JBR 0 #1 September 12, 2014 this may have already been posted but I couldn't find it. I would say I'm surprised by the goings on in this but nothing surprises me any more! https://www.youtube.com/watch?v=L8Y4SG6dHOo Quote Share this post Link to post Share on other sites
sirenoremac 0 #2 September 12, 2014 At 3:18, it looks like he reaches up to collapse the slider on his reserve before realizing what he's doing :) Made me giggle. https://www.youtube.com/watch?v=L8Y4SG6dHOo#t=197 Quote Share this post Link to post Share on other sites
councilman24 37 #3 September 12, 2014 I hope he KNEW there were no wires between those poles.For newbies, roads and poles equal generally equal wires that you can't see. I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
craddock 0 #4 September 13, 2014 councilman24 I hope he KNEW there were no wires between those poles.For newbies, roads and poles equal generally equal wires that you can't see. Except there were no power poles. Only STEEL light poles. Even so there would have been room on the side. But wires between steel light poles in town would be something I have never seen. I get your point and that should be covered in the fjc for newbies but I saw no issue with that landing. Hell the Road was wide open anyway That spot isn't bad at all, the winds were strong and that was the issue! It was just on the downwind side. Quote Share this post Link to post Share on other sites
pchapman 280 #5 September 13, 2014 I didn't so much mind that the wingsuit rodeo failed, or that the 2 non-wingsuiters went for some plan-B RW, or that their wingsuiting friend made a wide pass after they had opened. What was useful as a cautionary tale was the poor CRW between the two non-wingsuiters, that resulted in a double cutaway. Both guys were maneuvering at the same time. While CRW pros might well be able to hack that, normally one person flies steady and the other attempts to pin. Here the bottom guy had a moving target above and in front of him, sashaying around unpredictably. No wonder they ended up with a wrap / entanglement. Quote Share this post Link to post Share on other sites
craddock 0 #6 September 13, 2014 Yep. I showed and explained it to my whuffo friend as meeting someone in a hallway and both moving. Probably a real bad analogy but good enough for a non jumper. If I had been behind(which I would have been in that situation) I would have been screaming at him to hold fucking still so I could park it on him. At first.... then I would have turned and burned if I had my doubts. And yes. I have been there before doing x braced crw with my buddy for his first time. And I did take off and regrouped on the ground. That spot isn't bad at all, the winds were strong and that was the issue! It was just on the downwind side. Quote Share this post Link to post Share on other sites
parachutist 2 #7 September 13, 2014 councilman24 I hope he KNEW there were no wires between those poles.For newbies, roads and poles equal generally equal wires that you can't see. His priorities were mixed up... He landed there chasing his fb/pc. Quote Share this post Link to post Share on other sites
craddock 0 #8 September 13, 2014 I thought it was amusing that the later guy to cut away had his canopy partially inflated flying backwards entangled with the other main and yet still collapsed his slider before cutting away. Some might say to get a better look but really? There was any thought of not cutting that away That spot isn't bad at all, the winds were strong and that was the issue! It was just on the downwind side. Quote Share this post Link to post Share on other sites
mattjw916 2 #9 September 13, 2014 What a buncha quitters! They had plenty of altitude left under their reserves to try that dock again! NSCR-2376, SCR-15080 Quote Share this post Link to post Share on other sites
yoink 321 #10 September 13, 2014 That is a god-awful bit of CRW... You could see the collision coming for about 2 minutes. At least they both had matchy matchy canopies and Go-Pros though. Quote Share this post Link to post Share on other sites
SmokeJumper 0 #11 October 11, 2014 CRW 101 Talk to each other! Seems I only heard the upper (wrapped) jumper saying anything. Quote Share this post Link to post Share on other sites
