parachutist 2 #1 July 8, 2017 Pin straightening block: [inline pinblock.jpg] This is a tool I needed recently. I added holes ranging from 2.3 to 4.0 mm, suiting a variety of pins. The STL file is inside the attached .zip. I hope some people find it useful Quote Share this post Link to post Share on other sites
format 1 #2 July 8, 2017 Material is that tough? No danger of damaged plastic? How much print costs? Very interesting piece, inspiring What goes around, comes later. Quote Share this post Link to post Share on other sites
parachutist 2 #3 July 8, 2017 format Material is that tough? No danger of damaged plastic? How much print costs? Very interesting piece, inspiring Thanks! It cost me about $1.75 in materials for this print, using PLA plastic, and probably another $1 in electricity. The plastic is plenty strong, but if it ever did get damaged you could print another in a few hours. Quote Share this post Link to post Share on other sites
SkyGoblin 0 #4 July 9, 2017 If a pin is bent, and you straighten it, does that weaken the pin at the former bend? Quote Share this post Link to post Share on other sites
RiggerLee 63 #5 July 9, 2017 In theory, if you did it a lot or if it was a big bend. Remember the pin is like formed by a hammer extrusion process. It's pretty tough and ductile/malleable not sure the correct word in this context. We've been straightening minor bends in pins forever. So in a properly made pin, excluding the capewell fiasco, straightening a small bend is no big deal. LeeLee lee@velocitysportswear.com www.velocitysportswear.com Quote Share this post Link to post Share on other sites
rmarshall234 14 #6 July 9, 2017 RiggerLeeIn theory, if you did it a lot or if it was a big bend. It's pretty tough and ductile/malleable not sure the correct word in this context. We've been straightening minor bends in pins forever. So in a properly made pin, excluding the capewell fiasco, straightening a small bend is no big deal. Lee Agreed. And, I believe the concern with straightening the pin too many times is that it becomes "work hardened". In which case it becomes more brittle and therefore more likely to break. Not sure we could straighten it enough times for this to really become a problem though. ?? Having said that, if I become concerned enough about the integrity of a pin, it gets replaced. Quote Share this post Link to post Share on other sites
Deyan 36 #7 July 10, 2017 SkyGoblinIf a pin is bent, and you straighten it, does that weaken the pin at the former bend? At the latest PIA symposium, Nancy from Parachute Labs (those are the people that manufacture a lot of pins) did a demo where she bended and straightened a pin to 90 degrees angle 27 times before it broke....So I guess straightening a slight bend will do nothing to the strength. .....or was it 37 times? Nancy?!"My belief is that once the doctor whacks you on the butt, all guarantees are off" Jerry Baumchen Quote Share this post Link to post Share on other sites
rmarshall234 14 #8 July 10, 2017 Great info, Thanks! Quote Share this post Link to post Share on other sites
riggerrob 644 #9 July 10, 2017 The Capewell Service Bulleton CW01-03 shows a test block similar to this new plastic block. Capewelll specifies soft aluminum or soft stainless steel. Part of Capewell's problem was that they used a different alloy of stainless steel than the original MIL SPEC. John Sherman (Parachute Labs) will give you a lengthy description of the various alloys used to make ripcord pins and will conclude that PL uses the best alloy. Quote Share this post Link to post Share on other sites
parachutist 2 #10 July 10, 2017 SkyGoblinIf a pin is bent, and you straighten it, does that weaken the pin at the former bend? Each case is different. If a pin has a definite bend at one specific point on the shaft, then I'm likely to recommend replacing the rip cord. This block was used to encourage an out-of-true pin with a slight curve to be straight again. Quote Share this post Link to post Share on other sites
