a 7-cell low perm canopy tuned for slightly better openings. Quote The Horizon will not glide as far as some of our flatter trimmed wings, such as the Pulse, but may out glide some canopies designed to have a longer recovery arc. So a 7-cell low perm canopy. Quote Keep in mind that if you are accustomed to smaller 9-cell mains, the Horizon may require considerably more control deflection to achieve a quick snappy response. So a 7-cell low perm canopy. Quote The Horizon has a fairly long control range with excellent slow flight characteristics. So a 7-cell low perm canopy. Quote Although the Horizon has proven to have good landing performance both on straight-in approaches as well as high performance approaches, these great landings are not automatic. You must have the skill and technique that is appropriate for the size of the Horizon wing that you have selected. Any small canopy will have a high descent rate on final, so flaring must be timed well. This is how a 7-cell, low perm canopy flies. OK so we are still describing 7-cell low perm canopy. Got it. Low Perm material packs smaller, especially if utilizing material similar to the Optimum. I can't help but read this and feel this is just a slightly modified 7-cell low perm canopy, old technology repackaged and tuned a bit more for today's pilots. Isn't this just 1 step removed from taking a PD 7-Cell (Hey, remember those!) of FC 7-cell, adding a domed slider or nose baffles for better openings and calling it good? Sorry for the long post - if my thought process is off please challenge!=========Shaun ========== Quote Share this post Link to post Share on other sites
johnmatrix 21 #9 March 27, 2018 If you're a student pretty much any canopy that is OK for you at this stage will be fine for wingsuiting. This latest development of low-bulk canopies is marketed at people who downsized then got too stressed doing wingsuiting with the small canopies they were using and don't want to upsize their container to go back to a bigger more docile canopy. I do mainly wingsuit and tracking, and use a Sabre 2 for everything, loaded around 1.0. No issues but I won't be winning any canopy piloting comps. Quote Share this post Link to post Share on other sites
