jurajpetrik 0 #1 December 20, 2015 I am getting my first rig second hand. The owner says t is supposed to fit Sabre 150 Sabre 170 and Pulse 190. I find it pretty hard to find a used Pulse 190 so I want to know if there are any canopies that will pack similar to Pulse at 190 square feet. Doesn't have to be from PD.. Quote Share this post Link to post Share on other sites
likestojump 3 #2 December 20, 2015 straight from the horses mouth ... http://www.performancedesigns.com/packingchart.aspx Quote Share this post Link to post Share on other sites
Anachronist 2 #3 December 20, 2015 Any 7-cell of the same size. Specter, Storm, etc 9-cells of the same size - Pilot ZPX, Fluid Prime. Most 9-cells a size smaller. All manufacturers of containers have fit charts on their website that will tell you how different canopies will pack. e.g. http://www.performancedesigns.com/packingchart.aspx http://www.unitedparachutetechnologies.com/PDF/CHART_00037___Rig_Sizing_Chart.pdf https://www.miragesys.com/sizing-guide/ http://www.sunpath.com/canopysizing.php Quote Share this post Link to post Share on other sites
gowlerk 2,296 #4 December 21, 2015 QuoteThe owner says t is supposed to fit..... Be aware that this means very little. Consult a rigger, or take a picture of the container label and post it here if you don't have a rigger you can count on.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
jurajpetrik 0 #5 December 21, 2015 AnachronistAny 7-cell of the same size. Specter, Storm, etc 9-cells of the same size - Pilot ZPX, Fluid Prime. Most 9-cells a size smaller. All manufacturers of containers have fit charts on their website that will tell you how different canopies will pack. e.g. http://www.performancedesigns.com/packingchart.aspx http://www.unitedparachutetechnologies.com/PDF/CHART_00037___Rig_Sizing_Chart.pdf https://www.miragesys.com/sizing-guide/ the container is mirage g3. I checked the link you posted but no size there seems to fit the reserve / main combo. I haven't received the container yet. But when I do will it's size be written on it? Quote Share this post Link to post Share on other sites
Snowcrash 0 #6 December 21, 2015 A Silhouette might also do the trick. It's the same sort of hybrid design as the Pulse. Flat glide, good easy to pack first canopy. It will recover very quickly after a turn though, so be sure to give it a second or two to pick up speed again. Otherwise you might stall one side of the canopy when you initiate the next turn. Could give you an interesting perspective on the world if you're down low... Other than that I'd say it's a great beginners canopy. Quote Share this post Link to post Share on other sites
Anachronist 2 #7 December 21, 2015 jurajpetrik***Any 7-cell of the same size. Specter, Storm, etc 9-cells of the same size - Pilot ZPX, Fluid Prime. Most 9-cells a size smaller. All manufacturers of containers have fit charts on their website that will tell you how different canopies will pack. e.g. http://www.performancedesigns.com/packingchart.aspx http://www.unitedparachutetechnologies.com/PDF/CHART_00037___Rig_Sizing_Chart.pdf https://www.miragesys.com/sizing-guide/ the container is mirage g3. I checked the link you posted but no size there seems to fit the reserve / main combo. I haven't received the container yet. But when I do will it's size be written on it? g3 is the model not the size (which I think you already know) ask the seller what size it is or the SN and then call Mirage and ask them. I don't know where the size is written on a Mirage but yes, it should be somewhere, warning label, packing card pocket, etc. You will see combos that don't seem to match sometimes, they are "guidelines." Quote Share this post Link to post Share on other sites
gowlerk 2,296 #8 December 21, 2015 QuoteI haven't received the container yet. But when I do will it's size be written on it? Yes, on the label it will have an M#. That is the container size. In this case probably M4. There will be other numbers for the harness size. The size chart was probably published before the Pulse was available, but it lists a Sabre 150 as soft and a 170 as optimal. Also lists a silhouette 190 as optimal. But what reserve do you have for it? Unless you have a low volume reserve it only fits a 160. I have put 176s into one, but it's not pretty. If the M# is 3 or 3x ask for your money back. You've been lied to.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
3331 138 #9 December 22, 2015 From Parachute labs Inc. in DeLand Florida. http://www.plabsinc.com/1.html http://www.jumpshack.com/firebolt.htm I Jumped with the guys who invented Skydiving. Quote Share this post Link to post Share on other sites
jurajpetrik 0 #10 December 23, 2015 So the size is M2. The reserve is PD 143R. Just checked the Mirage website and it lists Sabre fits with 135-150. The rig is already paid for and on its way. Did I fuck up? It looks like it. The label is here https://scontent-vie1-1.xx.fbcdn.net/hphotos-xtf1/v/t1.0-9/11229410_10155967679030109_665101189353601477_n.jpg?oh=b4286ef4e4d4b9dff4b083ba93f1d8f2&oe=5719C7E4 Quote Share this post Link to post Share on other sites
gowlerk 2,296 #11 December 23, 2015 Did the seller tell you it would fit a 190? Did you use paypal? If you used paypal, first contact the seller and say that the container is not what was claimed and you want to return it. If the seller won't allow that, contact Paypal and begin a dispute. If you used friends and family payment, you are out of luck. You can try to resell it, you can keep it till you can use it. You can try to make a trade locally with a jumper who is ready to downsize. All is not lost, but you will not be able to fit large enough canopies for a beginner into it. There is also the possibility that you paid too much. What you need is a local rigger that you can trust advising you. New jumpers go through this all the time trying to get first gear as cheaply as possible. I understand this, I've seen it a lot. Your profile has nothing in it. Complete it as much as you can and then people will see where you are. Someone who can help you may be on here and nearby you. Skydivers generally want to help newbies. Don't be shy. If you would like to actually talk to me a bit, send me a PM.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
jumpsalot-2 3 #12 December 23, 2015 Live and Learn ....... and don't buy a Racer just because it fits all your canopies. Life is short ... jump often. Quote Share this post Link to post Share on other sites
jurajpetrik 0 #13 December 23, 2015 So i've taken a few deep breaths and I think all is not lost. In fact I think everything will be just fine. The owner claims he was jumping a Sabre 170 in it and since he is shipping it packed inside I believe him. According to the Mirage guide it fits a Storm/Spectre 170 and according to the PD guide a Pulse 190 packs the same volume as those two. So I should be able to fit the Pulse 190 inside, nothing else but that's fine. In fact a Sabre 170 is just a one size bigger than Storm/Spectre 170 so looks like he's been exceeding the specs a little bit. I will not do that and I'll probably sell the Sabre to a new jumper since it sells pretty cheaply. Quote Share this post Link to post Share on other sites
Russell_Jones 0 #14 December 23, 2015 I would talk to your local instructors / riggers about this. I wouldn't want to downsize from a 190 to a 143 at 2000ft in the event of a reserve ride! Reserves don't flare as easily as mains and probably fly very differently from canopies you've flown in the past. Quote Share this post Link to post Share on other sites
gowlerk 2,296 #15 December 23, 2015 At least the reserve container is not over stuffed. But that does leave you with the fact that the reserve is too small for you. Skydiving is an adult sport and you can decide to go for it, but if you feel you need a 190 main why do you think a 143 is a large enough reserve? Depending on the DZ rules where you are you may get grief from the safety officer. And for good reason. You may possibly be required to jump something larger for a while. I'm not even going to ask what you weigh. When newbies talk about using small reserves in this forum it almost always sparks a shit storm of criticism. So be prepared. The Sabre 2 170 in that container will be difficult to pack, so be prepared for that as well. In the end, your Mirage setup is probably a really nice rig, and should bring you a lot of fun. Congratulations.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
Anachronist 2 #16 December 23, 2015 Mirage doesn't include "tight fitting" canopies so you can probably horseshoe a Pulse 190 in there. But yeah, the issue is as much the reserve as it is the main. You could put a OP 160 in it but then you are still going to be downsizing at 2k ft or less, as previously mentioned. You're going to use your reserve at some point, you have to be comfortable flying it under less than ideal conditions and potentially landing off. Most folks don't (no one I know of actually) jump a reserve two sizes smaller than their main... Quote Share this post Link to post Share on other sites
mathrick 2 #17 December 23, 2015 In pretty much all the non-student rigs I've seen, the reserve is smaller until you hit about 100sqft. For student rigs, it's 50/50, depending on how big the main is (our student rigs all have 240 reserves, whilst main is either 260 or 240). You generally want it slightly smaller, for two-out handling(*). My own (second-hand) rig is 170/147, and it was completed for me by an instructor and a master rigger. 190/160 sounds like it should be about the same ratio, though you will obviously still want to run it through a competent adult before committing to anything. (*) Based on PD's tests, it's really a function of line length, rather than area as such. Smaller wings tend to have shorter lines, though it's not impossible to find a combination of main/reserve where the smaller reserve will have longer lines."Skydivers are highly emotional people. They get all excited about their magical black box full of mysterious life saving forces." Quote Share this post Link to post Share on other sites
jurajpetrik 0 #18 December 24, 2015 Yes I am concerned about the 143 reserve. I've talked to three experienced jumpers on my dropzone separately and they've all said it's fine. I will probably try to get the Optimum 160 reserve, I'll be wingloading that at 1.25. Not perfect but manageable I suppose? The attitude at my dropzone is that since it's a reserve ride as long as it saves your life it's okay and it flies docile because it's a 7 cell. Again I'm just a newbie so I don't really know much. Quote Share this post Link to post Share on other sites
virgin-burner 1 #19 December 24, 2015 jurajpetrikYes I am concerned about the 143 reserve. I've talked to three experienced jumpers on my dropzone separately and they've all said it's fine. I will probably try to get the Optimum 160 reserve, I'll be wingloading that at 1.25. Not perfect but manageable I suppose? The attitude at my dropzone is that since it's a reserve ride as long as it saves your life it's okay and it flies docile because it's a 7 cell. Again I'm just a newbie so I don't really know much. or you could get a speed 2000 from paratec which packs even smaller than the optimum. just saying. but i also think you'll probably be fine under the reserve you have now, it's still a reserve and not a velocity.“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
gowlerk 2,296 #20 December 24, 2015 Like I said earlier, it's an adult sport. You'll probably be fine.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
jumpsalot-2 3 #21 December 24, 2015 jurajpetrik Yes I am concerned about the 143 reserve. I've talked to three experienced jumpers on my dropzone separately and they've all said it's fine. I will probably try to get the Optimum 160 reserve, I'll be wingloading that at 1.25. Not perfect but manageable I suppose? The attitude at my dropzone is that since it's a reserve ride as long as it saves your life it's okay and it flies docile because it's a 7 cell. Again I'm just a newbie so I don't really know much. Quote So .... 1.4 wingloading on the 143R ........ good luck if you are ever unconscious under that reserve .... toes, knees, face. Life is short ... jump often. Quote Share this post Link to post Share on other sites
jurajpetrik 0 #22 December 25, 2015 virgin-burneror you could get a speed 2000 from paratec which packs even smaller than the optimum. just saying. but i also think you'll probably be fine under the reserve you have now, it's still a reserve and not a velocity. What size speed 2000 do you think I could pack in there? I've emailed Mirage and Paratec with the same question. If I can get a bigger reserve in there I probably will. Quote Share this post Link to post Share on other sites
Pobrause 6 #23 December 25, 2015 That a speed 2000 reserve packs noticable smaler than a comparable size optimum is a myth.------------------------------------------------------- To absent friends Quote Share this post Link to post Share on other sites
virgin-burner 1 #24 December 25, 2015 PobrauseThat a speed 2000 reserve packs noticable smaler than a comparable size optimum is a myth. why does every rigger tell me otherwise? besides the point, i jump an optimum and am very happy with it. no rides on speed's, but i hear they're a fine reserve.“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
virgin-burner 1 #25 December 25, 2015 jurajpetrik ***or you could get a speed 2000 from paratec which packs even smaller than the optimum. just saying. but i also think you'll probably be fine under the reserve you have now, it's still a reserve and not a velocity. What size speed 2000 do you think I could pack in there? I've emailed Mirage and Paratec with the same question. If I can get a bigger reserve in there I probably will. i have no idea, but i'm sure paratec or mirage will give you a more competent answer than anyone here on this forum. “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
