DylanH 1 #1 March 20, 2017 Just wondering in anyone here has ever encountered an issue with their Viso using batteries up very quickly. My Viso 2+ ended up taking a dip in a river for a couple seconds and ever since has been using up a set of batteries in less than 24hrs(with most of that time being spent off). Just wondering if anyone has run into this issue before. Quote Share this post Link to post Share on other sites
chuckakers 426 #2 March 21, 2017 I just had a friend mention this the other day. It was the first I had heard of it, but it sounds like you aren't alone.Chuck Akers D-10855 Houston, TX Quote Share this post Link to post Share on other sites
jurgencamps 0 #3 March 21, 2017 And the battery stays empty when you switch the viso off and on? Quote Share this post Link to post Share on other sites
hoipex99 0 #4 March 21, 2017 I had a similar problem:When I put in new batteries the battery status was on low again within a day. "Solution" which worked for me: When you remove the old batteries,wait for ~5min before you put in the new batteries. Otherwise the viso will remember the low batt status from the old batteries. Hope this helps Quote Share this post Link to post Share on other sites
DylanH 1 #5 March 21, 2017 The way it ended up working for me was I replaced the batteries in the morning, jumped all day. By the end of the day the new batteries were at 1 flashing bar. Turned it off for the night and the next day the batteries were so flat it wouldnt even turn on. Went through that process twice. Think I'll be contact L&B to see what they say. Quote Share this post Link to post Share on other sites
DylanH 1 #6 March 21, 2017 Thanks for the suggestion. The second time I swapped the batteries I was with someone who had a lot more experience with Viso issues than me. The batteries were pulled, we waited a few minutes and the reset button was pushed when the new batteries were put in. It still chewed through them as fast as the first time. Quote Share this post Link to post Share on other sites
hoipex99 0 #7 March 22, 2017 Ok,send it to L&B then. I got mine replaced last year because my Viso got hung up several times on the ride to altitude at about 1000ft. 2weeks later I got a new one. Quote Share this post Link to post Share on other sites
