There are easy ways to reconfigure the lips to fix them for flawless function serrated pliers are not the right tool.
Long nose pliers or a steel arbor shaped in the right geometry are the right tool.
The long nose pliers are to bend them up, the arbor is to insert and beat the lips down to with a lead or rubber mallet.
TomAiello 26
Yes, but do you have enough .308 Pmags? They're taking pre-orders now...![]()
-- Tom Aiello
Tom@SnakeRiverBASE.com
SnakeRiverBASE.com
SnakeRiverBASE.com
If I bought some AR-10 mags, then I guess I'll have to buy an AR-10. I'll tell my wife you told me I had to!![]()
mnealtx 0
QuoteIf I bought some AR-10 mags, then I guess I'll have to buy an AR-10. I'll tell my wife you told me I had to!
So she can beat up you AND Tom?
I will admit, that Patriot Ordnance 308 looks sweet...
Mike
I love you, Shannon and Jim.
POPS 9708 , SCR 14706
Overgassed, over massed and undersprung.
Hear me now, believe me later.
You can get accurate, or reliable but not both.
Don't expect a really accurate one to last. Don't expect a reliable one to be less than 1moa.
If you want a reliable .308 semi auto get an FAL and work on it. Parts are semi cheap and so are magazines.
An M14 takes a lot of work to be really accurate, they are fairly reliable and not bad at all.
You can get a national match for around $1400
Mags are expensive as all hell.
HK's are expensive to own and maintain.
You can get sub moa with the right ammo.
Maybe not, maybe the people I've trained with are doing it wrong too. Eitherway, I've pretty much walked away from the metal mags and have enough Pmags (for now).
