QuoteQuoteThe superiority of the SI system is due to the fact that it's RATIONAL.
Are you saying that the Imperial system doesn't use fractions and the metric system does?![]()
fractions, yea, right, wasnt it you with something like 2.4 inches!? so, that's 2*25.4mm, but how much is 0.4 inches!? 4*2.54!?
if i do a calculation, i do it in metric numbers. not a third of this and half of that really..
-Hunter S. Thompson
"No. Try not. Do... or do not. There is no try."
-Yoda
quade 4
Quoteif i do a calculation, i do it in metric numbers. not a third of this and half of that really..
Really? Split an hour into three parts.
Where's your "metric" time?
Draw an equilateral triangle.
Where's your "metric" protractor?
QuoteQuoteif i do a calculation, i do it in metric numbers. not a third of this and half of that really..
here!
-Hunter S. Thompson
-Yoda
quade 4
QuoteQuoteQuoteif i do a calculation, i do it in metric numbers. not a third of this and half of that really..
here!![]()
Yeah, I can see that's really catching on.
Where's your "metric" calendar?
QuoteQuoteQuoteQuoteif i do a calculation, i do it in metric numbers. not a third of this and half of that really..
here!![]()
you havent read the article, right!?
here's your metric calendar!
oh yea, of course, it's french, cant be good right!?
pretty much catches on like your imperial system, doesnt it!? that's why pretty much all countries except the US and england are still using the imperial system..
-Hunter S. Thompson
-Yoda
mccordia 74
I prefer Cm over Inch, because it makes my d*ck look bigger in terms of the number I can quote....
Think about it quade...In Cm's you might even go into double digits![]()
FlyLikeBrick
I'm an Athlete?
QuoteI prefer Cm over Inch, because it makes my d*ck look bigger in terms of the number I can quote....
even if it didnt, it still be mm's, and that would STILL be double-digits; hopefully!
-Hunter S. Thompson
-Yoda
here!![]()
Quick! How many quarts is 23.96 cubic inches and how many pounds of water is that? No calculators please
Originally employed as a weapon of war, the hammer nowadays is used as a
kind of divining rod to locate the most expensive parts adjacent the
object we are trying to hit.
turtlespeed 226
QuoteQuoteterafurlongs
I actually really like that one. I think they'd go well with "megastones" and "microscores"
Microscores are just really really short women.
BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun
quade 4
QuoteQuick! How many quarts is 23.96 cubic inches and how many pounds of water is that? No calculators please
Quick! How many litres is 13.3kg of gasoline?
The point here being, unless you're talking about pure water at a specific temperature and pressure, your argument falls to pieces.
QuoteQuoteQuick! How many quarts is 23.96 cubic inches and how many pounds of water is that? No calculators please
wouldnt matter about about gasoline either then, right!? as the volume would also change with pressure and temparature...
-Hunter S. Thompson
-Yoda
Pretty easy, actually.
It is common knowledge that the specific gravity of gasolin is about .75 so 13.3/.75 gives pretty darn close to 18 litres.
Yes, I did that in my head.
Still working on the miles thing?
>Checked my figuring with a calculator. 13.3/.75 is 17.73, so I was off by a couple percent. But then I checked what the actual SH of gasoline is...and it is .74. 13.3/.74=17.97.
I wasn't so far off after all.
QuoteQuoteQuoteQuick! How many quarts is 23.96 cubic inches and how many pounds of water is that? No calculators please
I wasn't so far off after all.Try that with your imperial measurements.
...and you spent how many hours working that out for us?
QuoteQuoteQuoteQuoteQuick! How many quarts is 23.96 cubic inches and how many pounds of water is that? No calculators please
...and you spent how many hours working that out for us?![]()
About 10 seconds to do the rough mental calculation, about 30 seconds on a calculator.
I guess Quade needs some more time to figure his cubic inches, quarts, and pounds.
A hint: A quart of water weighs two pounds and is 57.75 cubic inches.
kallend 2,231
Quick - how many square chains in an acre?
How many m^2 in a hectare?
How many cubic inches in a gill?
How many cubic cm in a liter?
piisfish 140
AND WHERE IS YOUR ALTIFEET ?
I jump with an altimeter ![]()
How many peas in a bushel?
How many state secrets in a cover-up?
How much water over the dam?
How the hell do I let myself get off on a tangent like this?
QuoteHow many peas in a bushel?
How much wood could a woodchuck chuck if a woodchuck could chuck wood?
turtlespeed 226
QuoteQuoteHow many peas in a bushel?
Like this?
mnealtx 0
QuoteAND WHERE IS YOUR ALTIFEET ?
Us Imperial guys realize that there's a difference between a measurement device and a standard of measurement.
I love you, Shannon and Jim.
POPS 9708 , SCR 14706
kallend 2,231
QuoteQuoteAND WHERE IS YOUR ALTIFEET ?
Us Imperial guys realize that there's a difference between a measurement device and a standard of measurement.![]()
So what is the charge on the electron in US Imperial units?
What is the magnetic moment of an electron (Bohr magneton) in US Imperial units? What is the value of the Lamb constant in US Imperial units?
To be more useful everyday - what is a current of 1.0 amp (amp is SI) in US Imperial units? What is a potential of a 12 volt car battery in US Imperial units (volt is SI)? What is the typical strength of the magnet in an MRI machine in US Imperial units (Tesla is SI)?
mnealtx 0
QuoteQuoteQuoteAND WHERE IS YOUR ALTIFEET ?
Sense of humor ran off on you, did it John?
Speak for yourself.
