IHazySky 0 #1 October 26, 2014 Looking at Atlanta Attachments catalog, and not sure which right angle binder is the one everyone uses for the container work. http://www.atlatt.com/apparel/EQUIPMNT/folders/binding.html Also, which binder is recommended for lighter work? Straight binder... Any insight into this area is appreciated. Thanks Ian Quote Share this post Link to post Share on other sites
JerryBaumchen 1,468 #2 October 26, 2014 Hi Ian, Quote which binder is recommended for lighter work? IMO no difference. I used a straight in binder for many, many years and was completely satisfied with it. I had seen the right-angle binders and thought they were a 'screwy' system. Then I bought one; I would never go back to a straight in binder again. Yes, I know: Sean Connery said, 'Never say never.' Make sure you get one that is custom made for the type of work ( thicknesses ) that you will expect to be sewing. Jerry Baumchen Quote Share this post Link to post Share on other sites
IHazySky 0 #3 October 26, 2014 I was thinking they were able to handle a small range of thickness. I will be making containers with 1000/500d cordura and 420parapsck. Not totally sure what thickness MDS or foam. Some told me hey had one for litter stuff like PC, d bag, and another for container flaps with plastic. I mean, what about middle range stuff like keypads and foam? I dunno, but I need to get something to practice with, and I don't want to get something I will never use or won't work for the final application... There is not a stock binder that people use for A certain application, like use the 1/8" binder for leg lags and the 1.4 gap for flaps with stiffeners. Just trying to get an idea of how to acquire the correct tool for the job here :) Quote Share this post Link to post Share on other sites
JerryBaumchen 1,468 #4 October 26, 2014 Hi Ian, IMO go for a binder that will handle the thickest material(s) that you expect to be sewing. I am very sure that it will work just fine on the lighter materials. Anyone else? Jerry Baumchen PS) I wish my binder would handle materials thicker than it does; but I can 'almost always' get it to work on just about anything. Not everything. Quote Share this post Link to post Share on other sites
riggerrob 643 #5 October 27, 2014 JerryBaumchenHi Ian, IMO go for a binder that will handle the thickest material(s) that you expect to be sewing. I am very sure that it will work just fine on the lighter materials. Anyone else? Jerry Baumchen PS) I wish my binder would handle materials thicker than it does; but I can 'almost always' get it to work on just about anything. Not everything. ................................................................................ Agreed. Para-Gear tape folders are great for binding thin components like d-bags. But when you start binding multiple layers of Cordura, the inboard stitch sometimes misses the edge of the tape. OTOH if you buy a tape folder for thick materials, it will sew gracefully and few people will notice the extra 1/64 of an inch of free-floating (tape) selvedge edge when you bind thin components. Bottom line: err towards buying too "thick" of a tape folder. Quote Share this post Link to post Share on other sites
IHazySky 0 #6 October 28, 2014 thank you for the replies. Any links to the binders your specifically referring to? Links to ones you are using? I was under the impression they were all custom built, but we all work on quite similar materials/thickness, don't we? Any linkage to reccomended folders would be great. Thanks- Machines are arriving tomorrow. That may be the only good thing about being a grown up, any day can be Christmas ;) Quote Share this post Link to post Share on other sites
JerryBaumchen 1,468 #7 October 28, 2014 Hi Ian, Here is a start: http://www.tennattachment.com/ Drop me an email tomorrow & I'll try get you more info. Jerry Baumchen Quote Share this post Link to post Share on other sites
