lawrocket
The issue here is farmers are expecting under 10% delivery of water next year. If that. Not because there isn't water that could be delivered. It's been the choice to let that water go into the Pacific. The litigation over it has been fierce.
As I wrote in the fracking thread, agriculture uses 75% of the water supply in California, so let's maintain some perspective when you talk about the smelt or the San Franciscans killing the poor farmers. I pay a hell of a lot more per unit of water, too.
Bertt 0
But what if there were small, modular nuclear reactors built into the grid along with wind generators? I wonder if anybody around here has thought of that.....?
You don't have to outrun the bear.
billvon 3,173
>wind generators?
Somebody should think about that!
>wind generators?
grue 1
billvon>But what if there were small, modular nuclear reactors built into the grid along with
>wind generators?
Isn't that precisely what project Hyperion was gonna be for? Not sure what ever came of that company
cavete terrae.
lawrocketEverything is about costs and benefits. Wind power has some advantages and disadvantages. Whether it's beneficial or not depends on what each individual finds important.
Here in the Central Valley, the Delta Smelt is given priority over farms, food, and work. Some disagree with the policy. Others support it. Those who support it have been winning.
Past water management in the Central Valley has been so ridiculously stupid that the delta smelt should be a non-issue. A rights management system that allows a guy enough water to operate a trout farm in the middle of the freaking desert so long as he can prove he has before (by taking groundwater), and wailing and gnashing of teeth any time anyone suggests a bit of reason and conservation. Massive water intensive crops, unregulated overdraft of groundwater, a Colorado River that really shouldn't be called that anymore (as it doesn't reach the ocean), zero investment in infrastructure, and a whole lot of crying by people unwilling to live in synergy with the environment they chose.
At least San Diego is propping up a desalination plant. The rest of California going to have to do that and more recycling and probably still have another standoff with the Arizona National Guard in 40-50 years. I'd worry about the Columbia River, but I don't see how you could cost effectively transport it that far...maybe an underwater aquaduct just offshore? Alaskan fisheries and California water are probably the two most poorly managed natural resources in the US in the last 40 years, though there may be a logging region in contention somewhere too. At least the Alaskans are trying now. I wouldn't say the same about California. As environmentally conscious as the state purports to be, that's one subject on which most of the state deserve an F. I'm reminded of Sam Kinison's thoughts on starving people in Ethiopia...
Blues,
Dave
"I AM A PROFESSIONAL EXTREME ATHLETE!"
(drink Mountain Dew)
Right; water is pumped there from the San Joaquin - Sacramento river delta. Which is where the problem lies.
>Second, check out Alameda's tide gauge readings.
From that site: "The mean sea level trend is 0.82 millimeters/year." It's the lowest rise rate in the area. I don't know if you looked at the other nearby sites; the average is about 2 mm a year.
>Second - the story of the levees is long and exhausting. Fundamentally, they
>were privately built. Then the feds moved in and it's been a nightmare since.
That's as informative as saying "fundamentally, the government sets a reasonable policy. Then farmers got involved and it's been a nightmare ever since."
The farming of the delta was just the first step in a long series of mistakes that led to today's central valley water problem. And it's getting worse. Even if you "don't believe" in sea level rise, or think it's less than a mm a year, that's still going to cause problems. Not because the water isn't going to flow, but the line between fresh and salt waster is going to move further inland. So even if farmers agree to never increase the amount of water they use the problem will continue to get worse.
>There is mighty fine water storage in the sierras.
Yep. And there's mighty fine water flowing down the Colorado River. We use all of it.
>And the ONLY solution I can see to it is to drain and restore Hetch Hetchy.
OK, we could do that. Farmers would then have to live on 0% of the water they are getting now. Which might be the right thing to do in the long run; farming in a desert was always a dicey proposition.
