deltadriftwood 0 #1 October 7, 2014 Released brakes but nothing from left toggle but tension. Spun left fast and shortly after chopped. I think this was started by a tension knot. Looks like some more stuff going on though? Any ideas? Quote Share this post Link to post Share on other sites
accumack 14 #2 October 7, 2014 To me it looks like a possible steering line over the nose from packing. I could be wrong. Quote Share this post Link to post Share on other sites
Pobrause 6 #3 October 7, 2014 Thats not a tension knot, thats a propper lineover...------------------------------------------------------- To absent friends Quote Share this post Link to post Share on other sites
TheCaptain 2 #4 October 7, 2014 It appears to me that you have half of a step through above the slider. Basically half of your canopy was flipped above the slider. Your second picture you can see the lines cross above the sliderKirk He's dead Jim Quote Share this post Link to post Share on other sites
BIGUN 1,488 #5 October 7, 2014 TheCaptainIt appears to me that you have half of a step through above the slider. Basically half of your canopy was flipped above the slider. Your second picture you can see the lines cross above the slider Looks that way to me also.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
betzilla 56 #6 October 7, 2014 if it were an actual step-through or riser flip-through, the slider would have to be twisted. But I do see the crossed lines, and it looks to me like it was assembled incorrectly. Quote Share this post Link to post Share on other sites
Alexg3265 0 #7 October 7, 2014 Sloppy packing... and either the d lines and or the brake lines worked their way around and in front of the nose. Line over in my opinion.I was that kid jumping out if his tree house with a bed sheet. My dad wouldn't let me use the ladder to try the roof... Quote Share this post Link to post Share on other sites
Bluhdow 31 #8 October 7, 2014 Body position!Apex BASE #1816 Quote Share this post Link to post Share on other sites
gowlerk 2,277 #9 October 7, 2014 Could be a line over, could be a tension knot at the brake line cascades. Easy enough to tell for sure. If it was a line over you will find heavy line burn damage on the topskin of the canopy. If you don't have obvious damage there, then there was no line over. Hang it up, do a careful inspection and let us know what you find.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
deltadriftwood 0 #10 October 8, 2014 Thanks. It had 40 jumps since last disconnected from the container so the assembly was right. However, the Last jump before this was onto an island and it got stuffed into a garbage bag best I could then repacked hastily in a hotel room but then repacked again by a packer I trust. I think there was definitely some "cause" here. I see the crossed lines, the lineover. Quote Share this post Link to post Share on other sites
