BrianM 1
Mind you, the other school requires two weeks of push-ups before they allow you near an airplane and the graduation dive is done wearing a ruck sack, rifle and snowshoes, at night, on a round, from 1000 feet!
There, I fixed it for you.
Needless to say I didn't tell them that I was a skydiving coach, instructor and rigger until after said graduation jump.
"It's amazing what you can learn while you're not talking." - Skydivesg
pchapman 279
I was just conserned to which method was safer, and for some reason I thought that static line was abit more of an old school method vs IAD.
Either method, well done, is safe & effective.
But I'll agree that static line is old school! (I instruct at the Ontario DZ that uses static line but doesn't require 2 weeks of pushups...)
It isn't as popular, it does require more types of gear and more transition training, it is an older technique, and it's not as cool because students aren't getting any real freefall.
Maybe I should leave it at that, but I will comment on a couple things Andrew White mentioned. A lot of what he said is either true in general, or something he has actually seen, but some counterbalancing ideas can be added.
Our line twist rate was at least five times what it is for IADs out of the same aircraft
True. Off the top I my head, it could be 25 - 50%. But I don't keep track because it doesn't matter much. Yes, students just drift a bit while untwisting.
One hazard might be the occasional student who wants to cut away from line twists despite their training, or who pulls their toggles before untwisting.
As for mals, yes the direction of air flow should make mals more likely. The DZO at the place I jump has a packing method that is supposed to somewhat counteract that. I don't know what the real numbers are, but the DZ has often enough had seasons with zero or one canopy mals when training 500-1000 first timers per year, plus whatever repeats there are. While there's lots of opportunity to debate malfunction rates, I just don't want it thought that direct bag static line automatically means a lot of mals.
The argument has been made that static line is a more sure way to get 'something' out. To this I call bullshit. The last time I saw a pilot chute in tow on an IAD was over ten years ago.
"Getting something out" is one of the DZO's reasons I believe. When critiquing IAD, I never figured PC in tow was the biggest worry. It was the student tumbling, and grabbing or getting entangled with the PC. That was a significant factor in first jump student deaths in BC in '91, Alberta in '93, and Ontario in '95. The students all had reserve parachutes available so IAD didn't "kill them". (There were plenty of other issues involved.) But IAD is more likely to give a student a nasty high speeed mal than does static line.
There's also the worry about the PC over the tailplane. But that comes down to understanding good ways to do IAD and training instructors appropriately. Just because I know a DZ that twice ripped up the tail of their aircraft due to IAD (in the 80s), doesn't mean other places can't do a lot better!
While static line (direct bag style!) doesn't have that high speed mal issue, it can still suffer from students getting caught up in the lines when backflipping off the step. Or because of the direction the canopy is extracted, a riser can get caught under the reserve pack tray causing a mal. Gear design and packing techniques can minimize this. Still these are valid issues with static line.
Hey Pchapman
BTW I did my first tandem at your home DZ when I was 16(3 years ago). It was one of the only places in Ontario that would let me jumpat that age.
anyway it was an awesome first jump.
[]DETE
[]DETE
billvon 3,118
>Pilot chute assist (static-line) is the worst system because it (is the
>longest and) allows the student too much time to back loop through his
>lines, grab a pilot chute, etc.
I started on a PC assist system with throwout pilot chute rigs. While I was an SL JM we used both PC assist (with springloaded PC's) and direct bag. Direct bag seems to be the way to go if you want to ensure openings, but the openings are very ugly because the main is essentially opening sideways to the relative wind. I saw sliders forced halfway down the lines before the main was even clear of the bag. PC assist with springloads seemed like the worst of both worlds. Unstable students had more problems with PC assist, but that system also gave the student the best openings during good exits and gave them time to practice DRCP's.
riggerrob 643
billvon,
You are correct in saying that one advantage of pilot chute assist static-lines is that they give the student more time to pull their practice handles, however, I put a higher priority on getting a canopy overhead a first-timer.
PC assist S/L just gives clumsy students too much time to grab a half-deployed canopy.
Personally I am glad I went the s/l method..
Never really had one problem except one small line twist which just as soon as I looked up and saw it, it was gone.. I have 11 jumps now, of course due to the way I travel for work and crappy weather and a few off-center prcps my 11th jump last weekend was my 5 second delay.
When traveling in the NE from feb-late april I found a small dz in kutztown, PA that offered IAD and ended up heading over there and taking IAD recurrency as the dz allowed me to after showing them my log book and was going to make an IAD jump but the weather went to you know CRAP! Either way I am glad I took the route of s/l over AFF as my canopy control and landings I feel comfortable with. I also like the IAD training route I guess because it is similar to s/l..
Now this is the opinion of someone yet still a newbie but I haven't landed off the dz since the first 2 jumps..
As a matter of fact I am going to try weather permitting this weekend to get jump 12 in which my JM said I will get maybe to almost to altitude..(I am not rushing it, if you are wondering). At least maybe then when I leave for Venezuela on the 29th I maybe able to do a few jumps down there to keep current till I get back..
s/l and IAD Rock! Especially when you have great JM's...
Have always wanted to be a social butterfly but now I have the wind beneath my feet.
billvon 3,118
That is, perhaps, a reason that direct bag is more suitable for someone making a one time jump (or for military jumps) than for people who wish to learn to freefall.
Pilot chute assist (static-line) is the worst system because it (is the longest and) allows the student too much time to back loop through his lines, grab a pilot chute, etc.
Trust me, I have worked with: military static-line, military surplus static-line, pilot chute assist S/L with fore-and-aft gear and round canopies, PC assist S/L with piggy backs and square canopies, direct bag S/L with squares, IAD with Para-Commanders, IAD with squares, etc.
IAD is my favorite method.
