jerolim 7 #1 November 10, 2017 Would this https://www.ebay.com/itm/IWISS-Wire-Rope-Crimping-Tool-for-Copper-and-Aluminum-Oval-Sleeves-and-Stop-From/302216512947?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649 ( Crimping Range : 1/16 "to 1/8 " ) or this https://www.ebay.com/itm/AIRCRAFT-TOOLS-NEW-CABLE-SWAGE-SWAGING-TOOL-IDEAL-FOR-MECHANICS/122019312175?hash=item1c68eaf22f:g:NmMAAOSwqu9VEBRy be good for crimping oval sleeves for main ripcords and cutaway ripcords ? Thank you. Quote Share this post Link to post Share on other sites
JerryBaumchen 1,464 #2 November 10, 2017 Hi Jerolim, QuoteWould this The first one: No The second one: I have or had one & used it many times for 3-ring cable. Slow but worked. I doubt that it would work for ripcord cable. But it might. I'll look around & see if I still have it; I could give it to you. Jerry Baumchen PS) I'll let you know via email. Quote Share this post Link to post Share on other sites
jerolim 7 #3 November 10, 2017 Thanks Jerry, I purchased second one;) I ment for main ripcord for student spring loaded PC's. Quote Share this post Link to post Share on other sites
councilman24 37 #4 November 11, 2017 I have both types and in the past made a few plastic handled student main ripcords but decided I didn't like the idea. And Jerry was kind enough to give me his ripcord testing fixture. I'd want to test those crimps. I'm actually using them to hang a cross at a church and will be testing the crimps to 600lbs to see if they pass. I would use it for cutaway handles but again I'd want to test each one. I believe there was a cutaway handle either missing the crimp or built purposefully with out one where the handle stripped off the cable and left one end in the riser.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
jerolim 7 #5 November 12, 2017 councilman24 I believe there was a cutaway handle either missing the crimp or built purposefully with out one where the handle stripped off the cable and left one end in the riser. Yes, there was one model on ebay from Ucraine (if I remember correctly) without crimp. Also there was base cutaway (intentional cutaway with 2 base canopies) incident and cutaway handle failed in this manner (i guess also missing crimp). Quote Share this post Link to post Share on other sites
