uer16 1 #1 July 24, 2017 A canopy I have was dragged against something sharp in the trunk of a car during a break-in, causing a pinky-sized hole, and a bunch of abrasions/pinholes over a certain area. I would avoid putting a full-sized patch since it's an older canopy that's worth as much as a patch or 2 would cost. I do want to jump it for the next ~200 jumps, and want to use ripstop adhesive tape for a quick temporary-ish repair. The bigger hole is no problem, parachute rigger's handbook says "For holes up to .5-inch in diameter or a tear, a double-sided patch is necessary", and the hole is smaller than that. I'm more worried about the pinholes/abrasions: it would require about a 10" piece of tape to cover the whole area, I believe one-sided would be sufficient. Are there any issues with that much tape being applied to a canopy? Would it be a good idea to just not do anything and see if it becomes worse? Remember the "repair" only needs to last ~200 jumps at which point the canopy is a car cover. The hole+abrasions are on the topskin of an end-cell near a non-loaded rib if that helps. Quote Share this post Link to post Share on other sites
peek 21 #2 July 24, 2017 uer16I'm more worried about the pinholes/abrasions: it would require about a 10" piece of tape to cover the whole area, I believe one-sided would be sufficient. Are there any issues with that much tape being applied to a canopy? Would it be a good idea to just not do anything and see if it becomes worse? Remember the "repair" only needs to last ~200 jumps at which point the canopy is a car cover. Years ago I had 2 long pieces of tape on a canopy with F-111 type fabric (not zero porosity) that had large friction burns. It lasted a long time. Just replaced it if needed. Quote Share this post Link to post Share on other sites
riggerrob 644 #3 July 24, 2017 Double-layer patches last longer ..... more than 200 jumps. If you want to get fancy, ask a rigger to sew around the edge. Quote Share this post Link to post Share on other sites
