HotLoad 0 #1 June 21, 2001 Happy longest day of the year to you all. I hope some of you get a couple of extra jumps in today. If you do, pull low for me once, I'll be stuck at work ALL day. Wouldn't matter anyway, dz's closed till Sat.Blue Ones Quote Share this post Link to post Share on other sites
ADRNALN 0 #2 June 21, 2001 Happy sunshine to you too. Quote Share this post Link to post Share on other sites
Dutchboy 0 #3 June 21, 2001 Sorry, I don't pull low for myself or anybody else. I only pull low if I am.The Dutchboyhttp://www.geocities.com/ppolstra Quote Share this post Link to post Share on other sites
HotLoad 0 #4 June 21, 2001 Pull high, pull low, just pull dammit! You should try it sometime, things look pretty big when you dump. Also, if you want to get technical, our definitions of low might be completely different. Some drop zones will chew you out for going below 2500, others will chew you out if you dump above 2500-3000. Quote Share this post Link to post Share on other sites
Aviatrr 0 #5 June 22, 2001 Quote Pull high, pull low, just pull dammit! You should try it sometime, things look pretty big when you dump. Also, if you want to get technical, our definitions of low might be completely different. Some drop zones will chew you out for going below 2500, others will chew you out if you dump above 2500-3000. Low to me is under 2k.. I normally pull at 2.5, sometimes 2k.. Depends on the canopy I'm jupming.. 2k is as low as I will go normally.. For a lot of people, under 3k is low.. To each their own.. Pull where you feel comfortable..Mike Quote Share this post Link to post Share on other sites
