indyz 1 #1 January 20, 2015 Can anybody recommend a good, affordable, set of cable cutters? All of the stuff at my local hardware stores says "not for steel". Quote Share this post Link to post Share on other sites
GD64 1 #2 January 20, 2015 indyz.........try Grainger.com Put "steel cable cutter" in search box. You didn't say whether hard or soft steel, or gauge. Anyway there are several choices. We use Greenlee or Klein brand cable cutters mostly because of the no questions asked replacement, even when the tool destruction is clearly our fault. Grainger does have other brands as well. If it's for rigging purposes you should be able to find something in the $100 range. Just a reminder that a larger cutter gives you more leverage with less effort (in case you are looking at doing many repetitions). Quote Share this post Link to post Share on other sites
peek 21 #3 January 20, 2015 indyzCan anybody recommend a good, affordable, set of cable cutters? All of the stuff at my local hardware stores says "not for steel". I have purchased a couple of large diagonal cutters at local stores that have worked well (assuming they stay sharp). Maybe $10 to $20? I have never seen anything on the packaging that says "not for steel". Quote Share this post Link to post Share on other sites
indyz 1 #4 January 20, 2015 peekI have purchased a couple of large diagonal cutters at local stores that have worked well (assuming they stay sharp). Maybe $10 to $20? I have never seen anything on the packaging that says "not for steel". I've used dikes and can usually get a serviceable cut with them, but in my experience purpose-built cable cutters with triangular or curved blades are consistently better. Our dropzone has a bench-mounted cutter that is awesome, but also expensive and non-portable. I've gotten a couple recommendations via PM that I'm going to follow up on, including this one. Para Gear also has a cutter for $65. Quote Share this post Link to post Share on other sites
councilman24 37 #5 January 20, 2015 I use some very much like these with very good success. Diagonal cutters with straight cutting edges flatten the cable. http://www.lowes.com/pd_338233-32251-2972-PKG_4294719596__?productId=3554900&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar|1&facetInfo=I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
ineed2fly 0 #6 January 21, 2015 http://www.paragear.com/skydiving/10000168/M6945/CABLE-CUTTER-HEAVY-DUTY"As soon as you're born you start dying. So you might as well, have a good time." -CAKE I'm crazy not stupid. There is a difference. Quote Share this post Link to post Share on other sites
inspector 0 #7 January 22, 2015 A little cheaper than above but are the best for clean cuts, low hand force and long life - http://www.felcostore.com/item/f-c7?gclid=CNONrfGwpsMCFQpsfgodaV8AQw"Just because nobody complains doesn't mean all parachutes are perfect" B. Hill Quote Share this post Link to post Share on other sites
DrewEckhardt 0 #8 January 24, 2015 indyzCan anybody recommend a good, affordable, set of cable cutters? All of the stuff at my local hardware stores says "not for steel". Felco. http://www.amazon.com/Loos-Cableware-Felco-Cable-Cutter/dp/B0038YY3QC Quote Share this post Link to post Share on other sites
JerryBaumchen 1,486 #9 January 25, 2015 Hi indyz, Re: cable cutters http://www.loosco.com/index.php?page=loos-hardware http://www.felco.com/felco/pages/category.page?name=190 COUPE-CABLES A 1 MAIN Or use the Amazon option, Jerry Baumchen Quote Share this post Link to post Share on other sites
erdnarob 1 #10 February 1, 2015 See ParaGear catalog.Learn from others mistakes, you will never live long enough to make them all. Quote Share this post Link to post Share on other sites
angryelf 0 #11 February 1, 2015 Try the Park tool cable cutter. (Made for cutting brake/shifter cables on bicycles). Cheap, small, well made most importantly it makes a very clean cut/end termination. -Harry"Sometimes you eat the bar, and well-sometimes the bar eats you..." Quote Share this post Link to post Share on other sites
betzilla 56 #12 February 5, 2015 I bought a great set online for like $15 from a place that sells bike repair tools. If I could remember the website, I'd post it, but that was a few years back. They're better than anything "skydive specific" I've used, or anything I could find at home depot. Quote Share this post Link to post Share on other sites
