Zep
law enforcment ammunition
I was working in the police station the other day, an ran into a drinking buddy (who's a police officer)
Anyway we where chatting an he showed me his new service pistol, Lama M-82 (well new for him)
He took out the mag let me look at it, it was ok but a bit on the heavy side,
What surprised me was the load, it was loaded with 9x21 JHP's
In other countries is this normal I thought it was a bit over the top.
Gone fishing
What's wrong with hollow points for self defense? If you need to stop someone from killing you, that's one of the best types of ammo available.
Even better than 9mm hollow points would be .45 hollow points.
Are you suggesting that the police should use something less effective, at the risk of their own lives?
Most departments including mine use a low grain(less gunpowder) hollow point.
With that combination the chances of the bullet exiting the body is reduced to NEAR impossible. It wouldn't be good if a bullet exited a person and struck a bystander. Also the full metal jackets(hard shell) as you call it are known to ricochet inside the body off of bones and tear threw organs.
______________________________________________
"A radical man is a man with both feet firmly planted in the air."
-Franklin Delano Roosevelt
No, For some reason I thought they used the standard hardball.
Just curious as to why you would think that?
I don't know, Something to do with international treaties, Maybe I was thinking along the lines of
if NATO has a standard round perhaps police forces do too,
Gone fishing
Nope it only applies to military.
And now Glock has created a NEW .45 round,
shorter brass...about the same as a 9mm, but with
'standard' .45 ballistics.
.45 power on a 9mm frame...
(he bets his life on a llama?!):S
9mm is pretty rare now a days.
9x21 is not quite the same as a "standard" 9mm round (9x19), and the terminal ballistics are significantly better. It is most commonly used in the USA in IPSC matches as you can "make major" with it.
9x19 (Luger, or parabellum if you prefer) is still quite popular in CCW states, with folks who like more stopping power than a .38 with less bulk, and less recoil than a .40 cal or a .357 Sig. in the same size frame.
Personally, my CCW is a .40 S&W stoked with 155 gr GDHP, and I see no reason to change.
G. Jones
"I've never been quarantined. But the more I look around, the more I think it might not be a bad idea."
No, I wish I did but....
back in my own darkness, we were restricted to 9mm ball rounds, so we used to 'Doctor' the first top 2 rounds in the mag. This has changed now as we can choose the ammo, depending on the job.
You would file the top down of the round down a few mm then cut an ' X ' in 1 or 2 mm.
This practise was illegal, so it was not an open spoken practise.
What does "make major" mean?
It refers to power factor ratings, which determine how hits are scored. The formula for determining power factor for a given "load" is Bullet weight (in grains) x velocity / 1000.
Some divisions have only a minimum power factor requirement, or "floor", while in other divisions you may "make major" by meeting a higher power factor (usually 160-170, depending on which division you're shooting in).
Peripheral hits are scored higher with major power factor due to the fact that heavier projectiles with higher velocities generally produce more damage, and will be more likely to "take the fight out of the bad guy".
G. Jones
Aha! Thanks for that explanation. So this is a way to give a higher score for lethality based on the bigger calibers and/or higher velocities?
So a .45 with the standard 230 grain bullets at 850 feet per second, would be a power factor of ...(calculating)... 195.5. And a 9mm with 115 grain bullets at 1200 fps would be... 138. Since I shoot .45's, I think I would like this scoring advantage!
That's very sophisticated scoring. I shoot high-power rifle, and it reminds me of a rule we have in that competition. If the edge of a bullet hole is just touching the line around a scoring ring, the shooter gets the higher value of the ring he's touching, even though the majority of the hole is in the lower scoring ring. The problem is, .223 shooters make such tiny holes, that they can be real close to a line, but not touch it, where the same shot with a .30 caliber would touch the line and get an extra point. So you can get a little advantage with a .30 caliber over .223.
