Texasreb78 0 #1 September 11, 2016 What is a good canopy to compare to the Sabre2? Something with similar flight characteristics; as close to "apples to apples" as you can get. I'm going to try to demo soon. Quote Share this post Link to post Share on other sites
riggerrob 644 #2 September 12, 2016 Sabre 2 competes for the same market sector as Safire and Pilot. Quote Share this post Link to post Share on other sites
Texasreb78 0 #3 September 12, 2016 Wouldn't PD's Pulse be closer to Safire and Pilot? Quote Share this post Link to post Share on other sites
jsreznor 0 #4 September 12, 2016 That's not what you asked. You asked what a Sabre2 is close to. Quote Share this post Link to post Share on other sites
Texasreb78 0 #5 September 12, 2016 So anything else? Or are those two going to be about the most similar on the market? Quote Share this post Link to post Share on other sites
tred 0 #6 September 12, 2016 also consider getting a rig that fits. your neck strap in your profile pic looks a little loose Quote Share this post Link to post Share on other sites
Texasreb78 0 #7 September 12, 2016 The struggle is real. Quote Share this post Link to post Share on other sites
Pobrause 6 #8 September 12, 2016 Texasreb78Wouldn't PD's Pulse be closer to Safire and Pilot? no Magellan by Skylark Volt by PS Cayenne light by Firebird New S-Fire by Icarus Spain Quadra-V-Tec or Faqtor by Paratec Monarch by Precision Aerodynamics ... and a few more depending on what you are looking for in a "Sabre2-like" canopy and how you are going to load it. So, what do you want out of your canopy?------------------------------------------------------- To absent friends Quote Share this post Link to post Share on other sites
hackish 8 #9 September 12, 2016 I think the sabre2 is a design that shows some of its age. PD has continued on their R&D programs improving openings, flight and landings. I wouldn't be surprised if they released a Sabre3 or retired it completely in the next few years. Having said that, it's hard to compare the sabre2 against anything more modern that's on the market. -Michael Quote Share this post Link to post Share on other sites
Texasreb78 0 #10 September 12, 2016 Thanks! I like the steeper glide and slightly longer recovery arc the Sabre2 has, but I'm not enthusiastic about some of the reviews regarding its openings. I'm gearing myself to progress into high performance landings. This is my starting point of my progression and plan to wing load at about a 1.15 for now. Then possibly the same design wing at a 1.25 before advancing to another design. Quote Share this post Link to post Share on other sites
Maddingo 21 #11 September 12, 2016 I've heard alot of good things about the Volt from Parachute Sytems, cheaper, pretty much the same flight characteristics and it is said they open a bit better. Quote Share this post Link to post Share on other sites
timrf79 0 #12 September 12, 2016 Texasreb78Thanks! I like the steeper glide and slightly longer recovery arc the Sabre2 has, but I'm not enthusiastic about some of the reviews regarding its openings. I'm gearing myself to progress into high performance landings. This is my starting point of my progression and plan to wing load at about a 1.15 for now. Then possibly the same design wing at a 1.25 before advancing to another design. The openings on a Sabre2 are perfectly fine if you pack it right and have good body position at opening. I would say that if you struggle with Sabre 2 openings at a WL of <1.5 you should not advance to higher loading/ different design. If you want to swoop, I would further suggest staying on the canopy platform until a 2.x loading. At least 1.5. Zulu's, Crossfires, etc.. are speced at a min loading of 1.5. Due to their shape it might not be bad to have flown a higher loaded semi-elliptical first. Quote Share this post Link to post Share on other sites
BigL 4 #13 September 13, 2016 I load my Sabre2 at 1.17. Haven't had a hard opening on any of the >200 jumps that I've done on it. All the reasons that you've listed are why I chose it to start HP landings, with advice from my local instructors. Quote Share this post Link to post Share on other sites
Texasreb78 0 #14 September 13, 2016 Thanks everybody. Most of ya'll have been helpful and informative. I'm going to demo a Sabre2 and keep an eye out for some of these other similar canopies. Quote Share this post Link to post Share on other sites
BigBUG 0 #15 September 13, 2016 Try Safire 2. Way softer openings, less resistance on the toggles and risers, ability to recover almost instantly if shit hits the fan but you managed to hit the toggles. I did more than 1000 jumps on Safires, with wingloads from 1.5 to 1.9, and it flies beatifuly. Hope this link will work, this is Russian social network, but you should be able to see video without logging in. This is my home DZ 10 years ago and the guys saves himself with a Safire 119, WL ~1.7. See the 'instant brake' feature in action :) "> Quote Share this post Link to post Share on other sites
Deimian 43 #16 September 13, 2016 vk.com/video_ext.php?oid=-46147684&id=164154652&hash=05047f34e6f79938&hd=1" width="640" height="360" frameborder="0" allowfullscreen Well, that was indeed impressive. Quote Share this post Link to post Share on other sites
dragon2 2 #17 September 19, 2016 Texasreb78What is a good canopy to compare to the Sabre2? Something with similar flight characteristics; as close to "apples to apples" as you can get. I'm going to try to demo soon. A Fusion is about as close as you can get to a sabre2, I think. A bit less divey maybe than a sabre2, if you want to do front riser approaches. A pilot feels 'tamer', a safire 1/2 is in between. IMO (I jumped all of these, some of them for years). ciel bleu, Saskia Quote Share this post Link to post Share on other sites
erdnarob 1 #18 September 23, 2016 Here are some canopy angles of depression : Sabre 2 15.34 degrees Pilot 15.06 degrees Safire 2 15.14 degrees Katana 18.3 degrees steep Nitro 13.25 degrees quite flat That can vary slightly with canopy size. I don't have the figures for the Pulse but I know that the angle of depression is lower than those canopy above. The Pulse is known to have a quite flat flight like the Nitro and Nitron. Angle of depression is the angle measured between the chord of the airfoil and the horizontal. The flight steepness of a canopy depends on (according John LeBlanc from PD) : 1) angle of depression 2) weight distribution 3) canopy designLearn from others mistakes, you will never live long enough to make them all. Quote Share this post Link to post Share on other sites
Deimian 43 #19 September 26, 2016 That is interesting. Any chance you have that number for a Crossfire 2 and Lotus Max as well? Quote Share this post Link to post Share on other sites
