unclecharlie95 3 #1 August 28, 2016 I'm a newbie rigger and encountered a reserve with the slider mounted upside down. (Smooth side of the grommets was facing up towards the canopy) Would you correct it? I did and also corrected the next 2 canopies I saw with the same problem! Seems to be quite a few canopies out there like this but I assume the ramifications are slim / none?BASEstore.it Quote Share this post Link to post Share on other sites
likestojump 3 #2 August 28, 2016 which way was the tape facing ? Quote Share this post Link to post Share on other sites
gowlerk 2,277 #3 August 28, 2016 QuoteI'm a newbie rigger and encountered a reserve with the slider mounted upside down. (Smooth side of the grommets was facing up towards the canopy) I'm curious why you feel this is wrong. Did you see this is a manual somewhere, or is it just something someone told you?Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
sundevil777 102 #4 August 28, 2016 QuoteSmooth side of the grommets was facing up towards the canopy Why would that be wrong? It would seem to be right to me, but I'm not a rigger. P. 34 of the PD reserve manual shows a pic that looks to clearly show that the smooth side is towards the canopy.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
unclecharlie95 3 #5 August 28, 2016 sundevil777QuoteSmooth side of the grommets was facing up towards the canopy Why would that be wrong? It would seem to be right to me, but I'm not a rigger. P. 34 of the PD reserve manual shows a pic that looks to clearly show that the smooth side is towards the canopy. Which PD manual are you looking at? The manual I have shows the smooth side (without the lip) towards the container.BASEstore.it Quote Share this post Link to post Share on other sites
jerolim 7 #6 August 28, 2016 Tape has to face canopy! Quote Share this post Link to post Share on other sites
sundevil777 102 #7 August 28, 2016 unclecharlie95***QuoteSmooth side of the grommets was facing up towards the canopy Why would that be wrong? It would seem to be right to me, but I'm not a rigger. P. 34 of the PD reserve manual shows a pic that looks to clearly show that the smooth side is towards the canopy. Which PD manual are you looking at? The manual I have shows the smooth side (without the lip) towards the container. I just looked at the manual on their website. Perhaps I'm misinterpreting the picture. I'm the wrong person to be saying what's right, just wanted to point out that there is a pic on their manual.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
riggerrob 643 #8 August 28, 2016 Slider grommets are not the only way to determine if a slider is right-way-up. Tapes are more important. Tapes should face up, towards the canopy. The theory is that if stitching fails, fabric will will be blown up, to press against tapes, keeping fabric attached to grommets. Quote Share this post Link to post Share on other sites
fcajump 164 #9 August 29, 2016 gowlerkQuoteI'm a newbie rigger and encountered a reserve with the slider mounted upside down. (Smooth side of the grommets was facing up towards the canopy) I'm curious why you feel this is wrong. Did you see this is a manual somewhere, or is it just something someone told you? The theory on the grommets direction is that the smooth side should face the direction of motion (i.e. down the lines, towards the container) so that any irregularities, bumps, ridges, etc are on the 'back side' and not causing drag, extra friction and/or wear on the lines. Taking both of these notions in mind, if you find a conflict (i.e. binding up but not smooth grommet down), I would contact the canopy mfg and ask which they want. They designed, tested and certified it. So it should be their way. JWAlways remember that some clouds are harder than others... Quote Share this post Link to post Share on other sites
unclecharlie95 3 #10 August 29, 2016 Thank you for the repliesBASEstore.it Quote Share this post Link to post Share on other sites
sundevil777 102 #11 August 29, 2016 QuoteThe theory on the grommets direction is that the smooth side should face the direction of motion (i.e. down the lines, towards the container) so that any irregularities, bumps, ridges, etc are on the 'back side' and not causing drag, extra friction and/or wear on the lines. Especially during early stages of opening (slider up high), I would think the lines are wrapped around more of the radius of the grommet that faces the canopy, so that would be more critical to have the "smooth" side. That would match what I think is shown in the latest PDR manual. That is just me doing easychair thinkin', it will be interesting to hear from more authoritative sources.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
fcajump 164 #12 August 29, 2016 sundevil777 ...it will be interesting to hear from more authoritative sources. Absolutely. Anyone from a canopy mfg wish to pipe up? JWAlways remember that some clouds are harder than others... Quote Share this post Link to post Share on other sites
parachutist 2 #13 August 29, 2016 sundevil777QuoteThe theory on the grommets direction is that the smooth side should face the direction of motion (i.e. down the lines, towards the container) so that any irregularities, bumps, ridges, etc are on the 'back side' and not causing drag, extra friction and/or wear on the lines. Especially during early stages of opening (slider up high), I would think the lines are wrapped around more of the radius of the grommet that faces the canopy, so that would be more critical to have the "smooth" side. That would match what I think is shown in the latest PDR manual. That is just me doing easychair thinkin', it will be interesting to hear from more authoritative sources. I heard another explanation years back. It went something like this: === foggy memory recollection === When sliders come down hard during terminal openings, they slam into the links at the bottom with a lot of force, even if bumpers are installed. The link acts as a hammer, just like when the grommets are getting set at the factory. So you want the grommet parts to get hammered together instead of apart, and that's why the smooth side is up. === /fog ==== Quote Share this post Link to post Share on other sites
masterrigger1 2 #14 August 30, 2016 Quote I'm a newbie rigger and encountered a reserve with the slider mounted upside down. (Smooth side of the grommets was facing up towards the canopy) A couple of manufacturers; past and present, install the grommets the opposite way that the rest of the manufacturers do. Flight Concepts International (previously Glide Path) is one of them. MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
IJskonijn 45 #15 August 30, 2016 I thought the whole goal of bumpers was to prevent the grommets from being damaged by the hard links. And in todays world of slinks, I doubt that's still a relevant consideration. Quote Share this post Link to post Share on other sites
chutem 0 #16 August 30, 2016 Should the rigs in question be grounded until this is sorted out? Quote Share this post Link to post Share on other sites
parachutist 2 #17 August 30, 2016 IJskonijnI thought the whole goal of bumpers was to prevent the grommets from being damaged by the hard links. And in todays world of slinks, I doubt that's still a relevant consideration. The hammer force I was mentioning referred to assembly/disassembly action, not damage. Grommets start out as 2 pieces and they get pressed or hammered together into 1. If they get knocked the other direction, they can come apart. Lines could get caught in the new gap, which wouldn't be good. Bumpers are there to prevent dings, gashes, and dents in the grommets. It's a different sort of damage. Soft links are relatively new. Many canopies still use metal links, and most sliders were not designed to be used specifically with them. Some evidence that current canopy designs were not engineered for soft links: [inline 20150417_163313s.jpg] Metal links have a small diameter, so small finger trap loops were designed to fit onto those metal links. Along came soft links which are bulkier: they need to pass through those same small loops twice. Sometimes maybe these fat soft links didn't go through the small loops easily because the gear wasn't designed for them. Quote Share this post Link to post Share on other sites
