jguy904 0 #1 April 4, 2015 how much counter weight would be needed for a 3by5 flag and a 6by10 flag/ MUFF #3384, DIRTY SANCHEZ #28(Chief Recruiting Officer), FALLING GATOR #7801-A, POPS #10957, FLYING HELLFISH #847, HISPAS #79, SRA #9229, Surfador Rodrigues Quote Share this post Link to post Share on other sites
angryelf 0 #2 April 4, 2015 I've used 2-4 lbs for 3x5, i think upwards of 6 for the 6x10. My recommendation is build a weight bag that you can add/remove 2lb SOFT shot dive weights to. That way you can adjust the weight for various flags and avoid the dribbling of shot into your sewing machine trying to custom make weights."Sometimes you eat the bar, and well-sometimes the bar eats you..." Quote Share this post Link to post Share on other sites
PhreeZone 20 #3 April 4, 2015 If the flag will only be used for jumping, a better design is to have the weight sewn into the leading edge instead of having a drop weight. This allows for the flag to fly straighter and lets you use less weight. This keeps you from having the potential of dropping a weight also.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
jguy904 0 #4 April 5, 2015 thanks MUFF #3384, DIRTY SANCHEZ #28(Chief Recruiting Officer), FALLING GATOR #7801-A, POPS #10957, FLYING HELLFISH #847, HISPAS #79, SRA #9229, Surfador Rodrigues Quote Share this post Link to post Share on other sites
normiss 900 #5 April 6, 2015 Or a large enough drop weight that will take a little enacted ebay kero his feet. In the end zone. Quote Share this post Link to post Share on other sites
fcajump 164 #6 April 8, 2015 I'd suggest double checking your design for failure modes... (what happens if it fails "this" way...) Better to leak small shot than drop a weight (or bag of shot). Also, good idea to clear the airspace/ground below before deploying the flag if you're using a weight. I dropped one years ago and was REALLY glad it was into an open field away from the audience. For a 3x5 and 4x6 there are also setups that do not use a weight and allow for the jumper to recover the flag without dragging it. JWAlways remember that some clouds are harder than others... Quote Share this post Link to post Share on other sites
