uer16 1 #1 August 8, 2017 Does someone know/can measure the distance between the brake line cascade and the brake setting loop. And also between the brake setting loop and the toggle? One I bought came with ~2 inch difference between left/right brake lines. It might be possible to figure out which one's which, but confirmation would be comforting. Quote Share this post Link to post Share on other sites
IJskonijn 45 #2 August 8, 2017 http://www.flyaerodyne.com/wp-content/uploads/2017/05/Diablo.pdf If I'm reading it right for the 150, the brakelines should be 551mm longer than the A-lines with the brakes unstowed, and 135mm longer than the A-lines with the brakes stowed. This means the brake setting loop should be 416mm above the toggle. If the brakelines are this far out of whack, you might benefit from checking the entire linetrim carefully. Quote Share this post Link to post Share on other sites
