rushmc 23
Quote>I'd say that trillions of quantum measurements have been made over the course of
>the past hundred years.
317 a second! Even back in the 1920's! Them's some fast experimenters.
>Sure. Good thing we can measure the temperature, give a location and a date and
>time of the measurement. And we can put all those together and over the last fifteen
>years or so see that the trend is flat.
Yep, And we can put it together over the past 150 years and see it is not flat at all; there is a strong signal.
150 years
Wow
That is one hell of a sample when compared to the age of the earth
But I guess we can only see this in the context of our RECORDED time on this planet?
if we falter and lose our freedoms,
it will be because we destroyed ourselves."
Abraham Lincoln
brenthutch 444
Can you elaborate on that point? A 150 year long, "strong signal"? Are you telling me that the warming trend predates the industrial revolution, and thus is not attributable to anthropomorphic forcings?
kallend 2,219
QuoteYep, And we can put it together over the past 150 years and see it is not flat at all; there is a strong signal.
Thanks for letting us know that your knowledge of history is as bad as your knowledge of science.
rushmc 23
QuoteQuoteYep, And we can put it together over the past 150 years and see it is not flat at all; there is a strong signal.
Always so much content
And we know YOU think you are much the expert
Well, there is a definition of an expert that fits your posts
Abraham Lincoln
Seeing as how just the LHC measured a half a billion collisions per second for a period of years, (that's a trillion every half hour or so) I'm pretty comfortable with the "trillions" of measuremebts per secons number.
My wife is hotter than your wife.
kallend 2,219
QuoteQuoteQuoteYep, And we can put it together over the past 150 years and see it is not flat at all; there is a strong signal.
You don't have to be an expert to know when the industrial revolution started. All that's necessary is not to be an ignoramus.
You're welcome!
brenthutch 444
"Antarctic sea ice remained extensive due to an unusual northward excursion of ice in the Weddell Sea. December of 2012 saw Northern Hemisphere snow cover at a record high extent, while January 2013 is the sixth-highest snow cover extent on record since 1967."
Yep looks like we are all going to melt.
billvon 3,173
"Arctic sea ice extent for January 2013 was well below average, largely due to extensive open water in the Barents Sea and near Svalbard. "
"As has been the case throughout this winter, ice extent in the Atlantic sector of the Arctic Ocean remained far below average. "
"Average Arctic sea ice extent for January 2013 was the sixth lowest for the month in the satellite record. Through 2013, the linear rate of decline for January ice extent is -3.2 percent per decade relative to the 1979 to 2000 average."
"In recent years, the surface of the Greenland Ice Sheet has experienced strong melting, but the 2012 melt season far exceeded all previous years of satellite monitoring, and led to significant amounts of ice loss for the year."
Were you hoping no one checked?
brenthutch 444
billvon 3,173
Good! Another denier talking point sinks quietly beneath the waves.
Why is Arctic sea ice more important to the earth's albedo than Antarctic sea ice?
Why is the Greenland ice sheet more important than the Antarctic?
Why do the alarmists cherry pick as much as the deniers?
brenthutch 444
http://www.wendymcelroy.com/news.php?extend.5268
Granting that CO2 is a greenhouse gas, there is little evidence that man's CO2 emissions are the dominant force in global temperature. For the last 17 years, CO2 has risen but temperature has remained flat, which suggests that some other influence is stronger than CO2. Also, "too much" warming is a judgment call -- there is no scientific basis for how much is too much. Sea level isn't rising any faster than it used to.
In 2008, Britian’s Met Office noted a 10-year pause, or sharp slowing, in the warming trend and asked this question in the National Oceanic and Atmospheric Administration’ annual State of the Climate:
Do global temperature trends over the last decade falsify climate predictions?
No, it decided. Global warming models wouldn’t be clearly wrong until the pause lasted 15 years:
Observations indicate that global temperature rise has slowed in the last decade… The simulations rule out (at the 95% level) zero trends for intervals of 15 yr or more, suggesting that an observed absence of warming of this duration is needed to create a discrepancy with the expected present-day warming rate.
http://blogs.news.com.au/heraldsun/andrewbolt/index.php/heraldsun/comments/the_models_are_broken_by_the_standards_warmists_set/#119995
http://iopscience.iop.org/1748-9326/8/1/014024
An analysis of NASA satellite data shows that water vapor, the most important greenhouse gas, has declined in the upper atmosphere causing a cooling effect that is 16 times greater than the warming effect from man-made greenhouse gas emissions during the period 1990 to 2001.
http://wattsupwiththat.com/2013/03/06/nasa-satellite-data-shows-a-decline-in-water-vapor/
kallend 2,219
brenthutch 444
From the abstract
"Current global temperatures of the past decade have not yet exceeded peak interglacial values"
So we are no warmer than we have been in the past, which confirms what I have been saying all along, thanks for the assist.
Here is some more.
"New data from the National Oceanic and Atmospheric Administration show atmospheric carbon dioxide levels are continuing to rise but global temperatures are not following suit. The new data undercut assertions that atmospheric carbon dioxide is causing a global warming crisis."
http://www.forbes.com/sites/jamestaylor/2013/03/06/as-carbon-dioxide-levels-continue-to-rise-global-temperatures-are-not-following-suit/
kallend 2,219
QuoteQuote
From the abstract
Here is some more.
Nice cherry you managed to pick there. Of course it's irrelevant but the best you can find.
How about a definitive source on CO2 levels (rather than an opinion piece in Forbes
www.esrl.noaa.gov/gmd/ccgg/trends/
sfzombie 3
kallend 2,219
www.politico.com/story/2013/03/film-targets-climate-change-deniers-88629.html?hp=r7
rushmc 23
you bitch about bias sites and then you post a politico link???
Abraham Lincoln
kallend 2,219
Quoteyou bitch about bias sites and then you post a politico link???
Sauce for the goose.
brenthutch 444
sfzombie 3
kallend 2,219
www.sciencerecorder.com/news/scientists-earth-is-warmer-today-than-any-time-in-the-past-11300-years/
