phoenixlpr 0 #1 September 26, 2015 Does everything look OK on this picture? Thanks for you opinions! Quote Share this post Link to post Share on other sites
riggerrob 644 #2 September 26, 2015 I see 2 problems: First: some one stole your slider. Hah! Hah! Secondly: your bridle is miss-routed UNDER your canopy. I doubt if opened with the bridle so badly miss-routed. Chances are the bridle miss-routed itself when they canopy surged after initial inflation. Quote Share this post Link to post Share on other sites
phoenixlpr 0 #3 September 26, 2015 From the very same jump. Quote Share this post Link to post Share on other sites
virgin-burner 1 #4 September 26, 2015 were you drunk when you hooked that up!? “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
phoenixlpr 0 #5 September 26, 2015 virgin-burner were you drunk when you hooked that up!? What trouble can happen jumping a rig like that. Tension knot? Quote Share this post Link to post Share on other sites
virgin-burner 1 #6 September 26, 2015 phoenixlpr ***were you drunk when you hooked that up!? What trouble can happen jumping a rig like that. Tension knot? i'm not a rigger, that's what most likely could happen. see twisted steering-lines in skydiving, or worse, BASEjumping, that resulted in bad things happening. friction is higher, so more chances of. i would fix that if i were you. i've hooked my first canopy up alone (skydiving) and had a line misplaced, i fixed that instantly before the next jump, it freaked me out. keep your gear in functioning order, treat it well, it may safe your life! “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
stayhigh 2 #7 September 26, 2015 Unhook the left frontside slinks and twist them couple time to even things out. Symmetry is the key bro.Bernie Sanders for President 2016 Quote Share this post Link to post Share on other sites
virgin-burner 1 #8 September 26, 2015 stayhigh Unhook the left frontside slinks and twist them couple time to even things out. Symmetry is the key bro. THAT^^ i think there's even something like a step-through as to describe best. you were so totally drunk dude, i'm PMSL here. “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
mark 107 #9 September 26, 2015 virgin-burneri think there's even something like a step-through as to describe best. Can't be a step-through if the lines were assembled correctly and the lines on the rear riser are still correct. Mark Quote Share this post Link to post Share on other sites
virgin-burner 1 #10 September 26, 2015 mark ***i think there's even something like a step-through as to describe best. Can't be a step-through if the lines were assembled correctly and the lines on the rear riser are still correct. Mark mark, there's NO WORD for this, it's NOT assembled correctly, that's what's so funny about it! the riser is twisted and SOMEONE managed to even turn it through the lines, i dont know how to describe it. “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
hookitt 1 #11 September 28, 2015 riggerrobI see 2 problems: First: some one stole your slider. Hah! Hah! Secondly: your bridle is miss-routed UNDER your canopy. I doubt if opened with the bridle so badly miss-routed. Chances are the bridle miss-routed itself when they canopy surged after initial inflation. I'm assuming you're not serious :) ... The bridle under the canopy is a shadow. The Right line group was hooked up with a twist.My grammar sometimes resembles that of magnetic refrigerator poetry... Ghetto Quote Share this post Link to post Share on other sites
hookitt 1 #12 September 28, 2015 phoenixlpr What trouble can happen jumping a rig like that. Tension knot? To answer that question: There would be accelerated line wear.My grammar sometimes resembles that of magnetic refrigerator poetry... Ghetto Quote Share this post Link to post Share on other sites
jdewey95 0 #13 September 28, 2015 New A license here, can someone point out what I'm seeing? The point where the toggle lines attach looks weird but I can't put my finger on what it is Quote Share this post Link to post Share on other sites
phoenixlpr 0 #14 September 28, 2015 jdewey95New A license here, can someone point out what I'm seeing? The point where the toggle lines attach looks weird but I can't put my finger on what it is Hook-up of the right front group of lines is incorrect, you can see the right front riser has a 180 degree twist. I ou can see the tip of the riser faces backward. It is a rigging fault. Quote Share this post Link to post Share on other sites
betzilla 56 #15 September 28, 2015 Looks like the right front link got flipped through its line group a time or two before being connected to the riser. Should take you about a minute to fix it (or an hour if you stink at puzzles). Quote Share this post Link to post Share on other sites
hackish 8 #16 September 28, 2015 Worse than that I had to call a rigger (second time) this year for hooking a reserve up like this. First time i called him was for finger tight rapide links. If there ever is a 3rd time it will be a report to make sure his ticket is revoked. -Michael Quote Share this post Link to post Share on other sites
jbscout2002 1 #17 September 28, 2015 hackishWorse than that I had to call a rigger (second time) this year for hooking a reserve up like this. First time i called him was for finger tight rapide links. If there ever is a 3rd time it will be a report to make sure his ticket is revoked. -Michael This is why I still have low jump numbers. I've been spending all of my money on gear, rigging classes, and tools. After reading the BPA confidential incident reports, I can't trust anyone I don't know to assemble, adjust, alter, repair, or repack my gear, and I definitely don't trust rental gear. Quote Share this post Link to post Share on other sites
hackish 8 #18 September 29, 2015 jbscout2002 This is why I still have low jump numbers. I've been spending all of my money on gear, rigging classes, and tools. After reading the BPA confidential incident reports, I can't trust anyone I don't know to assemble, adjust, alter, repair, or repack my gear, and I definitely don't trust rental gear. Whether it's doctors, mechanics or riggers there will always been good and bad practitioners. Keep in mind too that all riggers make mistakes. The careful ones catch their own mistakes before the equipment goes into service. -Michael Quote Share this post Link to post Share on other sites
Sincy78 1 #19 September 29, 2015 I don't think there is a twist in the right front riser. It looks like there is just one line thats been mis-routed. All the lines would be involved if it were a twist. Zoom in on the problem area, only one line is routed wrong. Assembly error. Quote Share this post Link to post Share on other sites
betzilla 56 #20 September 30, 2015 QuoteIt looks like there is just one line thats been mis-routed. The link has been flipped through the line group between that one line and the other lines. That's why the other ones look twisted around each other. Quote Share this post Link to post Share on other sites
tikl68 6 #21 October 1, 2015 Exactly. not JUST twisted but flipped through itself. Quote Share this post Link to post Share on other sites
virgin-burner 1 #22 October 1, 2015 yea, we all know that by now, since sunday night actually..“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
craigbey 0 #23 October 4, 2015 Thank for posting the pictures. This is really timely. I just replaced a slider today and ended up with the same problem after reconnecting everything. DOH! Fortunately, I discovered the problem on the ground, but now I'm not so sure about the rest of my work... Quote Share this post Link to post Share on other sites
format 1 #24 October 5, 2015 Looks like a 130ft loaded at 1.8 How wrong am I? What goes around, comes later. Quote Share this post Link to post Share on other sites
